Cam belt change mileage/years
Old Mar 20, 2025 | 02:56 PM
negseven's Avatar
Default Cam belt change mileage/years
Hi, my jag has done 84,000 miles and is from 2012, how does the criteria for getting your cam belt changed work. I have been told it is
112,000 miles or 7 years, so by the years it obviously fits that, but as it hasn’t done 112,000 miles how does that make sense?
can anyone explain it more ? Thanks….
Old Mar 20, 2025 | 05:16 PM
NBCat's Avatar
Assuming the vehicle is fitted with the 3.0 litre diesel engine?
What is indicated in the vehicle's Owner's Manual in the maintenance section?
Old Mar 20, 2025 | 06:52 PM
negseven's Avatar
What I was trying to understand was the 7 years or 112,000 miles, roughly at 7 years the car would have done 56,000 miles, so why say 112,000 miles? What’s the logic in that…
Old Mar 20, 2025 | 10:03 PM
POD XF's Avatar
The logic is that the belt will deteriorate with time, regardless of miles travelled and it will deteriorate with use, regardless of the time taken. If the car had been driven home from the dealership and parked in the shed for 7 years, the rubber would be considered to have aged sufficiently to need replacing.
Old Mar 21, 2025 | 10:55 AM
Vasara's Avatar
What ever comes first: Time or distance, like POD XF wrote above.
(this is common practice by any vehicle manufacturer)
DougXK8
Aug 9, 2024 08:08 AM
Mark SF
Jan 18, 2022 10:50 AM
2004XJ8
Jun 18, 2020 05:25 PM
George05
Nov 15, 2019 03:49 PM
Mike198
Jun 16, 2017 12:51 PM
