Climate control not working
Used the car this morning and the blower did not work. The display showed that the fan button indicated all the speeds but no air through the vents. Turned climate control on/off a few times but to no avail. Started car again to see if it reset but now the air vents will not close. Any clues to what is at fault.
a) Resistor pack b) blower motor Would a diagnostic check show up climate control faults? Jaguar XF 2.2d 163hp 2014 model |
Pull the jag specific codes with a code reader and it will tell you much more about the issue
