dab radio addition
Old Jun 30, 2024 | 11:41 AM
Davie1975's Avatar
Default looking for help
I came acoss you post about adding DAB, I have a 2011 xf preface lift that I,m looking to retro fit with DAB. I just need a shopping list. I really wanted to ask you about the pre wiring. looking at the picture below can you tell me if this will be straight forward or not
I appreciate any help you can give
rear c pillar
rear c pillar
rear c pillar
under seat
under seat
Originally Posted by Cambo
Welcome to the forum!
The factory DAB radio can be retrofitted however it is not plug & play, it will need some programming changes to enable it.
Attachment 147827
The wiring for the module may or may not be present, you would have to remove the left c-pillar trim to check if the antenna wiring is there...
I found on 2011MY the wiring was there, on 2014MY was missing, not sure about 2012MY.
Pre-wired in 2011MY
Attachment 147826
Not pre-wired in 2014MY
Attachment 147828
If you can pop off the trim panel and take a picture, I can tell if it's pre-wired or not...
Cambo
72
Feb 17, 2022 07:17 AM
rsmithline
Feb 6, 2021 09:01 AM
apgwales
Nov 14, 2016 01:28 PM
Piersman
Nov 9, 2016 01:40 PM
Jun 13, 2007 08:34 PM
