Drilled rotor reviews
Old Jul 22, 2015 | 03:19 PM
psinsyd's Avatar
Originally Posted by Maddshadez
@psinsyd, There shouldn't be any issues with the sensor, however I just went ahead and removed mine, they were in rough shape anyways and I don't see them worth the cost of replacement, I do a brake check every few months anyways.
Thanks man! Any issues with the warning coming on on the dash? Any mods you needed to do since you're running without them, i.e shorting them out as I've seen some others here mention?
If I did go with them, would they be compatible with the R1 kits available? I haven't torn into the XF brakes as of yet.
Really appreciate the help.
Old Jul 22, 2015 | 04:26 PM
Maddshadez's Avatar
No warnings, I cut off the sensor, stripped an inch of the 2 wires bare, twisted them around each other, and taped them up, which prevents dash warning lights.
Had I not grounded the sensor they are still compatible with the R1 brakes, the pads are your standard pads, nothing special, and they have the U shaped hole for the sensor.
Old Jul 22, 2015 | 08:33 PM
psinsyd's Avatar
Beautiful, thanks man!
Pringleblue
Jan 12, 2021 11:42 PM
MrWhite
33
Oct 22, 2015 10:29 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
millertic
Sep 30, 2015 08:11 PM
