Out of no where my driver seat stopped moving. Moving seat Forward or back doesn't work nor does the tilt forward or back. The only seat function that works is the one that releases or adds pressure to the seat. I changed the module thinking that was the issue. I check the fuses they were all good. Could all of the under seat motors went bad at the same time? Any help appreciated.
karpe
04-24-2019 12:44 PM
Did you solve your problem? I have the exact same issue.
lotusespritse
04-24-2019 03:27 PM
Originally Posted by jahmezis45
(Post 2005865)
An old thread, but this guy needed to get out the voltmeter to check out what is getting power and what isn't. It isn't likely to have multiple motor failures at the same time, and a voltmeter would answer if they are bad motors or if they are not getting any juice.
I also really wonder what people mean when they say they checked the fuses? Did they really put a meter on them, or just look at them? Sometimes fuses go without looking bad.
karpe
05-31-2019 01:45 PM
I got this sorted. Had to take it to the shop, as I could not remove the seat. The switch pack was bad, luckily I found a replacement unit from eBay.
