Engine oil
When checking engine oil on instruments at my XF 5.0 it writes engine failure. Do you just renew the oil presure swich, or anything else ??
Get a code reader and see what the ECU says about "engine failure"
That sounds really bad. |
Engine oil
when testing with engine tester the message came out b100a and in an reference it said Number-plate- right sid fault. I knew that and had ignored it as an minor fault to be repaired next service. But anyway I fitted an new light and now I can measure the engine oil. Strange that these two faults is connected.
Originally Posted by Arne Riis
(Post 2026947)
