Feul rail hose size
Old Feb 22, 2025 | 10:06 AM
Isaac's Avatar
Default Feul rail hose size
2009 xf 4.2l non super charged. Just wondering what size the fuel hose is that goes in between the rails is? I had to cut mine to get a feul pressure gauge on her for testing as I couldn't manage to seperate the hose itself from rail.
Old Feb 23, 2025 | 02:29 PM
nickhand's Avatar
If/when you find the hose size and type, please post the results,
Old Feb 28, 2025 | 11:56 PM
Isaac's Avatar
between the rails is 5/16 fittings are barbed, the oem hose had a type.of plastic inside it, i was.unable to find one of simalier make so went with high pressure efi hose. Now for some reason thow it was tight fit but when i started it up i spraying out of the bank2 side, to stop this i had to use hose clamps, but seems to be holding up for now.
MSGGrunt
Jan 3, 2024 07:19 PM
michaem101
Apr 10, 2023 07:52 AM
BradsCat
Apr 30, 2021 09:07 PM
Johnken
Dec 30, 2018 03:50 PM
macdoesit
Nov 24, 2017 07:50 PM
