Fuse location
I know this is a rather dumb question, but does your XF have a camera above the license plate? It sounds like your car wasn't fitted with one, only parking sensors. If it was fitted with a camera and the camera isn't working when you put it in R, you would usually get a blue screen pop up. Very odd that it doesn't even pop up when in R if you do have a backup camera. The usual culprit is the wire that runs from the body of the car into the trunk lid. It's on the right corner when you open the trunk. If you pull that concertina rubber cover back, you would find the broken wire or wires right there. They bend each time you close the lid and opening and closing bends it back and forth and that usually breaks the wires. If this is the case, it's easy to splice them back together and wrap some conduit tape around them to avoid it happening again.
