Incomming call ring too loud
Old Jul 3, 2012 | 10:35 PM
Escolar's Avatar
Default Incomming call ring too loud
A couple of times I've had incomming calls when the ringer is so loud it's painful and my head hurts for like an hour afterward. Intermittent and rare. I'm sure the dealer will blame it on my Samsung Droid Charge smartphone. Anyone else experienced this? Anyone got the same phone and no issues?
Thx.
Old Jul 4, 2012 | 05:25 AM
Wife's Tech's Avatar
There should be an adjustment available in vehicle settings no?
Old Jul 4, 2012 | 07:05 AM
jaguny's Avatar
I believe you can use the steering wheel scroll button to increase and decrease volume when the call is in process to adjust volume. Probably can also do it from the screen menu also.
Old Jul 4, 2012 | 08:21 AM
jagular's Avatar
Phone volume may be triggered by a different setting from the stereo volume even though the stereo controls are used. Scroll through your settings on the touch screen and see if the phone volume is separate.
Old Jul 4, 2012 | 10:01 AM
arlingtonman's Avatar
Incoming call ring volume, navigation voice volume and one other thing (I forget what it is) can be adjusted through the interface in my '09 XF premium. I think it's either in communication or vehicle settings
Old Jul 4, 2012 | 01:41 PM
Escolar's Avatar
Thanks for the replies. I'm fully aware of these various sound settings. It rings comfortably most of the time, and occasionally blares like a wartime invasion. All that happens (if anything) between events, is that I might turn up the volume to better hear a call in progress, or perhaps tweak the volume when I'm in a call away from the car via my BT headset.
Old Jul 4, 2012 | 02:23 PM
jagular's Avatar
I think the system remembers the selected volume at the end of the call and assumes you like that level. I suspect you raise the volume during one call and then do not reduce it during that call. Then the next call rings at that higher volume you forgot to reduce.
Old Feb 18, 2025 | 02:44 PM
Kells's Avatar
Default Phone call volume
Thx.
in our jag we just turn down the volume on the radio and this turns down the volume on your phone.
Hope this helps 🙏
Old Feb 19, 2025 | 07:49 AM
clubairth1's Avatar
Community Influencer
Kells what car do you have?
Old Feb 20, 2025 | 04:40 PM
Kells's Avatar
Default Car make
We have an x type jaguar, bought last week.
2009 like brand new,well looked after.
I had to set up the clock, phone and sat-nav for my husband.
Hope you sorted it out.
Kells
Khello
Sep 4, 2024 08:25 AM
roman_mg
Feb 21, 2017 06:33 PM
oilstain
Jun 9, 2014 10:31 AM
Escolar
Apr 27, 2013 01:50 AM
gagets
May 8, 2011 04:35 PM
