Jaguar Fault Code B102B-67, U3002-81
Old Apr 20, 2021 | 09:04 PM
sufi_786's Avatar
Default Jaguar Fault Code B102B-67, U3002-81
Hi Team,
Recently I start getting fault code in my Jaguar XF 2013 model
It shows, B102B-67 and also U3002-81
I try to figure it out what are those faults code for and how to fix it.
Can anyone please help with that?
Old Apr 21, 2021 | 05:22 AM
fivel's Avatar
which module is giving you the U300281 DTC?
Old Apr 21, 2021 | 05:29 AM
sufi_786's Avatar
What I feel it's CJB fault, because when I press start button, the LED screen and aircon vents turns on, but the speedometer lights and engine doesn't turn on
its bit confusing for me, never faced this before
Old Apr 21, 2021 | 05:54 AM
fivel's Avatar
The DTC can be raised by different modules, if you can find which one it will help you pin point the failure.
The common theme is that there is a mismatching or corrupted VIN being seen on the CAN. This is can be because a module has been swapped out, there's noise/interference or fault on a CAN somewhere, a module has got corrupted and throwing out a garbage VIN or simply be a electrical/power glitch.
Have you checked the battery recently or had anything changed/fixed on the car?
Old Apr 21, 2021 | 05:59 AM
sufi_786's Avatar
Recently I change the timing belt kit. And after that this problem occurred and the installer told me that my BCM module has some problem. I am not a mechanical person neither my friend, all I got is these photos I have attached.
Just trying to figure it out how to fix it or else it has to go to Jaguar Dealership service centre and it's costly.
Old Apr 21, 2021 | 06:48 AM
fivel's Avatar
You've got some fun things going on there. Your gateway module is complaining that its software version is incompatible with the car or its configuration file is corrupted.
Your MOST network is complaining about something, I'm not sure what but -87 errors are often "lost comms" errors, might be related to the DTC on the GWM.
Your RSJB is reporting some sort of electrical problem with the right tail lamp.
The second screenshot seems to be showing a mismatching VIN problem. You would normally see that if you have changed a module out, but you don't say you've done that.
Try disconnecting the battery, charge it. reconnect it and see if that takes any gremlins away, it might just be lower on power and causing weird errors. I'd try that with the rear lights disconnected as there maybe a short or electrical error that is interfering with the electrical system.
Old Apr 21, 2021 | 05:52 PM
sufi_786's Avatar
Thanks for guiding me through, I can try that out and see.
It's very confusing for me regarding the VIN number has been wiped off. Never heard or saw that before.
Old Apr 22, 2021 | 03:56 AM
fivel's Avatar
I didn't mention that some of those codes might be historical so you should clear the DTCs when you've reconnected the battery before trying to start it.
These cars are notorious for random electrical glitches, especially when the battery is playing up; modules don't boot up properly and power dips cause them to do odd things that confuse the car. "replace the battery" is the Jaguar equivalent of "turn it off and back on again".
The VIN mismatch happens because some of the core modules, like the CJB, RSJB, ECU, RKE, etc are VIN encoded to stop you being able to steal or hotwire the car by injecting things onto the CAN to make it unlock/go. It also makes it very difficult to replace (or steal) those modules because used parts are encoded for their original car and won't work in another, new parts need the special tools/dealer software to programme them. The side effect of this is that any issue with one of these modules either not being able to communicate with the other modules or sending out garbled messages means the whole car stops working. It could be anything from a failed module, to a poor power or CAN connection that can cause this.
If changing out the battery doesn't work, then check CJB ground point and the connections to the CJB itself.
Old Mar 26, 2023 | 02:23 AM
XF_Graeme's Avatar
Hi Fivel, I have the same problem...
B102B-67
U3002-81
after a flat battery issue (car has now been sitting with dead battery for months)
I have a Xtool decoder but cant get far with that, about to purchase an SDD with Mangoose cable - hoping that will be the right tool to fix it, but...
please give your advice on the SDD IDS with Mangoose ...
Do you know the procedure to resolve this ??
Car is 01/2013 XF Jaguar Sedan 2.2lDiesel (in AUstralia)
Old Mar 26, 2023 | 10:01 AM
fivel's Avatar
tbh there wasn't a follow up to the thread so I'm not sure if we got to the bottom of what was causing the faults. A proper tool like SDD will help you a lot more than a OBD scan tool.
A dead battery for months may certainly upset it, but a bit of power, clear the DTC and resetting some modules might work. I had an issue with the door module after it had been standing with no power for a while, it wouldn't store the mirror positions or dip on reverse. Reprogramming it via SDD brough it back to life.
Nathanmatthew77
Sep 8, 2018 08:56 AM
Terry Keeling
Jun 30, 2017 10:48 AM
kbeachy
Feb 14, 2014 07:07 AM
jagman96
Aug 11, 2010 10:35 PM
