MY12 adding a Bluetooth module
Hi guys,
My friend just bought an XF MY12 with no bluetooth and he needs a handsfree. Is there a way to add it somehow? The car is a Premium Luxury 2.0 Turbo equipped with standard 10 speaker 400w sound system. I did some research and I found that central unit has to be replaced which is costly, but I also found Audio2Car Adapter 84442 + two essential harnesses for about 100 euro. Supposedly it attaches to the amplifier on the left side of the boot.. Will that work? Any help appreciated! Thanks! |
It should have Bluetooth for phone calls built in. If you want streaming audio which it doesn't do, either connect a 'Tune2Air' module (about $70) to the iPod connector in central arm rest if you have it and that will do steaming audio and control of tracks through steering wheel and track name display, or a usb BT streaming stick for nearly free which plugs into the usb in arm rest and streams audio but no controls
Depends a bit on which stereo system it has |
