Need Help
Old Apr 10, 2022 | 05:31 AM
LitBoi3200's Avatar
Default Need Help
Recently notices my rear differential gasket leaking and also a bit of light popping up that include, cats system fail, battery warning, tpms failiure. The car ran amazing but is turning into hell for me. Sorry if I’m being out of pocket but are there any Jaguar mechanics here in Colorado willing to help me get my XF supercharged back to shape
Old Apr 10, 2022 | 08:17 AM
VicVegas84's Avatar
Cats can get clogged up from running a rich condition (too much fuel). The rear diff gasket is probably pretty easy to replace but I have not done it personally.
Post the codes you're getting and any other symptoms. That will help.
Old Apr 10, 2022 | 10:45 PM
LitBoi3200's Avatar
Default Jag codes
Jag codes
P0620
P010B
P0174
B11DB
P0128
P050B
Old Apr 10, 2022 | 11:59 PM
litteredwithfaults's Avatar
with CATS he means the dynamic suspension not the catalytic converter.
Find a local independent mechanic specializing in european imports. Have them install a new battery, a fully charged high quality unit and use a scan tool to follow a replacement routine. This will take care of most of the errors. The diff seals last about 10 years on these, have them do all 3 before too much oil leaks out.
Once sorted you can decide if you still want a maintenance hog in your life or sell it on. All the other euro lux brands are the same if not worse.
jagxkrtoofast
Dec 9, 2022 12:56 PM
fredpribyl
XF (X260)
Jan 23, 2021 03:40 PM
loganjude
Diesel variants - All models
Jul 5, 2017 02:18 AM
Matthew Erich
Dec 18, 2016 12:17 PM
