Passenger side windows not working
Old Jun 24, 2024 | 09:44 AM
RobinL's Avatar
Default Passenger side windows not working
Hi,So suddenly my (right) side passenger window stopped working.All I heard was some whirring sound from the door.Changed the window regulator mechanism completely with motor.Did not change the sound and found that it was coming from the control module in the door.Replaced it with a new (second hand) unit, no noise anymore but no movement in front and rear passenger window.Before replacing, the rear window still worked.Tried to put the old one back in, no noise, no movement either.Put the "new" one back in.Checked the fuses in the footwell and luggage compartment, no relating fuse is burned.Also noticed the mirror controls dont work anymore.Clueless of what I could try next.Please help.
Old Jun 26, 2024 | 11:33 AM
sportbrake_phil's Avatar
Did you configure the "new" module with SDD?
Old Jun 26, 2024 | 12:19 PM
RobinL's Avatar
No, I will look into it how to do this.
But shouldn't the old module still make the sound like it did before replacing?
Old Jun 27, 2024 | 11:12 AM
I wouldn't have though the old module should make a noise in the first place, so maybe it won't get back into quite the same state now it's been powered off.
scottpeterd
May 28, 2022 10:45 PM
edreddy
Apr 20, 2022 05:19 PM
Hanso
May 6, 2017 09:56 AM
93leaper
XJ40 ( XJ81 )
Oct 20, 2007 07:26 PM
