problem with fluctuating revolutions XF 250 2.0T
Old Feb 27, 2025 | 04:46 PM
woytek81's Avatar
Default problem with fluctuating revolutions XF 250 2.0T
Hello everyone, thank you for accepting me into the group.
I wanted to show you a problem that occurred in my car.
The car is an Xf 250 2.0T. I recently replaced the timing chain, there were no problems before, but the car already has 145K miles, so I decided it was time. After the replacement, I noticed that when the car stops, the revolutions are uneven for a while and fluctuate. Once P0505 appeared (problem with idle speed regulation), after clearing the error, the revolutions continue to fluctuate. I read that it may be a charging problem, but I measured the batteries and the values ​​are OK, I noticed that when I stop and turn off the radio, ventilation and lights, the rpm stops fluctuating.
From the things I've already done.
I checked the air hoses and the vacuum pressure is ok.
Do you have any suggestions?
Old Feb 28, 2025 | 10:25 AM
Vasara's Avatar
Camshaft timing? (Not sure if the camshaft sprokets have timing adjustments though. I never changed chain on 2.0T)
CZIntercity
XF (X260)
Jun 17, 2023 02:04 PM
KKostas
Jan 25, 2023 06:18 AM
raymond 49
XF (X260)
Feb 5, 2018 04:53 PM
bluesman78
Aug 8, 2011 11:17 AM
