Problem with touch sensitive map light.
My overhead dome light, or "map light" comes on intermittently without touching it. Apparently this is a design issue and a know problem. Jaguar has a bulletin on it but not a recall. This bulletin requires the dealer to fix the issues by cleaning the inside contacts. While in warranty, I took my car in twice for this issue. The cleaning the internal parts only temporary fixes the issues. The issue is now back and I'm out of warranty. Unfortunately, the service manager at the dealer is unwilling to to replace the light, a $1,000 bill for parts and labor.
I feel this is unfair. I am not asking them a favor as in fixing a problem that I have incurred out of warranty. But to fix a problem that they failed to do from while I was in warranty. This is annoying. I do like the new Cadillac 2013 XTS. And before I play $1K on something like this I wound likely trade it in. But I do like my '09 SC and would probably prefer to keep it. Any suggestions? Thanks in advance for any helpful insight. |
They should fix the problem. It's because they refused to fix it, that's why the light is still broken. Speak to the manager there or Jaguar USA. If you have facebook, go on there start complaining till it's fixed.
In terms of trading the car in, i wouldn't' do it. You are avoiding a problem that will chase you regardless of what car you buy. I recommend buying extended warranty for your car. You can extended to 8 years and 100,000 miles through Jaguar. I believe it's about $3,500. Well worth it. |
I had the same issue. Dealership replaced the whole unit
i had the same issue, it was so annoying and kinda embarassing, it would turn on every time i hit a bump.
they had to replace the whole unit for me. |
The first has to be the bulletin which is clean and paste, if it occurs again, its replacement as you cannot claim for the same bulletin twice
Originally Posted by Brutal
(Post 638126)
Really? well I took it in twice under warranty. So it shoud've been replaced the 2nd time? |
I know this isn't what you want to hear but you could pull the bulb out for the time being. At least it won't be flickering on and off during the day.
I don't believe these lights are touch sensitive. All I have to do is wave a finger close to the light to turn it off and on. Don't have to touch it at all.
Originally Posted by thelegend
(Post 638239)
really? Well i took it in twice under warranty. So it shoud've been replaced the 2nd time?
Could this happen while the vehicle is parked overnight ? and deplete the battery.
no not really
so how would your average owner go about cleaning or replacing the item?
$1K to replace a light bulb issue....YIKES!
Open a case with jaguar. It was still under warranty when you brought it in initially not your fault they couldn't fix it properly. |
Full replacement is not a bulb it is the whole overhead console light assembly with all the other electronics in it. There is a repair kit out sence this thread back in 2012. I would try that first, its cheap and easy to do
Intermittent map/dome light
(Post 1720736)
Thx! |
(Post 1720736)
Thx! |
^^^find the bulletin to see what to do and you can order or pickup at a dealer. . Or get 3 little heat shrink sleeves to fit, dielectric grease and alcohol pads to clean and save the money on the kit. May not even need the grease anymore
Thanks!
| All times are GMT -5. The time now is 09:01 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
