Small clunk felt in gas pedal from 1st to 2nd gear??
Old Jun 10, 2021 | 09:21 AM
Wunderboy987's Avatar
Default Small clunk felt in gas pedal from 1st to 2nd gear??
Hello.
I have a 2011 XFR with 95k miles. Recently while shifting from first to second gear I can hear a faint clunk. also I can feel it in the gas pedal. It usually only happens on the very first shift from first to second gear. Although occasionally it will happen on the downshift from second to first gear, but when that happens it's much more aggressive. This is all while driving slow.
I guess I should have the trans and diff fluid changed. I don't think it's a transmission or engine mount?
Somewhere I rememeber reading that this transmission has a plastic piece that is prone to breaking. Not sure if this is related and I cant seem to find that post.
Any input is much appreciated. Thanks!!
Old Jun 12, 2021 | 10:39 AM
BritCars's Avatar
Are you sure it's not the ABS braking? It runs a self test the first time you get to something like 10-15 mph (maybe even below that). With a noticeable clunk through the pedals and car seat. Only the first time after starting the engine?
If not then I'd start with fluid changes.
Old Jun 12, 2021 | 10:54 AM
Thanks for the reply.
Yes it only happens during the very first shift.
I don't think it has to do the braking system. If I have it in manual mode it always happens at the exact same time as I shift from first to second gear. Weather it be 3 mph or 15mph. (Happens in automatic mode also)
Thanks for the help everyone.
Old Jun 12, 2021 | 01:18 PM
Oxidizer2k's Avatar
I would start with the fluid. I was having issues like that at 73k. A drain and fill fixed my issues and I’m at 75k now and plan on doing another drain and fill. Make sure you do your adaptation after changing the fluid.
Curless Auto
57
Dec 27, 2023 04:06 PM
x42bnx
Dec 23, 2015 07:45 PM
Robert Scott Neilly
Jul 30, 2011 12:00 PM
gbit
23
Mar 9, 2010 01:57 AM
