Spires stage 2 mufflers should I add an X pipe?
Old Feb 26, 2024 | 10:29 AM
gretle_2.0's Avatar
Default Spires stage 2 mufflers should I add an X pipe?
Hey guys I’ve had my spires stage 2 mufflers for awhile now and wanted to go with the stage 1 from spires to add on but I saw they stopped making exhausts. Does anyone recommend adding an X-pipe (Magnaflow type just like Big Will) and deleting the 2 resonators? Just wondering if anyone had the spires stage 2 exhaust setup and added a x pipe to see if they recommend it or not.
Much thanks!
Old Feb 26, 2024 | 07:00 PM
dennis black's Avatar
20 Year Member
putting a x pipes makes the sound nice and throaty by cancelling flow out ,you'll loose a few horsepower ,but to get a good sounding exhaust note its well worth it
Old Feb 26, 2024 | 07:25 PM
gretle_2.0's Avatar
yeah that’s what I was thinking and it would lose power? I was thinking of putting it right after the cats and heard from others that it increased the power, is that wrong?
Old Feb 26, 2024 | 08:07 PM
OzXFR's Avatar
You will NOT lose (note lose not loose!) any power by fitting an X-pipe to a 2010 XF SC, and you may in fact gain some power.
The X-pipe should replace the central muffler but not the resonators, leave the resonators in place or else you risk massive drone.
The factory XFR-S (550 PS vs 510 PS for the XFR) initially came with an X-pipe while the XFR did not, and the F-Type V8 has always had an X-pipe.
When I applied the XKR-S tune to my old 2010 XFR (XKR-S tune rather than XFR-S because Denso vs Bosch ECU but otherwise an identical tune) I discovered that I needed to fit an X-pipe or H-pipe (I went with an H-pipe) before the tune would stick.
Old Feb 29, 2024 | 07:55 PM
Jaaaggg's Avatar
This is terrible advice, x pipes are proven to increase hp and tq as they even out the exhaust pressure. All the 550 HP vehicles from JLR come with an x pipe from factory.
Old Mar 1, 2024 | 02:32 PM
20 Year Member
You are absolutely right I lost power low down but gained at the top end like I said a small amount that is not noticeable, but only a graph, at Janney racing dyno, ill see if I can find the graph ,that's why I said it's not noticeable but sounds great
Old Mar 2, 2024 | 08:37 AM
gretle_2.0's Avatar
Do you have a tune on yours?
Old Mar 2, 2024 | 09:14 AM
20 Year Member
Yes stage 2 and a transmission tune , I'll be putting the griptech upper pulley ,which is controversial whether it will make more power, so I'll have a video and dyno it at Janney racing to see what power gains it gets,and whether it's worth it, so you guys can decide, my lower crank pulley and remap made a huge difference, ,the transmission tune was the icing on the cake very reliable ,I've had on for a few years now
Old Mar 2, 2024 | 11:10 AM
clubairth1's Avatar
Community Influencer
Interesting! I don't think my XJR has an X pipe from the factory?
Old Mar 9, 2024 | 06:48 PM
Jssaab's Avatar
I have the Griptech pulley. I had a ton of belt slipping with the crank pulley. It definitley was needed for me at least
Old Mar 10, 2024 | 11:25 AM
20 Year Member
Nice to no I have the griptech pulley in the box just have to install it soon
asjdhsajhdfj
Nov 6, 2021 08:16 AM
Benson7
Mar 22, 2019 10:08 AM
Northern XF
Jul 30, 2017 09:03 AM
Evan Trinh
Feb 25, 2016 06:04 AM
bfsgross
34
Jun 29, 2010 02:07 PM
