Spongy brake pedal.
Old Feb 15, 2021 | 02:17 PM
Carlos Saez's Avatar
Originally Posted by Robinus
One thing I don't think you've said. How's it stopping ? Are the brakes working OK & you've just got a spongey feel at the pedal ?
It does stop fine but i gotta, press the pedal a bit more than normal, it's gets worse when the brakes get hot after driving a lot, yes it's spongy.
Old Feb 15, 2021 | 02:41 PM
User 42324's Avatar
I wouldn't have thought it would be braking properly if your brake pedal slowly pushes to the floor.. If this is happening & you can't find a leak the chances are good you've either got air in the system or a duff master cylinder. If you can't bleed any air out (or nothing changes after bleeding) then it's likely the master cylinder. It sounds like you're driving around with faulty brakes & if it is the master cylinder, at some point it's going to fail badly & you won't have any brakes (ask me how I know).
Old Feb 15, 2021 | 03:06 PM
I have suspected Master cylinder form the very beginning, maybe that's why it gets worse when hot, probably bypasses more fluid as it looses viscosity.
But i haven't been able to do any conclusive testing, with the car cold turned off without servo assistance, the pedal is hard and doesn't sink, so I can't really says 100% sure it's the MC. I have bleed it 2 times, no air comes out.
Anyway the car is 11 years old a New master cylinder won't hurt. But I'm not sure if it will cure the problem.
I don't drive the car everyday barely once a month, i use my wife's bmw, and won't be driving it untill I sort this out.
Old Feb 15, 2021 | 03:09 PM
Originally Posted by mghirsch
My 2011 called for DOT, low viscosity. Don't know if Mannol is LV or not, or if it would make difference.
It's LV , has same specs as the shell esl, so we can rule that out.
Old Feb 15, 2021 | 08:51 PM
Does anyone knows of there's an adjustable push rod in the servo,like the older cars, maybe that's bathe whole problem.
Old Feb 20, 2021 | 07:10 PM
arty914's Avatar
If the master cylinder is going bad, and you pump the pedal it should become firmer. If not your problem is else ware.
Old Feb 21, 2021 | 08:28 PM
Already ordered the MC, yes it does get firm when pumping.
I took the car out the other day, for some intense acceleration and very aggressive braking, the brakes feel very good after that, apparently it solved the problem , I'm not sure how, but the pedal feels great now.
So I'll keep the new MC i case the pedal starts acting up again.
Old Feb 21, 2021 | 10:53 PM
  #28
Oxidizer2k's Avatar
Wow. Glad it worked out.
Old Feb 23, 2021 | 07:32 PM
BritCars's Avatar
Glad it worked out.
Intense acceleration and aggressive braking with spongy brakes could easily have led to a different outcome..
mtotrainer
XJ XJ12 ( X305 )
Aug 9, 2022 04:16 AM
Civicalized
XJ40 ( XJ81 )
Jul 29, 2022 01:00 AM
Xdevo1973
XJ40 ( XJ81 )
Oct 14, 2017 12:15 AM
al_roethlisberger
Aug 20, 2015 06:18 AM
DB6
Jun 21, 2011 11:21 AM
