Towbar wiring sportbrake
Old Nov 5, 2023 | 02:00 PM
lotuscorty's Avatar
Default Towbar wiring sportbrake
Hey folks, just fitted a towbar to the 2013 Sportbrake. I bought a dedicated wiring kit and plugged it all in according to the instructions.
Nothing works.
Before I go back to the supplier about a faulty module, is anyone aware of this model needing to be coded by the dealer to allow the wiring to work?? I was of the understanding that lights would work and the coding would take car of parking sensors, camera, etc?
Any help greatly received. Thanks
Old Nov 6, 2023 | 06:08 AM
Noelmid's Avatar
Default No dealer coding needed
Hi,
I fitted a towbar to my 2012 XF Saloon and didn't need any coding. It all worked perfectly. And I don't think the Sportbrake would be any different.
Good luck.
Old Nov 6, 2023 | 06:43 AM
Robtrt8's Avatar
Need to probe the inputs. If nothing works I'd look at the ground (-) first. Also, have you plugged it into only one trailer? Might be the trailer.
Old Nov 6, 2023 | 07:11 AM
bydand's Avatar
Nothing works.
Removed the Tow bar from my XF 2013. 27Kg of steel being carried around which I don't use.
The tow bar manual is attached, if any help.
See page one!
When I scan for codes I get something Like Tow bar not found. Everything works so not too fussed.
File Type: pdf
Old Nov 6, 2023 | 04:58 PM
Robtrt8's Avatar
It makes sense that you’d have to code in a factory tow module but not an aftermarket one.
Old Nov 7, 2023 | 03:59 AM
lotuscorty's Avatar
All wiring is good, nothing at trailer socket, looks like something needs "turned on" in the car. Thanks
Arvis
Oct 3, 2023 10:05 AM
jc1kz
Apr 14, 2022 02:49 PM
smiffyg50skm
Jun 13, 2017 08:31 AM
usaf
Jan 21, 2017 09:01 AM
PhilipM
XK120 XK140 XK150
Aug 14, 2015 06:40 AM
