Now different unlocking behavior.
Old 10-08-2013, 08:37 PM
CP1's Avatar
CP1
CP1 is offline
Default Now different unlocking behavior.
Used to be when the car was locked I could walk up to it and just pull the handle and the car would unlock and the door would open.
Now, I have to pull the handle twice. The first time unlocks the car and the second opens the door. Not nice when it's raining.
What's up with that?
Old 10-09-2013, 12:53 AM
Per's Avatar
Per
Per is offline
Sounds strange to me, and not seen that described in the owner's manual. 1st try to double lock and leave for min 15 minutes, keeping the key fob well away from the car. If that does not change it try pulling the fuse for the keyless system for 10 secs.
Old 10-09-2013, 07:48 AM
Blackcoog's Avatar
Try a new battery in the fob or a different fob. Make sure the battery in the car is fully charged.
Old 10-09-2013, 05:36 PM
10 XF Premium's Avatar
My drivers door is starting to do it also. I liken it to a dirty lock actuator taking a bit too long to fully unlock the door and you have to double-pull the handle to open the door.
I am going to have it looked at the next service.
Old 10-09-2013, 05:43 PM
DPK's Avatar
DPK
DPK is offline
Sounds like a weak battery in your Fob....Do like Blackcoog suggested..
Old 10-09-2013, 08:31 PM
UltBlkXF's Avatar
mine was doing that too and then the low battery light came on for the key fob. Got the battery fob changed and it is working right now
Old 10-10-2013, 08:28 PM
CP1's Avatar
CP1
CP1 is offline
Just changed the battery in the fob. No change in behavior.
Old 10-11-2013, 07:51 AM
Blackcoog's Avatar
Try topping the car battery off if you have a charger. It seems like a weak battery can be the cause for a lot of random electrical issues.
philwarner
28
07-11-2017 10:21 AM
jluckcuck
11-06-2015 07:49 AM
Bigvettefreak
09-28-2015 03:03 AM
jessejamestw23
09-26-2015 03:57 PM
SeanU
09-18-2015 03:38 AM
Quick Reply: Now different unlocking behavior.
