Won't start 2015 Jaguar XF 2.0
Old Feb 5, 2025 | 05:06 PM
Dakota1's Avatar
Default Won't start 2015 Jaguar XF 2.0
2015 Jaguar xf 2.0 4cylinder gas pulling codes p2542 and u0010then u0155 and u0142we have replaced:1. high pressure fuel line2. high pressure sensor3. high pressure fuel pump4. ecm replaced and reprogrammed5. low pressure fuel pump6. crank shaft sensor7. oil level sensor8. spark plugs9. keys replaced and programed10. Fuel filter11. Injectors12. Battery13. All relay replaced,under hood and fuse box??can anyone provide any information and or advice we can not get my wifes car going??-vehicle acts like it wants to but just wont.-Since battery was unconnected we have had the ECM cloned and installed with all codes cleared except oil level sensor we replaced that that.-Then the fuel sender A and B code show up so then we replaced the fuel sending unit-The only codes we have showing now areB11db, u0142, u0010, u0422, u0155 u0140, c1b00, u101b, b1087,u0103, u3000 ,p2542-We have cleared the codes and now we are only showing codes for body control module and low pressure fuel system sensor circuit high
Old Feb 5, 2025 | 10:08 PM
Isaac's Avatar
That sounds like what mine is currently doing, changed the coolant temp sensor then all hell broke loose were it would crank but just not start, I had one code that said dynamic control module no communication, ended up putting old sensor back in and left the negative lead off for 20 minutes, tur s over now but is plagued with all kinds of codes.
Old Feb 5, 2025 | 11:50 PM
Dakota1's Avatar
Oh dang so you still haven't got it running yet either... Yeah we are three months in on this thing
2011_XF_5.0
Mar 10, 2022 09:28 AM
Stuart Satter
Dec 31, 2020 02:19 PM
DMBJag
Dec 6, 2019 03:00 PM
darrellleece
Aug 16, 2017 07:22 AM
