Won't start after diesel filter change
Old Oct 22, 2017 | 03:51 AM
jseaman's Avatar
Default Won't start after diesel filter change
Edit: All sorted, fill your fuel filter before firing it up if you change one! I had to do it by hand and pump through the lines
Old Oct 24, 2017 | 01:30 AM
Mr Sharky's Avatar
Any air anywhere in the filter or the lines will create an air lock that will prevent the car from starting. You can use a short squirt of starting fluid to help it start. But use it very sparingly because it can cause damage.
