Wood Veneer cracked
2010 XF Supercharged. The veneer on the wood trim that sits behind the parking brake release center console area is starting to crack. Is there a replacement available, or would doing a carbon fiber wrap be more viable? Thank you.
Online junkyard is your best bet. Maybe eBay. Anything new from a parts reseller will probably be eye-watering in cost. Make sure you get a match.
And then find a way to keep your car out of the sun when parked. I use a Lanmodo. (you can google it) |
mine is cracked as well, a lot of them ive seen are. easily crackable
One thing I discovered on the X308 is that each interior was a matched set. Not sure if its the same in the X250, but I developed a crack in the driver door panel escutcheon on the X308 and went to a local Jaguar salvage where they had dozens of them hung on a stringer like fish (not the best way to store them, but I guess it was efficient space-savings wise). They were all slightly different shades and some VERY different patterns. I picked one that was as close as I could find. A passenger in the car probably wouldn't notice, but I can sure tell. Had to learn to just live with it. To have a match I would have had to replace ALL the veneer with a whole set from another X308 and I didn't want to spend the money. I'll be curious how successful you are at finding a matching replacement part for the X250.
Originally Posted by pdupler
(Post 1964384)
ive noticed the X250 is mismatched as well
Originally Posted by carzaddict
(Post 1964506)
It's up to you but the wood does not crack. What you are seeing is a clear coat crack.
As was posted Jaguar uses matched veneers so tough to match. I found out when the dealer did a repair on a previous Jaguar that they use Madera Concepts. Wood Repair I talked to them about matching the veneer and was told they refinish the original panels. The wood is a very thin skin and very flexible but weak in strength. You could send them a picture to get a quote but I can vouch for the quality of their repairs and I never had another crack after the repair either. . . . |
