XF - Rear Parking Sensor Replacement
Hi Guys,
I have a rear parking sensor issue. I know which sensor needs to be replaced and I have one on order. Do i need to remove the rear bumper? or can I just remove the plastic trim around the bottom of the bumper and then reach up to the sensor? I have seen many useful tips on here regarding the bayonet fitting of the sensor and how to remove and replace but getting access to the sensor will be my main obstacle. Many Thanks, Jim. |
Any solution?
I got similar situation, one of mu sensor just fell inside. Need access to replace reqr sensor in position. Just wondering if I can get acees with only removing the diffuser (plastic bit)?
Originally Posted by MKJim
(Post 1873653)
Hi Guys,
Which sensor
I have an XF with the dreaded no camera or sensors (after 2-3 seconds of activation) together with the contact your dealer message. From the forum it would appear the fault could be a faulty sensor (I have replaced harness in boot lid), but how can I determine which one as they are inoperable?
