xf reversing camera
does 2013 xf jaguar 2.2d business have a fuse for reversing camera
If your camera has stopped working then the most likely culprit is a break in the wiring harness that runs through the rubber bellows between the boot lid and the body of the car, it's a common enough fault. The harness bends each time you open & close the boot lid, eventually some wires break.
Tomlark
Thanks Cambo will have a look let you know
Wiring harness develops a crack and lets water in which destroys the camera. Very common problem. Does the inside of your camera lens look cloudy or have massive condensation? this happened to me. Camera had to be replaced. |
Thanks guys for reply turns out camera wires broken in loom under rubber between boot and lid. Managed to solder wires camera working perfectly.
