XFR Charge pump Change/Upgrade
If I'm quiet, I'm up to something..LOL
Well after seeing the Russians do this mod and given the fact Higgins has 65k on him, I decided its now a good time to do this pump change on my terms rather than on its terms. Plus it was time for my yearly coolant change, and my oil change (Gonna be doing changing the oil every 3 to 4k mi. and the filter every other oil change from now on, with Wal Mart Synthetic..lol let the comments begin!) Tools, Small size torx sockets, electrical wire prep tools, nippers, spring hose clamp pliers, coolant. ETC.. About a days work. Not a hard job, just involved and a bit messy. Removing and installing that front splash shield was the cusser! https://cimg5.ibsrv.net/gimg/www.jag...c0d3f97019.jpg Bosch 010 Pump, bought off Ebay for $115. Its basically the factory M-B AMG replacement pump used on the M113K 5.5L supercharged engine https://cimg6.ibsrv.net/gimg/www.jag...fe2678ca5d.jpg The M-B connector.On the Bosch pump the + and- leads are marked, the pos blade needs to be connected to the cars wire with red stripe. https://cimg7.ibsrv.net/gimg/www.jag...fe6ff11180.jpg Connector and wire PN. https://cimg9.ibsrv.net/gimg/www.jag...25c1898161.jpg Old pump next to the new pump, Old pump removal is fairly easy. 1 8mm bolt on the top, remove 2 hoses. Pump electrical wire built up too. all of the old pumps rubber will transfer over to the new pump. be sure to check the clock position of all the rubber hoses and mounts on the old pump for the move to the new pump. https://cimg9.ibsrv.net/gimg/www.jag...b2c7bb8484.jpg This is the pumps lower rubber suspension, I had too trim with nippers to fit it over the hose and on the new pump. https://cimg1.ibsrv.net/gimg/www.jag...833dc25e95.jpg This is the Gates heat shrink hose clamp I used to give me clearance to use the old pumps lower rubber suspension. I've never had one leak, they re tighten each time they heat up and can be trimmed or cut with a soldering iron, to fit in weird, tight places or around odd shapes. https://cimg6.ibsrv.net/gimg/www.jag...43ffa7f6bc.jpg New pump ready for install next to new pump. Be sure and bucket prime the new pump right before you install it. https://cimg8.ibsrv.net/gimg/www.jag...91933d574d.jpg New pump. https://cimg5.ibsrv.net/gimg/www.jag...5140753702.jpg New pump in car. https://cimg7.ibsrv.net/gimg/www.jag...a9a3a191a6.jpg New pump in car. |
Thanks for the info. I've never seen that powergrip clamp before, but it's a perfect solution for my coolant overflow hose. Thanks!
Originally Posted by n8ertot
(Post 1340246)
Tried searching but couldn't find an answer... what is this for? Is this a preventative fix to the coolant pump failure that is common on the 5L supercharged V8s?
Originally Posted by texevora
(Post 1340288)
(Post 1340288)
Originally Posted by Bigg Will
(Post 1340281)
I've been using them for years and have NEVER had one leak, and unlike screw clamps, the pressure is equal all the way around the clamp. The only bad thing is you have to cut it off (I melt them off with a soldering iron).
https://cimg1.ibsrv.net/gimg/www.jag...28525c29a7.jpg |
(Post 1340340)
Pretty cool and looks way better than what the previous owner did. I assume you just use a lighter or a torch?
https://cimg1.ibsrv.net/gimg/www.jag...28525c29a7.jpg https://cimg6.ibsrv.net/gimg/www.jag...a34f95c80f.jpg Used them on all my LS6 hoses. ITS AN LS6, a manual LS1 TB had to be used as the LS6 only used drive by wire. https://cimg1.ibsrv.net/gimg/www.jag...67accdf504.jpg Gates changed the lettering from green to white. |
(Post 1340731)
I actually use a heat gun
What about any performance improvement?
(Post 1340736)
Interesting. I would have thought that if a heat gun would work on it, the temp of a coolant hose would be too much for it to remain stable. That would be really easy then.
Originally Posted by tbird6
(Post 1341038)
Interesting. We don't have a high flow pump for the STR and I have replaced my stock one in the past because it failed. Really did not notice much change.
When it's summer here it's always into heat soak! . . . |
(Post 1341799)
Since you run yours at the track. Did you gain anything with the change?
I never ran it at the track with the old pump fitted so I can't give you the answer you're looking for.
Thanks for this writeup OP, got all the parts I need and will be doing this on my 2010 XKR later this week.
Also, are the gates hose clamps really necessary? Mine seems like the factory clamps will work just fine
Originally Posted by bigdhenderson
(Post 1384876)
Hey Bigg Will , Guys ...can you provide the part number this? Want to make sure I get the correct pump. I have 50 k so in the spring I want to do water pump as well .THANKS .
