XJ ( X351 ) 2009 - 2019
1646, 02 chip, misfires 1 through 7
Old 06-20-2017, 05:24 PM
tilbury's Avatar
Default 1646, 02 chip, misfires 1 through 7
I have been chasing down faults all week and everyone I fix I get 2 more. I had lean bank errors and found a bad hose connection just past the Maf sensor then I had a 0333 knock sensor error. I removed the sensors and couldn't see how they could go bad so I cleaned up the base for a better electrical contact and that seems to have solved that issue. I do have a new knock sensor waiting for me to pick up tomorrow. Now I am getting engine missfires from all but number 8 cyl. and it feels like they are all missing. I still get a 1646 linear o2 chip bank 1 fault , a 1313 cat damage fault and a 1316 missfire exceeds fault. Where is the o2 sensor bank 1, do I get it from the top or bottom of the car? Is it the first or second sensor?Great car but these little issues are getting me down.
Old 06-21-2017, 12:00 PM
JagV8's Avatar
Received 4,483 Likes on 3,901 Posts
All else fails you could
add your car details!
download free workshop manual and look those things up
read what others did
Old 06-22-2017, 07:45 AM
tilbury's Avatar
I have read all the posts and have found usefull information. I did swap the wires around on the o2 sensor and the fault moved to the other bank. I friend lent me an o2 sensor but it still shows a fault. I will install the knock sensor today along with new plugs. If in doubt start fresh and get rid of as many possibilities as possible.
. I have a 2000 xj8 vandenplas. 320,000 Km. Love the car but it is starting to show it's age. Did a 5000 km road trip last summer with barely a burp out of her. Rust is getting bad so I think I will start searching for another.
Old 06-22-2017, 09:54 AM
tilbury's Avatar
I downloaded the repair manual and installed the new spark plugs. The engine started and ran nice for a minute then went back to hesitation and stuttering. I will try new coils and see if that helps. Any more ideas?
Old 06-22-2017, 03:07 PM
clubairth1's Avatar
Received 2,217 Likes on 1,754 Posts
Read the codes. I don't see how you can do it any other way?
Are you getting less of them?
Old 06-23-2017, 08:18 AM
tilbury's Avatar
I keep reading codes and they keep changing. I test drive the car and all is well and the next time more codes come up.
Old 06-23-2017, 10:50 AM
JagV8's Avatar
Read the documentation and see why (hint: 2 trip).
At least fix the ones you keep getting but do see my 1st reply.
Old 06-23-2017, 04:33 PM
Stuart S's Avatar
Received 6,136 Likes on 3,382 Posts
tilbury,
Your Public Profile shows that your have a 2000 Jaguar XJ8 VP. This is the X351 Forum, for the current model XJ. Are you in the correct Forum? Or is your Public Profile wrong?
+1 on what JagV8 said: "add your car details!" Use an automatic signature with your details for all your posts.
Stuart
Old 06-24-2017, 07:44 AM
tilbury's Avatar
Post moved and signature added. Thanks for the heads up.
