2011 XJL - Rear Sun Screen
My rear sun screen does not work on my newly purchased 2011 XJL with 39k miles. I hear nothing when I press the button. I can lift the screen partially but that did not do anything. Can someone tell me where to look for the fuse as I want to check the fuse out. I noticed when I took delivery of the car, the battery had been changed with a sticker of 11/17, so I assume the battery has been replaced. Any help with my problem would be appreciated.
John |
Theres a fusebox under the hood, on the right hand side. There's also one in the trunk/boot on the right hand side covered by a small removable panel.
According to the owners manual sunblind is fuse F21 a green 30 amp in the trunk fuse box. If you do not have the owners manual it can be downloaded from the forum.
Thank you for locating the fuse. I will check to se if the fuse is blown. |
Originally Posted by dmchao
(Post 2001941)
