Can early MY supercharged cars be ‘chipped”?
i own two X300s and usually lurk over there. But I am thinking of changing to an early model X351. I want a spuercharged 5 litre. There some 370bhp cars here in NZ , and one Spiersports (2010).
Can these earlier cars be chipped? I know the current XJR has 575bhp..
thanks
thanks
Received 3,824 Likes
AL, sure you can chip them. I seem to recall that there are some chips out there that can be had at Mina Galleries (maybe only for the supercharged versions?). Even if there is no chip that you can buy, a good dyno shop should be able to tweak the programming a little more to gain you a fair number of horsepower. The factory tune is very limiting and is based around being as powerful as possible while also not making too much noise or whatnot. You take out that bit of conservatism and you cna free up some horsepower. But, before you do that, I would investigate if there are any modifications that can be done to the intake or the exhaust to ease any restrictions there. That way, when you use the shop, they will be able to maximize everything. I seem to recall though that the intake is definitely not a restriction and the exhaust offers very little resistance and not much can be gained. I am sure stepping up to a say a 50 or 40 series muffler will help some. Probably gain more by going with a properly built 45 degree crossover exhaust system. keep in mind that were you put the 45 degree crossover will affect if you are getting high end horsepower or more low end torque. it is all a function of the length of the tubing between the heads and the x-pipe. If you understand 1/4 wave tuning, then you can figure out the RPM that you are going to get the most gain.
AL NZ (09-02-2018)
AL NZ (09-02-2018)
VelocityAP has a pulley and tune kit for something like a grand. The hypothesis is that these motors are capable of much more than they are tuned for, and that all 3 varieties are capable of 600 hp with a tune and pulley. I was leaning that way on my 12 XJ Supercharged, when my CPO was through, but am now apprehensive after the horror stories of reliability issues and huge repair costs. Others in this group have used this source with I believe good results. One comment I have heard is that Traction Control almost defeats a hot tune, unless you tune off. Then, when you turn it off, the car becomes a handful.
AL NZ (09-02-2018)
Before you get into tuning, please make sure you understand the downsides: https://www.jaguarforums.com/forum/f...tuning-206030/
Hi.Good to see another kiwi on the Forum.I had an early 5 litre aspirated.Achip will give at best another 20kw(303kw like the mustang.)I loved mine which had quite enough to get axle tramp if I had the red mist on. It was also very economical for such a car (around12.5 overall in Auckland).
There have been a few XJR and Beachams has had a few.These can be chipped up from the original (375 if I recall to over 400) without getting excited with the pulleys or overboost.
I now have a 2015 3l s/c which I had tweeked on purchase from 250 to 280( the s spec). I thus suspect if you bought an older xjr you could get it tweeked on the standard Jaguar ecu upgrades. It only involves plugging it into thecomputer and I got mine as part of the deal.
However I reckon you dont need the godzilla power in NZ. I would strongly recommend looking for a v8 with active cruise and blindspot. There were a few around but they are rare. The cars we get In nz are all very different and finding one with nav harddrive acc and blinspot would be something.
good luck
good luck
