Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XJ ( X351 ) (https://www.jaguarforums.com/forum/xj-x351-53/)
-   -   Change between F and C on Temp Display (https://www.jaguarforums.com/forum/xj-x351-53/change-between-f-c-temp-display-61104/)
JimmyJag Sep 21, 2011 09:17 PM
Ok, for some reason my 11 XJ is now showing C on the temp displays instead of F. Page 60 of the manual #13 (Settings - Heating and Ventilation)) says "Select to alter the sensitivity of the air quality sensor, or to select F or C as a default temperature unit."
My XJ only shows the air quality sensor adjustment slider under settings. There is nothing about changing the temp unit at all.
Is there some kind of hidden button combination I did to make this change?
Help..
JimmyJag Sep 21, 2011 09:40 PM
Looked a little futher and found the ability to change it in the main display settings using the steering wheel controls.
Someones been playing...
ExpatJag Sep 22, 2011 01:52 AM
Yeah I was going to say I think the menu to change that is on the steering wheel.
Bill Rod Jan 16, 2023 11:45 AM
So where on the steering wheel is the utton to change from C to F on my Jaguar XJ? Thanks, BILL
12jagmark Jan 16, 2023 03:23 PM
There isn't a utton. Look in your owners manual & it'll guide you on how you can navigate the settings from your steering wheel controls..
clubairth1 Oct 14, 2023 10:08 AM
As always it's dead simple if you can find the instructions! Which are in the owners manual.
First using the steering wheel buttons. Push OK on the right side of the steering wheel.
This brings up the main menu below.
https://cimg4.ibsrv.net/gimg/www.jag...7abd8fa6ce.jpg
Now arrow down and select Display Settings.
Which brings up this screen.
https://cimg5.ibsrv.net/gimg/www.jag...2ab3cab5f5.jpg
Arrow down and select Temperature.
Which brings this screen up.
https://cimg2.ibsrv.net/gimg/www.jag...2981436ed6.jpg
Now you can select C or F for temperature units.
You can also change from KPH to MPH and back too from the display settings button.
Arrow down and select the units option.
https://cimg7.ibsrv.net/gimg/www.jag...7d89982fbe.jpg
Which brings up this screen and you can select KPH or MPH.
https://cimg0.ibsrv.net/gimg/www.jag...b8ced7b53a.jpg
© 2026 MH Sub I, LLC dba Internet Brands
