engine coolant for 2011 jaguar xjl
where can I get Orange coolant for my 2011 jaguar xjl
Hi ysivakumar2,
Welcome to the Jaguar Forums! It's great to have you with us. I have moved your post from the thread for the X308 to the forum for the X351, which is the Jaguar factory project code for your 2011 XJL. You can view the Owner's Handbook for your car at the Jaguar ToPIX website: https://topix.jaguar.jlrext.com/topi...8&groupId=1655 According to the handbook, the correct coolant for your Jag is Extended Life coolant colored orange that meets [Ford] standard WSS M97B44. The most common coolant that meets this standard is Dex-Cool, which is manufactured by several companies including Texaco/Havoline, Prestone, Peak and Valvoline/Zerex. It is available at all auto parts stores, Walmart, and many gasoline stations. Note that Dex-Cool is an Organic Acid Technology (OAT) coolant based on propylene glycol and should never be mixed with any other type of coolant, whether Inorganic Acid Technology (IAT, the conventional green ethylene glycol type), or Hybrid Organic Acid Technology (HOAT) coolant (which is typically dyed yellow but may also be dyed orange, green, blue, pink, red, etc.). Please visit the New Member Area - Intro a MUST and post a required introduction so we can learn something about you and your Jaguar and give you a proper welcome. Cheers, Don |
Originally Posted by Don B
(Post 1792719)
Hi ysivakumar2,
Bri's Jag, if you are going to switch to the green coolant (this is what I am running in my car), you just need to fill and drain the coolant system with some distilled water to get rid of any remaining orange coolant. After you do the fill and drain, then you can add in the green coolant to the proper level. Please note that I stated distilled water. Tap water and/or purified water has impurities in it that can have negative effects on the aluminum cooling cores. Kinda like if you get the concentrated coolant and then mix it yourself, you want to mix it with distilled water. Wlil using tap/purified water result in short term failure, by no means. But, in the long term failure prevention, using tap and/or purified water is going to allow the radiator to corrode faster, leading to a shorter life. Are we talking years shorter, depends on the amount of impurities in the water. So, hard to say what effects it may have. So, always best to use distilled.
Now, with this being said, if you are in a part of town that you shouldn't be, you need to add something to your engine to get yourself out of danger, then by all means use tap water to fill the coolant system. Just drain and refill with the proper stuff in the near future. |
Originally Posted by Bri's Jag
(Post 2153781)
Hello I've got the 2011 XJL 5.0 and just want to be sure of the coolant type a lot of this stuff gets confusing so if I just get the GM orange Dex-Cool it should work correct? Basically if it's green it won't work and if it's orange it will work correct?
Check your Owner's Manual, but Bri's Jag was most likely originally equipped with orange Organic Acid Technology (OAT) Extended Life coolant. The most commonly available version is Prestone GM Dex-Cool. Manufacturers advise against mixing OAT coolants with IAT (Inorganic Acid Technology such as conventional green ethylene glycol) or HOAT (Hybrid Organic Acid Technology) coolants. Dex-Cool is inexpensive and widely available and contains corrosion inhibitors that are supposed to last longer than those in the old green IAT type. I buy my Dex-Cool at Walmart in the concentrated form and mix it 50/50 with distilled water, which I also buy at Walmart. Cheers, Don |
Just use Dex-Cool it's cheap, it's available and it's the right stuff.
Can't get any easier than that! . . . |
Ok Great thanks Don it's appreciated. I'm always in Wallmart and see the Prestone GM Orange Dexcool and am glad that will work. I've got 70K miles on my '11 XJL and probably the original factory fill so I'm gonna flush and refill with all new stuff 50/50.. With these cars I just want to make sure its not some special Jag coolant only available at the dealership or high atop some mountain in the Swiss Alps:icon_badrazz:
Thanks yes I hear to never mix green with the orange and always mix distilled, can clog radiators and heater cores. My car already has the orange so will definitely stick with that verses draining and adding all new green.. Appreciate it
Good rule of thumb never mix Oat with Hoat lol.
I thought everyone was using some "professional" antifreeze that is used by the Jaguar dealerships...?
Forgot what it is called... |
Ripoff orange!!
(Post 2153845)
(Post 2153837)
Hi Bri's Jag,
Bri's Jag, the line that runs to the back of the overflow tank is that high point vent. The Jag vents itself. With that being said, you may want to let the engine idle for a few minutes just to let it push coolant to all the necessary places and get the air out. After the few minutes, rev the engine a few times to help change the pressure in the coolant system from the water pump changing speeds and you should be golden. Big thing is to let the engine come up in temp, then you shut it off and rest the cap on top of the overflow bottle. You then let the engine cool (cap still not tightened down) and add any fluid that might be needed to restore the level to between the min and max indicators. You can then put on the cap. Putting the cap on with the engine hot can cause the engine to boil the coolant easier because the coolant is running at a lower pressure than it should be.
Dex Cool in the Jaguar XJ?
None of you use the JLR coolant, or Pentosin SF? Dex Cool is notorious with the aluminum GM engines such as the North Star. Even GM adds anti-corrosion additive when using it, from the factory. |
Originally Posted by 12jagmark
(Post 2154293)
None of you use the JLR coolant, or Pentosin SF? Dex Cool is notorious with the aluminum GM engines such as the North Star. Even GM adds anti-corrosion additive when using it, from the factory. Jaguar DJLM 20972 coolant is the same coolant as Ford Motorcraft Orange (WSS M97B44). To confirm this, just check the Jaguar Vehicle Specification Booklet. Motorcraft Orange is an OAT antifreeze compatible with Dex-Cool, and vice versa. According to documentation from Havoline, the original manufacturer of Dex-Cool, it meets these specifications: • ASTM D3306 • Ford WSS-M97B44-D • GM 6277 • M-B 325.3 • VW TL 774F Pentofrost SF is an OAT coolant also said to meet Ford WSS-M97B44-D, but stores in our area only stock it in 1.5 liter bottles and it is significantly more expensive than Dex-Cool. Dex-Cool has been controversial with GM owners and mechanics, but a great deal of the controversy seems to be anecdotal and lacking in scientific explantion. Dex-Cool reportedly interacted with certain types of gaskets early on, it is known to interact with Nylon 66, and it does not protect metal water pump impellers from electrolysis or cavitation erosion (thus the change to plastic impellers). Beyond those known issues, it seems to have been blamed for all manner of ills that could just as easily be due to owners not changing the coolant as often as specified, or engines running low on coolant for extended periods, or owners or technicians topping up with conventional green ethylene glycol (IAT), which is incompatible with OAT coolants and can form a gel that clogs heater cores and radiators. Dex-Cool contains corrosion inhibitors as part of its basic formula, so I would be interested in hearing more about the "anti-corrosion additive" GM adds to Dex-Cool at the factory. Except for problems with early Nylon 66 water pump impellers, it doesn't seem like we've had a lot of pattern failures with Jaguars that would suggest issues with the coolant. Cheers, Don |
Originally Posted by Thermo
(Post 2154221)
Hello Don. We've had my wife's 1997 Oldsmobile Aurora for 20 years now. It has an aluminum block & heads, which are well known to have problems with coolant leaks at the head gaskets to blow out, ultimately destroying the engine. This is eerily similar to what I hear from fellow Range Rover forum members (my 2012 Range Rover has the same engine as my wife's 2012 XJ) describe happens if the JLR is not immediately shut-off when it begins to overheat.
But back to the Dex-cool. I also have the authentic GM Shop Manuals for the '97 Aurora (also covers Buick Riviera) and have taken a few pics directly from there to provide. https://cimg9.ibsrv.net/gimg/www.jag...3a690c28f4.jpg https://cimg1.ibsrv.net/gimg/www.jag...52c1adb287.jpg Note that it says that Dex Cool is design and made to last 150,000 miles. https://cimg2.ibsrv.net/gimg/www.jag...7de5532650.jpg
(Post 2154350)
Note that it states that major engine damage can cause major engine damage. And from experiencing a blown head gasket that failed where the coolant passage breached in the Aurora, I can attest to that, EXCEPT that the prescribed GM anti-corrosion pellets WERE used with coolant refresh. STILL - these otherwise legendary North Star GM engines with Dex Cool were notorious for limited life, primarily due to coolant/aluminum corrosion that ultimately leads to irreparable failure of the threads where the head bolts thread into the block. There are some attempts at repairing/rebuilding them with stubs, helicoils, keenserts and the like, but not many long-term success stories. This sounds similar to what happens to a Jag aluminum engine if it overheats - blown engine & prescription to replace the entire engine because the block is shot sort of thing. Granted, I hear this more often on the Range Rover forum, but same engine.
(Post 2154350)
Don |
(Post 2154350)
Coolants, hydraulic fluids and other fluids can get corrosive and dirty over time and use, it's just not commonly thought of like engine oil is. Transmission fluids are also often neglected. And these are great vehicles, not to be taken care of. But I've never been a fan of aluminum blocks or heads. |
(Post 2154477)
But back to the Dex-cool. I also have the authentic GM Shop Manuals for the '97 Aurora (also covers Buick Riviera) and have taken a few pics directly from there to provide. https://cimg9.ibsrv.net/gimg/www.jag...3a690c28f4.jpg https://cimg1.ibsrv.net/gimg/www.jag...52c1adb287.jpg Note that it says that Dex Cool is design and made to last 150,000 miles. https://cimg2.ibsrv.net/gimg/www.jag...7de5532650.jpg https://cimg4.ibsrv.net/gimg/www.jag...99f4b8852c.jpg Note that it states that major engine damage can cause major engine damage. And from experiencing a blown head gasket that failed where the coolant passage breached in the Aurora, I can attest to that, EXCEPT that the prescribed GM anti-corrosion pellets WERE used with coolant refresh. STILL - these otherwise legendary North Star GM engines with Dex Cool were notorious for limited life, primarily due to coolant/aluminum corrosion that ultimately leads to irreparable failure of the threads where the head bolts thread into the block. There are some attempts at repairing/rebuilding them with stubs, helicoils, keenserts and the like, but not many long-term success stories. This sounds similar to what happens to a Jag aluminum engine if it overheats - blown engine & prescription to replace the entire engine because the block is shot sort of thing. Granted, I hear this more often on the Range Rover forum, but same engine. This is VERY good info, I haven't heard that it's more reactive with certain types of gasket material. Thanks! |
