Flashing Lights
I noticed on some of the older models this is a problem. I have a 2014 XJL LB-Rear WD. It has done this twice. Is this a warranty covered problem?
Anytime I see flashing lights there is usually a Policeman close by. I wish a warranty would cover them.
In your case I guess maybe you should say if you have a warranty and explain what's flashing? |
Flashing lights
:) My flashing is my dashboard, all the warnings flash, the infotainment stops and has to find a signal again. The car doesn't cut off it pauses at that moment.
It should be covered if your 2014 is still under the original Jaguar new car warranty or Jaguar Select Certified Pre Owned warranty.
