New 2016 SC engine in a 2011 Problems
Hello all.
As some of you know I recently bought a 2011 SC at auction with a major engine problem for 18k in Beautiful condition inside and out minus the motor. My mechanic convinced me it would be much better to go with a new motor rather than machine a head, and replace all the timing components as he has a great hookup with LKQ and was able to find me a 2016 5.0SC aj133 for 9k delivered. The craziest part was that the motor was pulled from a car that had been dropped in dealer transport and only had 4 miles. not a typo 4 miles!
Basically spend 12 total installed for a new motor, or spend 6k plus repairing the problems in the 2011. So I opted for the 2016 motor with 4 miles.
I had read on here about the electronics switch between denso and bosh in 2013, and even asked my mechanic about it and he was certain he could make it all work. Well yesterday I stopped in and he informed me that they were able to swap all the sensors, flywheel, mounts, and whatnot from my old motor to the new, and everything was fine....
EXCEPT THE SUPERCHARGER!!!!!! he showed me how the new SC had an electronic control instead of a vaccume line. SO here we are. new motor in the car, and a brand new shiny supercharger that he doesn't think he will be able to use. he wants to put my 63,000 mile SC on the new motor, but said my SC has seen better days and he showed me a little play in the pulley and a jiggle in the crazy looking blades inside of it. he said it will run that way but gain almost no power from the sc
So, My question to all the helpful people on here...
Is there any way to get a new ecu that would allow the new SC to work. They look identical except for the way the intake valve is operated. or is there a way to rebuild my old SC with the internals of the New?
any insight into this process would be appreciated. Has any one else installed a bosch MY AJ133SC in a Denso MY car and actually had it work? I am now so worried that after all this time and money the car wont run correctly. and as of now I'm out of money and have no supercharger to be installed and they are quite expensive.
Received 3,824 Likes
I personally would be looking at replacing the bearings in the old supercharger and going that route. There isn't much to a supercharger. So, unless the blades of the supercharger are toast, you should be golden after new bearings are put in. If the only play is in line with the blades, then you should be good. The big thing will be how much clearance there is between the blades and the body of the supercharger. There should be minimal gap. When you start getting too much gap, the air goes around the fins to the next set of fins as pressure is built, resulting in very little air flow overall. Granted, this could be overcome by either plating the inside of the supercharger to reduce the gap and/or replacing the rotor to get rid of the worn blading. Granted, you will not want to get the blading too tight as this may change the output pressure of the supercharger which will affect power (ie, less gap means less air going around the fins, therefore more air to the engine, more boost, more fuel can be added, resulting in more power).
Thanks for the response, yes I guess I'll have him rebuild he old supercharger. Do you know if the new sc bearings and internals are identical enough to the old one and we can swap?
My shop is looking into solutions as well, I'm stopping by the mechanic tomorrow I'll let you know what they come up with.
Got the 2011 supercharger rebuilt for the 2016 motor and Now there's another major issue that's popped up now that they got the motor running.... so there is some sort of magnet sensor in the 2016 that's causing the engine to cut out all the time. It has to do with the starter system and the way the 2016 stops at red lights and restarts. My mechanic can't figure out how to work around this and is going to reach out to a dealer tomorrow. Does anyone have any insight into this problem and have any possible work around a we might be able to try?
I'd really appreciate any help on this
Chris
Chris
So to anyone wanting to use an updated 2014 newer aj133 motor in an older denso car. There are a lot of hurdles but it is possible.
The work around to the start stop issue is pretty involved and we wish we had known before putting the motor in. Apparently It's a much easier fix with the motor out. There are some magnetic cam sensors that also need to be swapped out to the denso version that are not set up for the start stop. I will post all the details and part numbers when I finally get the paperwork after there car is done. I couldn't find any research on this so I'm hoping our trials might help the next person needed to swap the motors. And what's also got to know is that the newer motors are actually much less expensive as the older denso motors are becoming harder to source in decent shape/mileage.
But as of now, my mechanic has swapped all the sensors and we will know by tomorrow if it fixes the stalling problem, but he's very confident, and said he didn't catch it as the connectors come out of the newer motor in the same spot and have the exact same electrical port connection, they just don't send the right info.
prodigy215 (09-13-2017)
Happy to report that the 2016 motor is now running perfectly. I picked the car up Thursday and have been driving it all over. The used motor they found me only had 4 miles on it so I am still breaking it in and being gentle but it sounds awesome. So for anyone out there wondering if you can put a new 2014 and up AJ133 SC motor block into an older model with the denso computer system, it works and is running perfectly.
All the sensors need to be pulled from the old motor and swapped. Along with the cam gears. Flywheel, Fuel system, And the supercharger. We rebuilt mine as it was beat.
I recommend this to anyone with a bad motor in an older car. The newer motors are actually less expensive and can be found with very low mileage from the wrecker. Also. The timing system, cooling system, and a few other things have been improved and the updated motor is all around more reliable.
If you have any questions message me, or want a shop that can tackle this for you in the Philly area
Try Turchi Enterprise in Lafayette hill. The shop is incredible and the mechanics are fantastic. And you can not beat the price.
Love driving this car!!! Been waiting 2 months!!!
Have a good day!
Have a good day!
SinF (10-15-2017)
