XJ ( X351 ) 2009 - 2019
How to tell if I have Adaptive Front-Lighting System (AFS )?
Old Jul 17, 2020 | 09:55 AM
demiroquai's Avatar
Default How to tell if I have Adaptive Front-Lighting System (AFS )?
Hey guys,
I have a 2015 Jaguar XJ and I want to do a headlight refresh. The question is how do I know if my car has AFS? I see the lights calibrate when I turn on the car but if I turn the wheel when I'm not moving I can't see it moving. Thoughts?
Old Jul 17, 2020 | 10:51 AM
xdave's Avatar
If your lights move left and right then quickly back to centre when you start the car with the lights on then you have AFS. From memory the AFS won't operate when the vehicle is stationary - you need to be moving to see the lamps move after the initial calibration.
You can also tell by looking at the headlamp assembly itself. If the outer corner section has a lens in it instead of a silver insert with the jaguar leaper then you have AFS. If you see a jaguar leaper instead then you don't.
Old Jul 17, 2020 | 10:55 AM
clubairth1's Avatar
Community Influencer
Not sure but my 2014 XJR does have AFS. I can sit in the garage and turn the steering wheel and see the headlights on the wall move a bit.
So my guess is yes you have AFS. I think it was standard on all XJ's from the introduction in 2009?
Old Jul 17, 2020 | 11:49 AM
XJsss's Avatar
Adaptive Lighting was standard equipment on the North American market XJs
Old Jul 17, 2020 | 12:48 PM
carzaddict's Avatar
if you turn the wheel while not moving, you should see them moving ever so slightly. other than that im not sure if theres a button or a menu option that allows you to enable/disable (which would indicate you have it)
Old Dec 6, 2024 | 04:04 AM
billyawan's Avatar
how can you tell if this is a afs model or without afs ?
Old Dec 6, 2024 | 06:40 AM
clubairth1's Avatar
Read up thread? He told you exactly what's different?
Old Dec 7, 2024 | 03:40 PM
SuperChargedXJR's Avatar
There will be a sticker on the housing. Look for AFS. You’ll also see a yellow headlight with arrows under it on your dash at night if you have Adaptive Lights.
Hunter McWorthy
Sep 19, 2021 12:06 PM
RonK
Sep 23, 2017 10:54 PM
lancervi50
Sep 8, 2016 06:04 PM
mullisrd
May 10, 2016 10:11 PM
synperkaya
Apr 16, 2015 11:19 AM
