XJ ( X351 ) 2009 - 2019
Jaguar numbers for coolant pipe replacement O rings
Old Nov 11, 2025 | 11:28 PM
dennis black's Avatar
20 Year Member
The heater pipes come with the O rings installed already, I've installed over 15
of them on members cars with no issues, not a debate here just do what works for you,
even with the flat gasket that come with it, can't see them leaking from 2 metal surfaces mating, but just my 2 cents
do what you think is good for you, if it was a bad it would fail in 3 months, with each heat cycle
Old Nov 12, 2025 | 04:11 PM
12jagmark's Avatar
Yes - I misunderstood your post. It's good to read that you haven't seen any leaks yet.
Your post really helps with how the ones that came with the pipes perform - helpful feedback for future buyers to take into consideration.
Eventually, hopefully after many years & miles, leaks will crop up with the OEM seals or aftermarket. As long as they last a good long while they've served their purpose.
Old Dec 31, 2025 | 12:22 AM
Greg Wojdalski's Avatar
Originally Posted by Meanmugga
I need to change that pipe behind the engine... may I ask where you got the oem seals from?
Also... is it doable on the 3.0L without removing the supercharger?
It is totally doable without removing the supercharger. Not the easiest job, but very much doable DIY style.
62jeff
Oct 24, 2025 10:11 PM
Ken Dreger
Jul 3, 2025 02:21 PM
PermanentlyRepairingXJ
May 24, 2025 04:20 AM
Tamaren
Jul 24, 2024 07:16 PM
gershon
Jul 24, 2023 06:40 PM
