XJ ( X351 ) 2009 - 2019
Jaguar Technical Service Bulletins
Old Nov 2, 2018 | 12:16 PM
Iowa4576's Avatar
Default Jaguar Technical Service Bulletins
This web site has good info on Technical Service Bulletins (TSBs). These are known quality, material and mechanical defects. Not all will be applicable to your Jag, but some may. I was able to have the "sticky button" issue repaired under factory warranty which required the replacement of numerous steering wheel, console, and dash buttons and switches. These are not factory recall items, which are safety related. Unless you do the research yourself, you'll never know about these problems. You will have to select the model and year to get the correct info.
https://www.aboutautomobile.com/Tech...Exhaust-System
gears
Jun 13, 2024 01:19 AM
Jim 2001 XK8
General Tech Help
Aug 2, 2015 09:07 AM
Jim 2001 XK8
Jul 29, 2015 06:30 PM
JimC64
40
Dec 22, 2012 03:34 PM
jimatvs
May 10, 2011 12:25 PM
