Just replaced my front lower control arm bushings at 52k miles
the urospare bushings are not a hydro bushing like oem, that aside did you get an alignment done afterwards?? You need to
I don't know whether they are in fact hydro or solid rubber...but they looked and felt exactly the same and the ride and handling is excellent. The hydro bushings on my old arms were torn all the way through.
No I haven't gotten the alignment done yet. I just made some marks on the washers and bolts and lined them back up as best I could.
Yes. My 2014 XJL AWD lower control arms are being replaced now too. 53k mi. Discovered during annual inspection. I asked them to check as I was occasionally experiencing a little steering wheel shimmy. Not a crisis and could probably have driven it many more miles before changing them out.
Inspection, oil change and front lower control arms, slightly over $1600 (half of which was labor).
L
While having my car aligned last week my mechanic was kind enough to point out to me that the control arm bushings were just starting to leak a little fluid. Nothing major and he even mentioned that it didn't HAVE to be done right away.
I figured while he had it there and it was on the rack I may as well go ahead and have them replaced. 52k miles doesn't seem like a lot of mileage for a 2012 car to me- especially enough to justify worn out control arm bushings. Drive out for the alignment and the bushings was $1500
Any of you guys experienced this?
.Any of you guys experienced this?
The short life of the suspension bushes was one reason I decided to move on from my 2nd XJ (X350 model). Lets face it, these things should last a lot longer than they do. The spring unit lower bushes last even less time, and the rear lower wishbone bushes are also short life. Maybe one day Jaguar will cotton on to the fact that their name is mud when it comes to durability.
When you broke that bushing what change did you notice in the drivability and ride?
Probably the biggest clue is anything leaking from the bushings. Same for the motor mounts as they are liquid filled too.
But we have had people with what looked to be good bushings and after much work they replaced them and fixed the problem. So my point is yes inspect the bushings but that might not tell you anything unfortunately.
daboss085
Jul 29, 2013 01:52 PM
kalacho2006
Jan 16, 2013 07:19 PM
eastsidejp
16
Dec 22, 2010 07:17 PM
