XJ ( X351 ) 2009 - 2019
Mass air flow sensor where is it ??
Old Jan 27, 2019 | 11:32 AM
clifford hine's Avatar
Default Mass air flow sensor where is it ??
Hi all I need to look at my mass air flow sensor clean or replace as keep getting restricted performance and diagnostic software is telling me to look here. A picture would me lovely or has anybody got a repair manual like a Haynes pdf.
Old Jan 27, 2019 | 12:42 PM
cubist's Avatar
Hi Clifford,
This diagram may help.
Cheers,
Cubist
Old Jan 27, 2019 | 12:50 PM
Thank you very much at least I know where to look now.
Old Jan 27, 2019 | 08:31 PM
Thermo's Avatar
Veteran: Navy
Clifford, if you have a 2011+ XJ, you have 2 MAF sensors, not just one. They are easy to find. Look behind the headlights. You will see the air boxes there (where you put the filters). Where the line comes out to heat to the motor, you should see a small box (about 2cm x 2cm, or 1"x1") bolted to the top of the tube. This is your MAF sensor. It will have a connector on it with 5 wires attached to it.
Old Jan 28, 2019 | 09:41 AM
XJsss's Avatar
When I saw this post, my first thought was that to OP must have KN filers and that they may have been over oiled. IMHO
Old Feb 1, 2019 | 10:34 AM
clubairth1's Avatar
Community Influencer
Can you tell us what car/engine/year you have?
Old Feb 7, 2019 | 04:28 AM
EmmanuelTam's Avatar
I have just recently replaced a pair of the MAF sensors, thought these pics would help, if we are talking about the same car.
MAF sensor off
The MAF sensor
New MAF sensor on
Old Aug 16, 2023 | 04:44 PM
leadfoot4's Avatar
MAF sensor off
The MAF sensor
New MAF sensor on
I know that this is an older discussion, but could someone enlighten me on how to remove that yellow retainer, without breaking it, as I want to clean our MAFS sensors.
Thanks!!
Spurlee
Feb 10, 2011 10:15 AM
electraglide1600
Sep 13, 2010 01:16 PM
Greg561
May 14, 2009 02:27 PM
Spurlee
Apr 29, 2009 09:51 PM
Xistnnn
Feb 27, 2009 12:58 PM
