XJ ( X351 ) 2009 - 2019
Pedestrian airbag
Old Feb 9, 2024 | 08:32 PM
Carlos Saez's Avatar
Default Pedestrian airbag
Hi guys I had my pedestrian airbags deployed.
I'm ok the hunt for spares.
The number on my air bag is 8x2316E600AA
part number c2d23552.
I have only been able to find 8x2316E600AC, they look identical and the part number is the same c2d23552.
Does anybody know id they will work.
Old Feb 9, 2024 | 08:42 PM
Thermo's Avatar
Veteran: Navy
Carlos, yes, what you found will work. The air bag is just a slightly newer version of the one that was originally installed in your car. But, it is not different enough to be an issue.
Old Feb 9, 2024 | 08:44 PM
Thanks for the reply I'll get those then.
Old Feb 10, 2024 | 07:29 AM
Are they the same one for both left and right side can't seem to find and reference If they differ from each side.
Old Feb 10, 2024 | 09:39 AM
Thermo's Avatar
Veteran: Navy
Carlos, looking online, it would appear that the air bag is universal side to side. They are not calling out a left/right side unit.
Old Feb 10, 2024 | 02:11 PM
roviw's Avatar
I think there is a spacer piece to fit under one airbag unit on one side if I remember correctly, you should be able to reuse the original spacer.
I had this happen on my previous XJ. I also found two replacement airbag units on ebay, my sensor behind the front bumper was also replaced to be safe.
On mine there was a small amount of strain on both the bonnet hinges so I had to have those replaced as well.
There was a very very slight bend about 60mm from the trailing edge right across the bonnet, it meant that without replacing the whole bonnet I had to put up with a very very small difference in height when trying to align it with each wing at the rearmost point both sides, you may struggle to see it unless you know about it but it meant the top surface of the bonnet sat about 1.5mm higher.
I wish you well with the repair.
Old Feb 11, 2024 | 12:16 PM
Thank I'm aware of that, I'll try to fix it without getting a new bonnet. What a crappy system that is it really does nothing to protect a pedestrian, I have seen other cars like Land Rover that pushes out a big airbag Infront of the windshield that would seem more appropriate, but this only causes damage to the car.
DPK
XF (X260)
Mar 10, 2017 05:41 PM
Magnumforc
XF (X260)
Jun 14, 2016 10:47 PM
ajpds
Apr 21, 2015 03:44 PM
Schwabe
General Tech Help
Feb 20, 2014 06:00 AM
albackuk
Jan 28, 2012 12:58 PM
