Reset service required
2012 XF supercharger. How ro reset
wardwe64, you have 3 options:
1) go to the dealership 2) buy an SDD computer to perform the same function as the dealership which will set you back a fair bit of money ($1000 or so?) 3) look on e-bay and there are some hand held units that will do it when you plug them into the OBD port, but they will run you about $150 or so and all that they are good for it reading codes and reseting the service required light. Of note, not all code readers will reset the message. Only a select few. |
Originally Posted by wardwe64
(Post 1942031)
Please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum. Graham |
If it really is an XF then you could try this procedure outlined in the XF workshop manual:
Reset Procedure To re-set the service interval indicator, the following process switch presses must each be carried out within 3 seconds: With the vehicle in power mode 0, (ignition off) press and hold the rear fog lamp switch Allow the vehicle to enter power mode 6 (Press the start button without a foot on the brake) Immediately release the rear fog lamp switch Press and hold the trip computer cycle switch Press and hold the rear fog lamp switch Continue to hold the trip computer and rear fog lamp switches If the process has been successful, the message center will display 'RESETTING SERVICE MODE' and then display 'SERVICE MODE RESET' after 10 seconds Release both switches and return the vehicle ignition to off, power mode 0. |
Originally Posted by u102768
(Post 1942126)
if it really is an xf then you could try this procedure outlined in the xf workshop manual:
Reset procedure to re-set the service interval indicator, the following process switch presses must each be carried out within 3 seconds: With the vehicle in power mode 0, (ignition off) press and hold the rear fog lamp switch allow the vehicle to enter power mode 6 (press the start button without a foot on the brake) immediately release the rear fog lamp switch press and hold the trip computer cycle switch press and hold the rear fog lamp switch continue to hold the trip computer and rear fog lamp switches if the process has been successful, the message center will display 'resetting service mode' and then display 'service mode reset' after 10 seconds release both switches and return the vehicle ignition to off, power mode 0. |
