XJ ( X351 ) 2009 - 2019
Sunroof Blind
Old Jun 9, 2017 | 09:04 AM
pellowe's Avatar
Default Sunroof Blind
Whilst closing my sunroof blind it sounded like something snapped and now can't get the blind to close. When I press the close button the motor runs and the roller rolls but the blind doesn't move.
Does anybody have a diagram of the sunroof and blind mechanism so I can get a better idea of how this works. Is there a step by step process to get this repaired. I assume it involves removing the headliner.
Old Jun 9, 2017 | 10:20 AM
RoonieQ's Avatar
I had this exact thing happen. Fixed under warranty so not much help to you there, however, I posted about it at the time to list parts etc. Try searching this forum.
Old Jun 15, 2017 | 05:35 AM
pellowe's Avatar
I managed to fix the blind. One of the feet had broken so that was replaced. The only issue I now have is the blind is sagging very slightly on the right hand side whilst on the left hand side it is tighter. I have performed the reset procedure but didn't fix this problem. Does anybody have any ideas.
Old Jun 17, 2018 | 10:10 PM
jagmt's Avatar
where can i get the parts ?
Old Jun 19, 2018 | 08:56 AM
Sandro Felisio's Avatar
this is mine......
help!
Old Jun 21, 2018 | 01:53 AM
jagmt's Avatar
Originally Posted by Sandro Felisio
exactly same problem as mine
Old Jun 21, 2018 | 01:54 AM
How have you solved?
Old Jun 21, 2018 | 02:16 AM
pellowe's Avatar
Here are a few documents showing how to install the feet if they are broken. I bought mine from a Jaguar dealership.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Jun 22, 2018 | 02:23 PM
clubairth1's Avatar
Community Influencer
Here are 2 things that might help?
Old Jun 27, 2018 | 08:36 AM
Tnx you all, mine doesn't close... the problem is not in the tensioner...
Old Jun 30, 2018 | 12:16 PM
clubairth1's Avatar
Sorry in your video I saw 2 problems?
The back shade does not close all the way?
The front shade appears broken and the motor is making noise but the shade is not moving? Is the front shade stuck in the open position?
Maybe I do not understand?
Old Jul 2, 2018 | 04:29 AM
Hi!
The rear shade open and close but not completely close. This was like that from new.
The front make noise and it is stuck open.
Thanks for your help!
sandro
Old Jul 11, 2018 | 09:41 AM
lolshto's Avatar
I had exactly the same problem as yours. Same front shade, absolutely same noise.
You need to replace the motor of the sunroof and probably left, right or both feet. Mine needed the left feet and the motor. 1400 euro at the dealership.
I bought the new roof for the same price and got rid of the rust and cracking noise from the sunroof. It was exactly the same price ( 1400 euro ) from the donor car from Florida ( 2014 MY ).
You won't be able to fix that easily as it requires a lot of work ( dealership calculated 9 hours total ) and spare parts.
Old Jul 13, 2018 | 02:44 AM
So cheap.....
