XJ ( X351 ) 2009 - 2019
What Size Brake Pads for Front, 5.0L SC non-R
Old May 29, 2019 | 12:15 PM
New2Jag's Avatar
Default What Size Brake Pads for Front, 5.0L SC non-R
Trying to source brake pads locally but the vehicle selector doesn’t find them fiends my car no matter where I look. I’m hoping there are standard sizes on other vehicles that will work. Someone said somewhere the rotors were 380mm... are there certain pads that I need to look for? It’s def the fronts. Two days ago they just started making noise and I can feel a little feedback on my feet when braking.
Only gonna have the car another three months, not trying to get into a full rotor/pad replacement job for front and back and unfortunately I dot have the tools to do it myself anymore.
Old May 29, 2019 | 01:25 PM
Mark SF's Avatar
Where is locally?
Old May 29, 2019 | 01:31 PM
Mark SF's Avatar
I checked Rock Auto for you. They list 10 different options in front pads for your model.
Old May 29, 2019 | 08:52 PM
OzXFR's Avatar
Being a 5.0 SC you will have the 380 mm front brakes for sure.
Those brakes are common across all the 5.0 SC Jags - XF, XJ, XK, and F-Type - they are the exact same brakes in every case including the pads.
As Mark SF says check out Rock Auto under (for example) 2011 XF SC front brake pads, heaps to choose from.
Just make sure you get the proper 380 mm pads, 193 mm long, see this Rock Auto listing for example: https://www.rockauto.com/en/moreinfo...447745&jsn=386
derrickonline
Jun 5, 2020 08:48 PM
TreVoRTasmin
Feb 22, 2016 11:27 PM
bsim
May 30, 2015 06:47 PM
Xeno
Feb 1, 2014 11:55 AM
