XJ ( X351 ) 2009 - 2019
Windshield water sensor not working
Old Aug 1, 2017 | 01:21 PM
loulizjag's Avatar
Default Windshield water sensor not working
Hi guys
On my 2011 Xj i have my windshield water always empty even when its full on my screen, so i think its the sensor that is not working or its disconnected. Anybody know hos to repair this ))
Thanks to all
Old Aug 1, 2017 | 02:09 PM
xdave's Avatar
If you really do have a full washer bottle (so not a leak) then it does sound like a faulty sensor. To get to the bottle remove the RH road wheel and the wheel arch liner. all the screws are visible (plus some 10mm nuts at the rear). The pump is on the bottom and the sensor is behind the bottle about 6" up. Refer to the attached drawing for the location (pump shown removed).
If you plug the hole, or drain the bottle, you can activate the switch manually to see if your warning lamp changes. If it does it's likely the switch, if not post back and I'll look up the wiring schematic so you can test that.
Old Aug 1, 2017 | 02:57 PM
loulizjag's Avatar
Ok great, i have some time this weekend to look it up. I'll tell you
If its the switch you have the ref number?
Old Aug 1, 2017 | 04:27 PM
xdave's Avatar
The sensor is C2S4061. Same as the last XJ (X350), X-Type (X400), XF (original X250 version), and your XK. Should be stocked by most dealers at around Ł20. Do not buy from eBay - they are priced around 300% the dealer cost.
Old Aug 1, 2017 | 04:44 PM
loulizjag's Avatar
Ok thanks. I'll look it up and get back to you
thanks
Old Aug 4, 2017 | 07:05 AM
justjon's Avatar
You can get to the level sensor without taking the wheel off - just turn the steering to full right lock, and remove the clips from the back of the wheel arch liner. You can then reach in through the small gap to the water level sensor. It's a bit fiddly, so I'd suggest doing it with the water bottle empty as you won't be able to plug the hole.
Dave, thanks for confirming the part number - I shook and tapped my switch until it worked again, but I'm sure I'll need to get back in and change the part before long.
Old Sep 11, 2017 | 04:08 PM
loulizjag's Avatar
All worked well, did not relive the tire and ordered a new sensor. No more problems. Thanks to all helped
Old Nov 7, 2020 | 12:54 AM
fossberry's Avatar
Blowing the dust off this post: anyone know what resistance should be measured with the sensor? Mine has died but I suspect it's not the sensor but the control board. Given it has a magnetic disc attached to the float the internals must be a Reed switch. I get open circuit when simulating no water in the tank and about 10k ohms when the circuit is closed (sufficient water - float against the housing). I tried unplugging and shorting out the plug contacts that lead back to the car (to give 0 ohms), but still get the 'washer empty' message as soon as I start the car...
