I bought a '96!
Hello folks,
About 8 years ago, a friend came over with his newly bought '96 XJ12. He let me drive it; the only one I have ever driven. I thought wow of course. After driving S1 XJ's for 35 years, this was a jet! Unfortunately the fellow suffered a mild stroke, had his licence revoked, and sold me the car. I didn't get to put it up on a hoist or test drive it. I got it home and looked it over, runs nicely, 109,000 Miles (a USA car), cheap paint job, minimal rust, some driver's seat movements don't work, needs 4 brakes, cracked windshield, needs brakes, AC weak, leather needs dye, headliner of course, coolant tank was low, needs throttle rod bushes, transmission mount thumping, lot of wheel speed related vibrations. But of course, I'm in love with it! I'm just retiring from teaching, and want all the Jags. I was pleased to learn (thanks DD) that all the X300's had the same brakes, because I have a new set on an XJR6 I have in my private bone yard. I want to swap in the R shocks too, as these are shot. I'll use the R front sway bar if it's bigger. The rear bar would be nice, but I know that the diff bracket has to be changed too. The shocks should make a big difference; now I can bounce the XJ12 about a foot up and down all around, whereas the XJR6 will barely move no matter how hard I try. I'm worried the coolant loss could be the evaporator. I see a film on the inside glass. Is there any quick test? I know people here frown on Barr Leak. The rims are shabby. Has anyone had luck painting them? The leather dye should be easy, as I'm a distributor of these products in Canada. NDR Cream. I'll send pictures as I progress. If anyone has any tips, please tip-away! Cheers, Robhttps://cimg2.ibsrv.net/gimg/www.jag...3536dbe602.jpg https://cimg3.ibsrv.net/gimg/www.jag...e6f61030e0.jpg https://cimg4.ibsrv.net/gimg/www.jag...b15b017baa.jpg https://cimg7.ibsrv.net/gimg/www.jag...916bb71299.jpg https://cimg8.ibsrv.net/gimg/www.jag...39ab63c359.jpg |
Windsheilds come in 2 versions for the X300 heated and non heated . Depending on which option you want to go , if it is currently heated there will be 2 extra relays behind the left side left foot small panel .
The clearcoat on the wheels being 22 years old can be removed by aircraft paint stripper back to bare metal but must be removed from car Your V12 engine coolent diagram is on page X . Best to go ahead and change the thermostat as they fail closed and you have that covered . http://www.jagrepair.com/images/Trai...20-%202000.pdf There are seat controls have 5 fuses to them . |
Congratulations, quite a collection of Jags you've got there!
I also just picked up a V12 XJ, but a 1994 XJ81 :icon_mrgreen: https://www.jaguarforums.com/forum/x...-first-203098/ So you and I are in a similar boat of minor V12 rehabilitation projects :) . |
Thank you Lady P and Al.
That's good insurance info about changing the stats. I hope the only problem with the seats are fuses, that would be great. In the meantime I'm scheming about using all the XJR6 stuff to stiffen up the ride. I have the comfort suspension now, and the car is sloppy. While getting the shocks and brakes off the R it occured to me that maybe the springs could go on too. The R springs are stiffer, but do you think the weight difference between engines will be a problem? I bet no one has tried, so maybe it's a case of try and see. It seems to me it would be less of a risk swapping out the rears; spring/shock unit complete. With Jags I've owned over the years, I've had good luck swapping to thicker sway bars, adding a rear bar etc. Overall this car is very quick in a straight line, but looses composure turning. Cheers, Rob |
I really like the Saphhire blue on these cars. Get some wax on that finish so it will last as long as possible. You've got better things to do than repaint right now!
Non-heated windshields are readily available. Shop around for the best deal. But be wary that some replacements do not have the VIN opening in the right position. The edge masking on the new glass might cover the VIN, so check that out before installation. Two thermostats: 88 deg. C only! You'll need 2 of the triangular thermostat housing gaskets too. While you're at it, replace the main radiator hoses at least, for now. All of the major radiator hoses are available from Uro Parts via Rock Auto and Ebay. They are quite inexpensive. BE CAREFUL with the hose fittings on the radiator. They are aged. Examples: [img]data:image/jpeg;base64,/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQ EBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/2wBDAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQ EBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/wAARCAB4AKADASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJ xFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3O Dk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIW Gh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx 8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRM iMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2N zg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goO EhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPEx cbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD+/iiiigAooooAKKKKACiio5poreKWeeSOGCGN5ZppXWOKKKNS8ks sjkJHHGgLO7kKigsxABNADbi4gtIJrq6mitra2ikuLm5uJEhgt 4IUaSaeeaRljihijVnkkdlREUsxCgkflR8Yf+C0/wCwH8HvENz4Xl+Jmt/ErVNPu5rHU5fhH4Uv/Geh2FzbyiGZP+EpMmmeGdSVJGUGbRNX1SEliFkJSQJ+Kf8AwVy/4Kuf8L8vtd/Zk/Zn8UzN8GNKupNK+JHjnRJprUfGDW7aUpceGNF1RSgf4W6TIo/ta8gElv47u0ngDN4VtPO1vP8A2Af+CH0n7UXwe8L/AB++OHxR8R/DHwd45shqnw08E+AdD8PP4q1LwmS0Wk+LvEeveJrDV9P0q31oW 8Wp+HtB0/QbhxpUsOrXGpW8mq/2XYuztd6L095+l9F8/u2b6I0oRjz1W029IK17WTTfXW+ySt5u6X9E37M//BS39jv9q/V4vC3wt+KUNr45uFd7XwD450y88F+Lb/y1V5Y9HstYWOz166hjcS3FloOoane20WZri3iiBevvOv4Mv+Ck H/BOXxz/AME7/GXw/wDEnhz4jar43+G3jTVbuT4fePpMeFfGvh3xxoBs9WOg6/LockVtb6vb2UQ1vwz4i0P+zo7xNM1R1sdGvdPLXn7u/wDBJX/grRpn7SunaN+zr+0JrtrY/tB6TZLaeEPGl6I9O0743abZW+4K6vFaW9l8T7G1id9a0eCJLfx LFBPr2hoHOoabZPl05lquum23+ZM6asp025Rd9N2rWv2b1eumn nufvhRRRUmIUUUUAFFFFABRRRQAUUUUAFFFFABRRRmgAr+S/wD4LEf8FXJPiA/iz9kj9mfXx/wgdrJqGhfGf4o6HdCR/G9xYSPa618O/B15BuRfBFjOk1r418SQyE+KZoJvDukSw+Hxf6jrfpP/AAWF/wCCriPH4q/ZI/Zj8TTMyyXfhr44fFTw3eOjJIc2+o/C3wZrFjPHJDI77rDx/wCILOeGSCGSXwvo1y97JrMln/LC5xHbmKN3hhiLYTZCqLYSKksFtbrtbcYp1SSRLaeeSS2k82FY QZE0jTctWnbTRddmr22i0+6v6M6KcVG05b2vFb6b83bzWt1vvY klmMBMc00pe4RGWMpCkUoVWRoIp0SdcxT4uhFCEkDSiFpFbMS/1Y/8E8/+C2v7P3w4/Z3+HvwR/aWsfGXgnxR8IfDVl4D0fxV4d8K6h4x8NeLPC3haCPTPDt1Pa+H YbrWdA1y20mPTtM1G3uNNn0i8uYo9SstXxqBsLP8Ak/2jCYlaGSNh5to/nGSaVJpA7szGCSRII8F7PYuS5cIHgWVXKuIomRrcxtPtn3xTvL FErtKFjCSLHLHJve3giSCSKLazzOkkCCtHSvFPrbomtkuj126a 66Xu2x2Um7rmTkn7t+yWnnZparqu93+zX/BXH/gpj4X/AG6dU8AeB/hZoeu6H8FPhxqOq65a6p4ntoLDxP488Wapp0dg2stoST3y6Bom gaSt/Z6PBezprk0uq6lqOqWNmkVtZw/jhpt9qWl3UGu6ZPe6Zf6RcWWuaXrWnT6nZXmmavp1wJrHW9JuL Ga2udNuIrm0tbnTr2zntvsNxBFNbSsVhlSrLblWd55HnedSXa6 lNtNJE00r7VknhnBkA8pHLD7S0w8tpYhcytJZt45CZJ22M0EUC 25sxbHKCUPJBPjzBBm1dnnXBSaOCaUlGXeaVNxst1v00bsvu8+ m9th9lFOKjtp89b9+vqz+y7/gkh/wVtsv2mtP0n9nf9orV7HSf2g9Js4bTwf4vvGj0+w+Nmm2toshR g0cNpafEnT7dS2p6basbbxRbRvrmkJDdf2npNj++1f5a2n3t3p F/Yavokt7YalpV5Zahpus21xfaXqWlapDdJNpmq2dzZ3UV3aXVnq MML2mo28ivaXKpdvNFcRRNB/Z3/wSa/4KzWP7R9lon7OX7RmsW2l/tEaVYx2fhXxhf/Y9O0/41WlnbNKYpIoilvYfE6xsoTNq+kwpHaeJIop9X0VEuU1LS7LKd Nx1Wqtd+XS9rt2v16bPUynCyuvmu2i/pq912tt+91FFFZGQUUUUAFFFFABRRRQAUUUUAFfzkf8ABYX/AIKpy/C2XxD+yZ+zp4ljt/iHNZPp/wAaPiVpV2wn+HNlqVmrHwH4XurdWZPHup2N1Dca1q9m8sng3TZ ltITD4luzNoH6N/8ABUP9tWP9if8AZk1vxdoE1tJ8XPH1xP4E+EGnzok6Q+JLywnu tT8XXVs5/e6b4H0WG61yRXjlt7rV10TSLhNmqgj/AD/NS1i41LUtSudSvr/Uta1C+u9Wv769vJ7rVdXv9SmubvV9W1DUpDNJqmozX9zd3012x klurmSacxzum5NKcOZ36J7d+uqve3d2623NqcNHN9HaKte701f kr6aO706GlNch1twjJ5CypG43sls0nmbpBPLNNIkYLSTIt2rBx uWOQRiFJn+h/wBmj9jT9of9sXxL/wAIl8AvAOpeJ/sF9EviXx1qd2NH+HPgq2dGWSDxL4xubSSza/8ALHnQaJpcOseJLtWimg0ue1Uz19I/8Ev/APgnN4s/b2+Kd7fa1JqPhD9nr4dX9hJ8TvHVgZo9U1jUpLW1vbL4YeBryd WiPi3VLOdNW17xDIlxbeD9Avbe7e3udU1fQbW6/uy+FXwn+HPwQ8A+HPhh8KPCGi+B/AvhSwh07RPD+h2i21rBFEipJc3MnzXGoaneupudT1fUJrnU9Uv ZJr3ULu5uppZnuVRxdo2ut3Z9LaNPfZP7r7JRcp8vZyf4X720d +3qno2n/Px+z7/wbo/CLRdOs9S/ad+Lvi34h68yxvd+D/hXKPAXgW1KmPNlLr13Z3vjfxDGFTZ/aEVz4TlbIaKytmBL/pP4c/4JC/8ABN/w1aRWtv8Asq+AtXMdtFbG78WX3izxjeyLFgiVrnxN4h1R0nZhu eaAQsSWAwpK1+kdFZOUnu2/y+4y5pd38tPy6n5qeKv+CP8A/wAE5PFdpcW8n7MXhLw3NcL/AMhHwNrPjDwTqMUoRljuUm8NeItOikuIi3mI9zBcDzArurkV+X v7RP8AwbqeF7621XXv2WvjfrPh/WRZj7F4G+M1lbeJdHvZoY2CWtv8QtAs9N8R6Gj/ACrFcajoPiyVHWBpJQId5/ptooUpLZu3a7t81sxqpNdbrTSWq06Wf6H+al+0T+zV8cf2V/iE/wANPjz4C1bwH4kig/tPR7mOe11Dw14r0oSG2bWfB3iaJn0zWtH3xrbXcltc22p6VcmC LW7HTp5VgHhFjfanol5balo97d6bqmk6hBd6VqFnfXOm6rouq2 bQ6jaano11ZXFutrqkF9ax3tvqSSJdQT2sTxrFPll/0p/2kv2ZPgz+1l8MdX+E3xu8I2vifw1qKPNp16hFn4k8Ja0qEWXif wdr0aNe+H/EOmybZba9tWMU6B7HU7a/0u5u7G4/gV/br/Y08f8A7D/xz1j4O+MWv9d0C6s5/Efwu+IkVpb2eneP/BJk8i3u3slcQxeJ9MmQ6X4s0CHe9hqbRSWszaBd6LdXXRTqc65 Wlzad3zd++v4a9EtNoNT2vzpX5ejs1Zry6Wb0Xdbf1K/8EhP+CpTftZ6NH8AvjjqNtD+0R4S0R77Q/ETxR6dB8ZvCelwxi61mK0B8u28c6JBtm8TaXbny9U00jxPp8MM aa5YaP+6Vf5gvw4+Ifjf4VeN/C/xL+HmvXHhjxz4B16x8UeGvEenR3Mttaa1pzGdJ3sxK0V7p8y28 mm31hO4sr2wup7K7t0t7yZJP9Fr9jT9prw3+19+zf8Mvj34cji sm8YaL5fibQkfe/hnxro8r6V4u8PSBneUR6frdrdHT5J9s13pM2n3zIq3Sis6tPkd 0vdf4Pt/XW63TM6kbWklZPRrs/TezWvl6NH1BRRRWJkFFFFABRRRQAUUV4x+0X8ZtD/Z4+BPxa+N/iPy20r4YeA/Efi57aRig1G90vT5pNJ0eMghjca1q5sdItUU75Lm9iRAXYCgFd 6Lrofxlf8F0/wBpM/G79tHXvh3pmpNceCv2dNHtfhrpyW0k01ufHF49trfxI1BYd5tB dRaldaN4L1JuZ4v+EbEGEMrxzfkP4R8GeJviN488KeAvAtqdY8 XfEHxP4f8ABfhbSLBWkk1LxBrl/a6ZpFo0jHzEge/uLVdQuY5F+yWUFw8oMETK0PivxDrHjLxDrfjPxJqdzf8AiXxH4 h8ReLdd1dy8dzLr3iTWLjVtXlMc4E1xJLqV5czssUsqeSOY0VG LfrD/AMELvhpa/FL/AIKF+BNV1S1h1TT/AIO+CPiD8UpUurW3dYtdsdO03wL4Zv0cFXU2t948lvLdPKYWup aVBJDK/liaXqT5ael9Fq+zbT636u21tXt16r2XRqEU9rXsrrqn16dXqf2 Wfsl/s3+D/wBkr9nz4afAbwYkM1p4J0GGLXdcS3W3uvF/jLUCdQ8Y+MdSHzSPe+JPEFxf6iUmklNlay2umQOLOxto4/o2iiuU5m222927sKKKKBBRRRQAV+YX/BWz9kWw/aw/ZF8Ypp1gJ/ih8GbfUfix8L7qGNTeXGo+H9MuJfEvhJW8maWS28aeGY77S47W Pap1+Lw7qD7m0yNT+ntNdFkRo5FV0dSjoyhldGGGRlYEMrAlWU gggkHg002mmt07lRk4yUl0d/Xy+ex/lpyDzfMlikQRG3SVrgKEgQXMFvvcIci7EMiyKkzMcBlOJHjKx/0v/wDBuj+0cdE8b/GP9lbxDqgEHjHS7H4t+ALKZ44Y4vEXhyy0/wAP+OrC2t0mlVr7WvD8vhnW3EYjEkXhvVLoqW3s34N/tX+AYPhL+0l+0H8KrOVINN8BfGr4meGtKVoHkgs7LTfEusSeGh aW8M7XEVvFos+l2cZC+TK1uqzYSVkW9+yp8edT/Zt/aN+EHx30iZri3+HHj7Sda1+G1WdJrrwreQjRvG+inyJI40a+8H XGv2EdhP50MU8y3TFLj7Q8XdNe0puytdJ7W10a6b9H2TeuqR11 IXckn8S0Vt9pdtNUlvte+6P9KWis3RtX0zxBpGla9ot7BqWj63 p1jq+k6jauJba/03UrWK9sL23kHEkF1azxTwuOHjkVhwa0q4DiCiiigAooooAK/nY/4OIf2iF8HfAP4a/s3aTetFq3xp8Uz+LPF0UEsgkT4e/DUW99Fa3EcY3bdZ8a33h+ayJYK7+HL1TkKQf6J6/z9f8AgsL+0E37Rv7dPxf1LTr6S+8F/C6Sx+Cng/y5Ul0+Wz8C3l9a+JLm3uEUIG1Tx5feK5rabbKEtGtXUTBoWW6c eaSVrpav5f8ABNKXxJvaOuvV9Px19Ez8vheT7o2eeZpVmvJJbs SpdNLckmWK82LMrQwzXBEU21lYTSCdfmjgjH9C/wDwbp6np9j+2L8WdLnjEV/rH7O+tiwlRI4oLhdL+IXw9uLyOOJl89XSO5jZ9zl/3Z81N+XP89N5LBAdjQFrhjMZ18gJIjeWyNIrNFb3cka+dO0alW luSZniAD+bP+iX/BKf4+6Z+zp+3f8AAjxtrl9b2fhXxH4muvhH4y1O7vTBbW+i/EvR/wDhHrLULud5USWPRvFTeENR1NhZ7LS1sp5rifYyyxdE9YO1/h6L0aXporq7723Nb8ya3bi7W7pK1vW2tvR9D/Q4ooorkOYKKKKACiiigAoorwz9pn43+Hv2bfgD8W/jn4onii0r4aeCNa8SJFMTjUtYhtzb+G9DhC8vd+IPEVzpWh2US/NLd6hDGMbsgGk5NRSu20ku7eiP8/r/AIKC6xY69+21+15rVi8R027/AGgvicLW6ihNxFPJpfiS80dZreRBuka6u7NlOxjLEyOyoUgFfH VvPIfnmjFu6LBOGTdMJLUIJYUlhMaAvuS5Fxvk8sq0kNwJlkeO tPXtS1XxDqmsa9rWoo2r+JdQ1PxFrV2uXnl1nWruXVNUup3mSN Qs1/Pcz3TfK4RlVoQ00hhxZZlmhe4tmaULBE82worSuyTq8ojJijWG FmZZoJAkfJmhuCjTb/RgrRSe6UdGnbWKVltpfq/S7O2q0pJLZJR11vZRVtfRf8Nv/eJ/wRD/AGij8c/2HfCXhTV743XjP9nzVrz4N68lxdfab+XQNIih1L4fajcfKNscn g7UNO0RXVnjlvPD2oGJiigD9gK/iN/4IEftJr8Kv2vbj4S6xq8kHhP9pDwxd+G7S2upkh0yz8e+DIrvx N4ISOWQGS81K+01/Gfh8O8ha7udQ03akbSxCf8AtyriqxcJtd9fv/4JyTVpeqT+/f8AG4UUUVmQFFFFAHyt+27+0BB+y7+yl8cPjgZIE1XwZ4H1L/hE4biVIkvfHOvNF4c8D2XzkGRZ/FWraSJ44w0v2UTuinYcf50Pgr4efEf4y+NLTwZ8NfCfir4r/EfXri+1DTvD/g3SdR8UeLdZkEou9e1O6svLMESiTFxq3iTV5LXT7FZIp9Q1FZJ ba4H9kH/BxFda1b/sP+CksvNGhXX7RXgG38U+S7xbrNvC/j2TSEuZf+PeOzfxDHpa77ggJqB02SIiVFYfMf8AwbX2vw3bwt+ 1TqK/2TL8ZD4t8BadfysLKTWIfhXbeGm/4R+LTpkeSb+x5/GX/CXzaotkVspLxNIa5B2aYI7i+VN262Xlon6rW+3ZfPWOlNtLXmu 35LlS8nq35o/nY+On7GX7WP7NWi6P4o+Of7P/AMQvhh4b1a8isbDxDrsWk61oQv8AUIUubTR7zW/COr+ING0zVWa2u57fTtX1Czv7maL7Pp4kWEpH8xlUne4Z5biIx yzXBeKKWCbZGkfy2rxgxqz2pR2aK5DwbURP3s6y23+it/wU61r4ZaJ+wP8AtTyfFiTTh4b1H4ReKdG0m21DyGkv/H2pWTwfDS10iGcjztfHj4+HrrRDEDNa6hbQ36GNbR5o/wDOqaZYUb7S8c1yDDLDHaLGpe6AhZ5WnSFZHEjt5m6AbTJsZ4n 8xXbSEnK6dvRaaaabOytrfys9LWSb+LXR3e9klbay89vLU/vH/wCCP37f+n/tg/AXT/APjnWoG/aL+CuiaVofj6zubuJ9Q8c+F7ZItM8N/FmwiEkjz2+urEmmeK8O8mm+MbW+NzHbWer6Mbn9fq/zDPgx8afib8AviF4T+MXwi8XXfg3x14Iubm80nXdPuTKJAhji1 LSdf0e6f7Nq/hjWYG+w6/oN4JbHVLNog8f2qaOS1/tT/YI/4LPfAL9qjTNA8D/GG90X4A/H+aO3sZvDfiXU0svAfjjURBlrr4feLdSeG0juL6RGaHwb4iuLL xHDLItnpZ8SRR/2jLlKLV3bS5UoX9+GvWUVvHzt2aafls+5+0FFAORkcg9D60VJi FFFcb4++IngL4V+FtU8cfErxl4a8B+D9Fha41XxL4t1mw0HRrK NEeTEt/qU9vbmaRY3EFujvcXDjyoIpJSqEBXeiV29El1Oyr+PH/gu7/wUG0f4xeKLX9kL4R+ILXUPh98MfE1rq3xh8QWk8c2meLfiPpjl dP8ABmnzwuUvtK8Bh7u41eZ3+wXHjWSC3OJ/CIln7L/gpN/wXQPxA0rW/gb+xXquseHfC+qR3WmeLf2hp4bjQ9a1vTmcQT6b8KrO7SHUvD9 hqMQeN/GesW1nrN/BceR4bsdKl8jW5v5lLmea1iknvEtWaX7RC8e4ys/2qZYpXkZwPKmKos015Ncs0c7MgaEQEnalBtptPRqy633v5fO19 bHXTh7G1SdlJbR6xv1d9L20tvG93aVrF3JZrJcvIkkcCwxGeKe S4uZtt1JLsT93FI01xJ9kjSEpC93dur2TJIznb+2vwg/4IE/tx/Fr4a6T8R9Y134R/CmTxHoUOr6H8MviVq3jAeNHs9RslvLD/hK18OeGdWs/B2oX1pdRRy6PdXmsapokolttX0/TrgT6Zbfj58MPEtn4J+J3w88batosfiPTPBXjzwR4z1Tw+TDJc eJbXwd4n0jX9Q0KczTrbvPdWtrLZwtKwRxPBIVuUikdv9ML4Rf Gv4W/Hb4c6B8WPhT410Lxj4C8SaVBq9hrul30EkNvBNAJ5bbVot/naPqdh88OqaZqSW17pt1DPb3kMUsTqNas5wtZ2b3aSt006q3kt rWMXOXxLvdtaq/Rfdbf0W1j/Om8V/D/AOOn7En7QOn+HvHGhXngr43fBnxZ4Q8bRW8d3b6lDPqHh3U7fx T4S1jQdascprHhrxAljBHa63buDc27z6Xfw22oWeoaZa/6MXwb+KHh/wCNfwn+HHxd8Kvv8PfEnwV4c8aaSpfzHt7XxDpVtqX2KdgqZub CSd7K6G1dtxbyrgYwP4v/APgun+0H8MPj1+1zpVt8LNUsfFmk/CX4c6X8N/FPivR3s77RNZ8Yf8JR4j8QXum6VqUMjQ6vZ+FI9UtrO61CGSSx i1ObWbeGRxp8sp/qV/4JeeCvEPw9/wCCff7KXhfxVbzWeuQ/CjStZubG480T2Ft4rvdQ8WaXYTLOTKkljpWt2Vo8bf6swlFwqq KxnJzjGT329VZWf/DdGtSq0eWNNvRySduyaXTprrvo2720S+9aKKKyMAooooA+f/2pP2dfBf7V/wABfiN8BPHrTWuiePdEazttZtIY5tR8MeILG4h1Pwz4q0yOVkj kv/Duu2dhqkVu8kcN6lvLp9y32S7nVv4Zfiv+zn+2/wD8E0Pizc661t8RPAmtaFJe6d4a+PnwuXxDL4F8Y6BdSATT2vi a2t5NK0+01CCS3uL7wR44j36dcqtrfabdWtlZ6hf/AOg1TXRJUeORFkjkVkkjdQ6OjgqyOrAqyspKsrAggkEEGmno1b f+v6/4cuFSUHdejT2Z/mrfHz9rn9ob9qQaU/xo+N3jL4tWfhy4efSdM1HUNM/sHQ7qS3Njc6hpnh/Q9N0vwzb6vMkgs7/V5tKN1ChK/a1s53hm+X42EUw2QRLLbmW4nimLSvE0KSfuort5ZvtJjgkAxHB HGYkSOIpcOjn/AEqPif8AsR/sgfGf7S/xP/Zo+CnjC7u2le41bUfh34ah16SSbBklPiGw0+z1xZSQGEqagsiu N6uH+avzm+Jn/Bv1/wAE+vHL3F14U0n4sfB+/ZZTZP4C+JeqanpthPIpUSR6R8Rrbx1amJQSPs8ZhXYWVHjJLVU XFX318r21T3v0s3ouyXW9Tqc/TlXZdNtkrK2n636H8OiXEMymK3Z4obJ22oY45ob0fZJLfzpJWi eQTZT97GsK3DzvcO6TqqmSKK4WS3RWEsdu0ce+J0UrGknkCG2j s5ZpJHgklWCbIW0n83y28rN0ZE/qK+JP/BtR4mghZvg5+1npeoRpcS3EGj/FL4YSabOcqqJE/ivwP4iaBCyjDzx+Bj5YjhENugQBfzz+JP8AwQg/4KKfDNri40P4eeBPjDpdpDc3Elz8LfiXoz6pdyzSl/I/sr4jRfDvU7wkSBd9v515GUkkQuwjlG6lBq11q0301ulps9benf TRSpuLXK+2t2npbfW2/wAtNeh82fAb/go9+2r+zhb2Gn/C39ojxvaeGtOaCzs/AvjFrP4keDCpmmWW2sdM8XQeJG0l5/LfyotCv9KTZGslq+A5P3/4X/4OH/249KhS017wh+z94unSLBv7jwR4s0uadk37p2j0P4jwQKG2vlFs YdghLGNfOVV/JH4k/sq/tV/CCKNPip+zh8ZfAESwpH9t1X4aeOJNHiCvNAslrrWkaRqHh2KBJ IEOyG/kixGIYrmSG4Q18+ancxQFrOeU2mouk91Ja3DCFyVdZ7gyW16bY xSQlDMl1IDGi/ZRC6h2lo9lCdmml1snp0ts0+r1dlZa62NlUj9qEJbK9tbq3l+V 189/238c/wDBfT/goH42tGtPDeu/Cf4XyTxO/wBq8JfDOO9u1t5H+T7NdeO9W8aW0TbN1uZhatOG23MSQsoz+W/xf/aK+OPx+1mHXvjd8UPG/wAXNatiJdGn8X6xq+p2GmST3ExMWjaReJDoGiCNE2vbaHo2nJO DE8sc6CMTeSaNo2u+LJmt/DegeJPEuq3G+OKx8MaBqHiCc3PmCPyni0K1ugbws42Pb2b75Z1 EgVDLMv3V8LP+CXf/AAUI+LwsofBX7LXxH0qwubcgaz8TrXT/AIW+HFiuEjV70SfEK90HVrrY6pcB9P0K5lI3rZJL5cavfJSha1 la2rbutN0277q26evqNVuVJxhGO6uko3232vf1ezstz4GWedle NJjcqvnKpXcTl5PtG+4lSS7RbQ2oknMImnIklCRBcuqxw+bC88 cQBkERkuLedy6w2yEK9tZo0ISC4mlkSWRBbCBj5q74gl21f0R/Cj/g3E/am8Qpp0nxd+NfwW+FmmTRIb7S/Cmn+J/iprto0XMJNvNa/Dzw49yjEyKI9XvbGCXzTFC4m/d/pV8KP+DdL9j7wkLa7+K3xG+N/wAaNThctNBN4j074c+G54mU/wCjGw8GadB4o+zo5ZoUm8a3DRoRGZHVRSdWmtnfTTlXppr/AMDa+miMJTcm222/O7v20d0kt7d/lb+KZHsLO3R7m6e3S5kCTO8yMsXltFIYQbpzLHJK0UM7JC8ieU rqk8m4QV9GfB74I/tK/GL7VpPwS+D/AMZfiBp+pwPHqUnw/wDCXjTUPDetMrvAh1PV4baHwsYljVmC61qCW0MIEu95pt0n+gD 8I/8AgnT+wz8DJorz4Z/st/B7RtWhdJIvEOreFLTxl4pjmQACdPFPjU+IfEKXBAAaZNSWRgAG YgAV9mxQxW8UcEEUcMEKLFFDFGscUUSKFSOONAqIiKAqooCqoA AAFZOtfRRWy36NdV6W06ruEZyg7xb+fX5emjV2fyOfsAf8EJ/if4i8YeHfiR+2xoth4I+HHhu7tNWsPglFquma14v8fT2whuLCw 8cah4furrSPDHhVZUjGt6Rb6jqeueIbdZtGkt/DFm8stx/XHFFHBFHDDHHFFEiRRRRIscUccahEjjjQBUREUKiKAqqAoAAFS UVi5OTu3fp6Lol5IJ1JVHeTv0S6L0CiiikQFFFFABRRRQAUUUU AFFFFABWFe+F/DOpXDXeoeHNCv7pwoe5vdI0+6uGCjChpp7d5GCgAKCxwBgcUUU AXtP0vTNJhNvpWnWGmQM28wafZ29nCXwBuMdtHGhbAA3Fc4AGc Cr9FFABRRRQAUUUUAFeAfEv4WfFDxj41s/EfhL46a/4A8NW/gLXfC934D0/w/Y3mm6p4j1PU7K8s/F8+tLe2OtWV1ZWNtLpHk6fNBeQW8xu9H1TSbx7mS5KKAPFL/wCBf7aEia1DY/tqWsMLm5ufDzH4GeCknt5raysf7G0zUp5Lm9nl02XUzqsmt3az 3Gp3Fj/ZcELh4r1rr3z4GfD/AOKfw+8O39j8WfjNqHxp8QajdWN6ms3vhfRfCsOihdLtINR0nT bPRFSK5059XS+v7O5vU+3pbXUNlcPN9kSZyigD/9k=[/img] Eurospare EBC8331 $2.91 each at AutohausAZ [img]data:image/jpeg;base64,/9j/4AAQSkZJRgABAQAAAQABAAD//gA7Q1JFQVRPUjogZ2QtanBlZyB2MS4wICh1c2luZyBJSkcgSlB FRyB2NjIpLCBxdWFsaXR5ID0gODAK/9sAQwAGBAUGBQQGBgUGBwcGCAoQCgoJCQoUDg8MEBcUGBgXFBY WGh0lHxobIxwWFiAsICMmJykqKRkfLTAtKDAlKCko/9sAQwEHBwcKCAoTCgoTKBoWGigoKCgoKCgoKCgoKCgoKCgoKCg oKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgo/8AAEQgAKwBkAwEiAAIRAQMRAf/EAB8AAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKC//EALUQAAIBAwMCBAMFBQQEAAABfQECAwAEEQUSITFBBhNRYQcic RQygZGhCCNCscEVUtHwJDNicoIJChYXGBkaJSYnKCkqNDU2Nzg 5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SFh oeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsf IycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX29/j5+v/EAB8BAAMBAQEBAQEBAQEAAAAAAAABAgMEBQYHCAkKC//EALURAAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYSQVEHYXETI jKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc 4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDh IWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMX Gx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/aAAwDAQACEQMRAD8A+qaKKKACikJAGSQAO9Ymr+LND0hSb7U7d GHVVbc35CgG7G5RXnNz8YvC0DYWS6l90jGP1IqfTvi14UvWCte S2xP/AD2j4/TNVyvsTzx7nf0Vn6brWmamgbT7+2uAe0cgJ/LrWhUlBSMQqksQAOST2rnvEvjHRfD0DPfXkZlA4hjYM5/Dt+NfPvxB+LN/rbPbWjm1sunloeW+p701FslySPW/HPxV0zQlkt9NKXl4BywPyKf614Jr3j3V9W1EXMl5MJQcqUYjZ9 MdPwrjpria6clifm7k8mt7wn4avtev47WxiLFiMseij1Jq9FsQ 23ue5+A/ixF/wj0UfiHzJb2NinmqBl1wME+/UfhRXTeGPhhoulaRHb30YvbnO55W4GTjgD04orF3voWuY7HU9U stLtzNqN1DbxgdXbGfoO9eV+LfjTZWYeLRIfOccedLwPwFeQ/FK/1KLxXqtrfSyebbTmPDOTlDyjDJ6Fcfj9QK4CeZnzlua1iluyW2 9jtPE3xF1rV5HNzfTMp/gDYUfgOK5GfVLq4BVpWweuTVA5JwKuW1jJOyrGpZmOABzmrJa7 kkELSLuLsfbNXreyEmNlwVb3rr/Dvwx8RalErw2qoh5zIdtad/8JfFNsDItkJwP+eTgn8quKXUzd+hwbRX9q37qbOO6nBok8S6xH GY3vbkqOMeYcVq6no2qaa/l31ncW7+kkZH865m4sJ3Y9evpRONtgi+5FLqVzcMfMZyfUnNMi haR+csa6Dw54K1nWrhUsbOWXJwW24UfU9K948BfBu100x3WuFb i4HIi/gX/GsnpuaLyPM/h78NL/xDJHPcI1vY9d5HLD2/xr6R8L+F9P8AD1mkFlAiY6tjkn1JrZtreK2iWOFFRBwABU1Q2W o9w/KiiikWeHftF+DmuooPEtknzQoLe9CjP7sn5X/4Cf6elfOv2Cdp2RlO8EqQPWvveeGO4gkhnRZIpFKujDIYHgg15 j4Q8K6GdQuJ206EyieQAnJwA2BgZxVRfQiSPEvBfww1bXZEYwt Bbnq7jHHsK9+8G/DDSNARJJIxPcD+Nxmu9hhjhQJEioo7KMU+hy7AodxsUSRIFjQK o7Cn0lFSWNlijmQrLGrqezDIrPOg6QX3nS7Ld6+Qv+FaVFFxWG QwxQIFhjSNR2UYFSfhSUUDFopKKAF/CikooA//2Q==[/img] Uro CCC2800 Right Upper Hose $6.87 at RockAuto I think that the springs from the XJR would do just fine on the 12. If you're going that deep, bring the rear sway bar over too. If you're really ambitious, swap in the LSD from the XJR. The XJ12 has an open diff. The front sway bar is the same on XJR and XJ12. Uro Parts makes bushings for the front sway bar and drop links too. You will want to save the oil cooler from the XJR as a spare. It fits the 12 and they are hard to source. Why not try out the XJR wheels on the 12? Maybe they are in better shape. The originals might be able to be sanded down and polished like Michael Medina did with his XJR wheels. They look stunning. Or you could send the originals out for refurbishment. The 17" wheels with shorter rubber will firm up the ride if that's what you want. Should be worth trying out just for fun. [img]data:image/jpeg;base64,/9j/4AAQSkZJRgABAQAAAQABAAD//gA7Q1JFQVRPUjogZ2QtanBlZyB2MS4wICh1c2luZyBJSkcgSlB FRyB2NjIpLCBxdWFsaXR5ID0gODUK/9sAQwAFAwQEBAMFBAQEBQUFBgcMCAcHBwcPCwsJDBEPEhIRDxE RExYcFxMUGhURERghGBodHR8fHxMXIiQiHiQcHh8e/9sAQwEFBQUHBgcOCAgOHhQRFB4eHh4eHh4eHh4eHh4eHh4eHh4 eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4e/8AAEQgCWAJYAwEiAAIRAQMRAf/EAB8AAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKC//EALUQAAIBAwMCBAMFBQQEAAABfQECAwAEEQUSITFBBhNRYQcic RQygZGhCCNCscEVUtHwJDNicoIJChYXGBkaJSYnKCkqNDU2Nzg 5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SFh oeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsf IycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX29/j5+v/EAB8BAAMBAQEBAQEBAQEAAAAAAAABAgMEBQYHCAkKC//EALURAAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYSQVEHYXETI jKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc 4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDh IWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMX Gx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/aAAwDAQACEQMRAD8A+y6KKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKKKACiiigAooooAKKiurm3tITNdTxwxjq8jBQPxN cbrnxS8JaY7RJevezD/lnbJu/U4FJtIaVzt6K8N1747SROYtP02xhPZri7Eh/75Sub1D4r+M7qMsl+1uh7wWBVfwZwP50uZD5WfS1FfJt74/8RBTJda/rUgPaIhR+e6uevfiTrZci21K/xnrNfEn9CKXMPlPtOivim1+InjDfmLWrv6Lenj/x6tmx+LPj+0wRf3cgHqBKP5NRzByH17RXzFpP7QPiWBwl9Z21y B1zHtb9CD/47Xc6B8fdAu3WLU7Ca0kPXY27H/ASA36U1NMXKz2Siuf0Lxp4Y1oL9g1e2dz/AAO2xvyOK6AEEZByKokKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAKKiu7mC0t3uLmVIYkGWdz gCvHfiB8YxFM+l+FYWuLggjzsdPcZ4A9z+lJtIaVz1TX9f0jQr Yz6pexQLjIUnLN9B1rx/xd8b3klaz8L2ZeQ9H275D77RkD8ePevJ7iXV/EuoNJcTy6nMzfNskIgQ+hk6ufZPzqS+fw9oELQapdfbrhOWsLR QsaH/bGdo+shZvas3O5aSH6pq3ivxLOZrzUJJMnG1G80j2zkRj6Fyfa mN4chto1k1u6htI25H2qblvdUG3P4I9Yd94z8SahCx0S0XTbMD Alj4OPaVuT/wAACisSDQ2vrSXUNU1GWc8tNuLY+px292J60k7DOsuPFHgzSCY rW4nvJR/DBH5IP5AH846onx5eysTpPhoKB1eQkMPfKlM/981maOq+UbXRdOuLuIf62W2gWNOOuZG4zj6UX9zqMMZhnOlWMH 8PnXiNj6iPJJ+tFgLN7rHijV48y2sDR4JAZIiRjr1G7v61zNza aqrjdppRn5UFtuR6jJ6Vduv7Ma2l+0ePZpDJhnt9OspjHyeRkl R+lcfqdtALwrp+oXE0GB888YjbP0DH+dDA2tSu73RmZbi3e3lR tpVipw3cdTUmn+K55JV/cRP04dEwfyUGuSninceXskn9O+P1pkcF1bSB2t5EyMg4NG4z1R fEkSx41HRRsx/yzY4x+ZH6VctNY8MXyCLzFiGfuSoCB9OmPwWvM4NZu1wjSAM3G WX+vFXNPt7/AFLVI4IRFbTIu7eUwSP60N2BI9Rh07pNpl0SOoCNvH5HkfpXS+ GviF4s8OMqLePLAvHlv86fkeR+Fee2OnPbxqZpl84dZIQYjn6D g/lWgNR1GEbZmj1CP0lG1/8Avodam43Fn0Z4Q+M+i6lsh1eI2Up481PmjJ9x1H616dY3lrfW 63FncRTxMMq8bAg18SRz2N1KFjZra4PSKb5Sfo3Q1v8Ahrxb4i 8L3m+xupVGctH1BHuvQ1opvqQ4dj7DorzD4f8Axf0fXdlpqxTT 7w/KGJ/dsf8A2U/WvTkZXUMrBlIyCDwatO5DVhaKKKYgooooAKKKyNd8S6LosRe/v4YsDJBYZx/kUAa9ISAMkgCvEfGHx2toZZLTw7Zm4dSAbhhlPfA7/oPrXlXiP4j+NtbUxz6rJbxZJCxNsPXuV5NQ5pFKDPrHUvEGiab n7dqtpbkDJDyqD+tctqXxb8D2LlG1dZWA/wCWSM4+mQCK+Rp/tU7mWe8dyxySByfxNQmyLZO6cj13dKnnZXIj6du/j54WjJENreyYP9wD+tZVx+0Ppa8Q6NOx/wBqQD/GvnU6ZnP7pz65kNMOlnHEEhz/ALZpObHyo+hF/aLt8EtoODjgefxn64/pVyz/AGhtKdwLnRpEX1SYMfyIFfNL6W0YxibrnIINV3trhFDJK+3sGS jmYcqPruw+Ofg+4YLMl5BnqSqkD8jmuq0r4heD9SUNb63bLk4x KfLP/j2K+GopJ4my0Ecgxjhua07bU9PFuql7y1uAcEudyHj6DvRzsXK j72t7m3uEDwTRyqeQUYEGpa+JtF1nxDpyfbNJ1N2Qfe+zzEkD/aA5/MV3nhn46eIrDZHqcUV9GOpcbWI+o/wq1PuLkPp2ivPPCHxd8K66FjnuP7PuD1WY/Ln2b/GvQIZY5o1kidXRhkMpyDVXJasPooopiCiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKACiiigArB8ZeLNI8K6c13qdwqnblIwfmb/Ae9YnxR+IeneDrExhhPqMgxFCvJBPTjufavBNUXVdb1Ual4kJu 9Rlw8Gns2UgB6NLjqfRf6VEpW2KUe5d8a+N9b8ZSCW5nl07R2Y i3ijH7249kXr/wI1iSWNnaWKT6ywsLBz+7s4yXluWH97HMh9vuima/rdj4dlky8epa2QFleTmO39FIHU+ka/jXn9zq2p63qjqgkvLyb5Xdz0Ho2Oi/7C8euazb1LsdF4h8X3Mtv9k01Bp1of3YjhfDMPR5B/6BH9CaxLDTI5Jllvp4o4QT5e8bY8jrgHqfzP1qpPcW2kuUdf7R 1KVdnmYyE9owO+OOAQM1HNNqWtalDaQxTfaXysFpbt5kqr1wCf lRR+J7k5pofob2oeJtFsJLdbt/tEMR5Em5dwB6AcM2fomPU1V8YfEIeILSOz8P+FrfTtMhQKGuJA kbNzliOMnn1JrO1HQtN0HUVste1uysbtsGa2s0a6mjH/TWQ8L78sf9mumktND8P+En8VWkVtfLkR2jeb5jyuTj77cqFwSd ioeMe4G0Ghxen6F4h1FEmd737ORlSmy0hYdyJJCMj6A1b0XQtJ i1FjfWtjeLGu5minkunY4OF7LnPfBFcZr3iLWNe1Ga5vb6Qxxj JQcJx7d/xya3tO15dI8A2lxDbxjUrm/3yyt94pkBce2OMUJX3Bux0EvjLSNPQG38LxQqgyDLJFFx9Nua1 NPv7HxFqWjzeIFn0TT5CzOFu9iTLghQSoGzLYGTj86wdb8KWNx qerMpuZGt7mOYIVzEscjovXPB3P6Ht+Hqfw5tdD1LxBr663ZW9 9Z2ulJI1vMmY9sexuR35X9KQ+hz2u+BbX7XNIkr28DcwwKXZVG OzFyzfnXnurWVxpOoNbPPJMgJ+ZJXjwPXBzkfTI9a6iz8YPAnn +H9LkttMEhV7OSYzWsi/wB6NWy8B9gzD8sVNqF9p2s237pQkpO6KK5+Rw3+zIOG9jwfY0n oSefahq9jp9zGlzPJIjqGIVFl4z05AFa1lL4fvUhfSL5Y7gnKQ vvtWZvQEMyZ+uM1geMtHhZWu/Le0w2Pu5UHvuA6fUflXINI4nHVcEA85xVWQrnqlv4jkiuXtZ77 y5Y2KNFexg4YHBHmJ79yK2RqgjQNfW72yt0lDb4m+jjj86yNS1 K3stF0pr3QxqCXNqJrmXHzKx4yTg8nr2qjZ/YmU3nhfV7u2JYCSwmXchyeeuR+PP4VD0LUmdewhnh6LJGwzg8g 0+0ubu2Kxxt9oiB4hlb5l/3W6j8adqHhq705V+zXMdtcsiu9sR8uSM4K5IBGeSMc/wANYQ1p7K7W31uzNtltqy5zE59MjofbtTs0VdM65Ggvrt43drO 9wOJl2MD2DD0PrXd/D74pa34Sul0rWkkuLMY/dufmUeqN6fpXFaaLPVLF1uI2kVP9XufDJ/1zk/8AZW4NV5L6BFbTtVJurQH93cldjxH0b+6f0NNO2pDR9j+GfEGl eI9OS+0q6SaM/eH8SH0I7Vq18W+H/EGueCNVS+028ZoCcB/4XH91x6/5FfS/w7+JWk+LtO3RYhv4lzPbFuR/tL6itYyuZuNju6w/FHirRfDtsZtSu44zztTPLH0Ap8+rW0sZQsVB4O1sGuYu/Cvgq9umur3TGupmPLy3UrH/ANC4p3El3PO/GHxj1a/LQ6HbC0g5HmyjLH6D/HNeY3keqa1etPcNdajcucngsfwAr6atPDHgeBw0WgWef9sFx+T E1vwDS4oxFb28MMY6Ii7R+QqOVt6lXt0PlO08F+KJl3poN9g9N 0JQf+PYFSt8P/FqqWGjopPXfeQL/N6+p2hs2/5YR/lUMltanpGopcoczPlSbwP4yzhNPsM9h/aNvn/0Os+88GeO4wSNGLj/AKYTRy/+gsa+rrnTLGVSskETg9QyA1h6j4L8O3nM2kWTHqGEQU/mMU+TqPmZ8o6jpfizTRuvNH1O3U/xPaOF/PGKxjq9wrY88Bh1GK+p7z4dWEfOlalq+lMOQLa8fb+RzXIeJPA 3ivljdaT4hjAPyalZJ5re2/Gf1FJxHc8MTWrjJ+dCD1A4zVyDWjuXfEoA75zWz4i0HRrWQx6/4V1LQJSeJ7GYyRH/AIA+c/gwrnLjws8i+Z4f1q11Revkt+4nH/AGOD/wFjU2A0hf6ZcZM0ABHPpinGytLiPNvIF6/L1FcjcvqGnXDW19aywSp95JUKsPwPNTW9/GfWM8cg8UmO5ty6VdWria2d0IJw0Tcj3wKtW+vyKVj1bT0vdgK 7wNknTAzx2qlZanKpwX8xPY81eF7ZXassyDzCMHjkUAXLOygv8 A99o94spJ4hf5ZVPGAe3frW/4P+IXijwrdAWt5I0SnD28vKnHYg9PwribvSlcCSzc+ZkBQOD+f Q1Gus3KlbbVQZo+nm7fnj989T+P6UwsfWvgD4zeHvEPl2uokaZ etxhz+7Y+x7fjXp0brIgdGDKRkEHINfA4UGI3NvMk8IP+sTt9R 1H4133w4+KniDwpJHA0xvdOB+a3lPQf7J7GrU+jIcex9eUVzXg jxtoHi60WXSrxTNtzJbvxIn4d/qK6WtCAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKKKKACiiigAooooAKKKKACuA+K3xBt/C1p9isf9I1ab5Yok5Kk/1/lVr4p+NoPCml+XAfN1K4+WCJeSCehx614TawXd1qD3965udTuT yc52A/wr/U/06xKXQtLqyG0ttQutVbUryT7Vq8x4kb5ltweyg9T7/wCTzvi7xfBpqy6bodzvuHLC4vw/zM38QjY9/WQ9O1V/iJ4xjs7WbStKm3RnKXNzGeZj3jQ9kHdu/Qe/j93ercS5um+TGREvAYDpn0X2rO5djelc3j7muPJsl581QS0nqs Y6892PJq3NfwS2YhsIk0zTF+/Ix3u5HqeNx/2VwB3JNZTyTXDQC9hknnlwttYRA7pM9N2OQOnyjk9627rwlqyW VzqN9cCeawKLdWdpD5kdkGB2iRgcDGBkKGwDzigenUTTba+1Qt FpFrKkcgxJcScySD3PZfYYAre8Jm/8FXWpa3Z2kGqEG2tXiWXEjrKzYaJhkfeUAgjncK5nxbe+Jfs6W DW32LR1VfNezI/fqeh3E5x7dB6VsXCNaeHL3RYrgSx/ZJ4I3DE5ETC4hPP+7j8aEh7qxi+LPA2mXF5JOl9qnhy+mcs1r4 gtniDMT2m+6efXmuU1jwv400RYINRjmOnBi0UofzrcZ/iBUkAHjnivo3x98SNZPwn0mbTJ4pHuGhW5kubeKaNUdfulHUgg n6EevNeHaF4k1S01u5FlqcGnyeb+8tY4wtpJ6/u8bFz7AGi5mZ0Vje2elPb3Ng6LMPmuIiJFI9TjmuY1nVpL7VLe EFhDE6qo9gRXul5fWU1rCbm2s9JvpV3KnnKYZvdSDlT7MK888b aDbSzpdpamzvw4JTgCXB/ImndrQGejpYS3F14nvEm2pbJZM6f3l8+IfzIP4Vt/DKOO91jxjHPOtus/h2WAMxwAWARfxJIH41y97rE2n6n4gskzsvYIEbAHG143/kp/Suk8DzSWD+OL23Yo0Xh0spB5ViVOai6L6HnPhO/h03RPsdxbMyxhpJXiO90B/iZMbtvTkbh64rQ1K3S80mWG1nVEuFBWZFDj2ODwa5jw5JHfX8f nvcRvCwBmhdgY1H8SgdwMmrkPjHR4tfl0xLK5ltg3F3Agyf8Aa ZF4IPqAD6jNUQ7GLq0+s2emNaapILiNcrDdRHnH91s8MPY4I96 5u1hmLYdHaMkDcByuemRXoOutZXcbz6VdRXG4YkTqHHoy/wCSKvfDvw/peoGS6vbe6t2thvheI/LkfwsD1B4p9LiOij0rz4LW1aMTBJUtolIGN0Uaj9TMf++aa9od U1iXw7o0MKQRRTl5YxsaV0j3AkjsWCitZZzDY2jxuS9vaPdOfR pS0in8pIx+FZXhlv7L8M+JtbQ7JUso4Uc9pJQZOPwjC/8AAqn1NdkQ6f43sL5H0rxBL9r1K2k8o6haR4WbBxllJGf94dfQ dzxFf6dBp4kkhF5a7WErhugGOMEdRn7rA8fdx1ryNIxB5msysU t7VgGYcb5CCVjHucH6DmmWni7Ub2WZbuG0ks5UCTxlCgIzx8w5 BGOD/OhK5meo+G7s2UZu/D1wNR00fNLZltrxe4BOV+hJX0bPFdVFLY6oTf6RNtUfLLDJ/rIieqkHqPY814t4Zk8lt9nM6Op3xur4kjHYgjr74r0Dw/dS31zA5eO21UkCG5VQEnweEkXgfQ8D/d6mmUpHaTaNKLQmzgMkRX95ag5SQf3oj/7IeQemO/MNJqHhy6h1rRruZYFfMcyHDwt/db9evXn3FdjpHiO3kv3h1CF7K7J23lqwO0kceZGeCD0yOo/LM2v2CJceanlSC8XAfjy7sH+Fuyv0w3fHY4IWwHV+GPH7+LNLZ rQiLW4E3T2ini4UDmSL37lfxHpVE+P5VBLSYIPKk14xrdreeGt Sh1PTJp44Vk3RSAlXgcfwt3BH/wBeu+0CXTfilp08+myxad4utRvu7JiFjvMf8tE7K3c9j145qr3 Fax1afEWdc/MCR2zitGD4liP77kgDsc14XqRvdPu5bK8ikt54WKyxyLtZT6EV UGoyKudxJzUuQWPpnT/iXZyBT5o56c/0ro9P8b6fcYBmQnOMg85r5LtdY8qXfLCs3y4AdmA+vBBqxH4ju IpQ0crY6gbun0p8wuU+yLbVba6XMMyt7d6kNwM4J5r5O0zxxqN vtaO6cOvIIOM13/hj4r5ZYdUUFMcSr1/EetPmQnE9vedTVeWVGySR+VcrZeI7O9txNa3CSoe6t09qe2too OG3AfWqvcDW1KztbqBopkjliYYKuuQ31rzHxn8J9Hvi9xpgOnT 5zmIfJ/3z/hXZHW4yrMrjae9V31wE4DZI5+Y5FS9dw1PAPEmmeJNAj+y6zbJ qenAgKZF3qB6BvvJ+BFcfdWNlcsX0+T7M5yfs8zcfRW/x/OvpvVru0vFdbqNGDcYIzkfTv1ryPxl4QtGLXWmMkbHnyv4Sfb0 qLFJnmIlntpSkgaNgOQRV+21KNiBOgPvSXkD7jDcISV7H7y/Q1n3ETR5fhk9cdPqKVx2OmgvXEWEfzY88AnkVa863uI3jlQFe7 ADetcbBcvCQytx1xWrZ6jFMQJCUkA6incC+1nfae732mSM0Y4k 29MejD/IqxaXsV+7CJVgulA/0YZy3qV/wpEdnhdoZTFIOhVuvaqdxaRXTJsPkXS8gj5ckemOhpPQDa0vWt R0u7jvtNuJIJozkFW2mvo/4N/G3T/EOzR/EEyW+oqdiznhZD/tdgffp9K+U49ULSpZaiqw3CEgTYP7zno3v71U1Jbmxuf7RsmeC 5hYMQpIYEd6qMuqE1c/SEEEZFFfL3wA+Pe5odB8VzloydsVyx5Q+h9R/L9K+noJY54UmhkWSN1DK6nIYHoQa2TuZtWH0UUUxBRRRQAUUUU AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF YPjjxLZeF9Cl1G7cbgCIk7u1a9/dQWVpLdXLhIol3Mx9K+dvF+uT+K9ebVZziwt2KWUR6MR1c+oH6 mplKxUVcybq6vtY1eXWdVLPeTH5E6+Sp6KP9o8Z9On05f4g+JU 0u0n0u1l2zEbb2dDyv/TFD6/3m7dOvTS8Za9H4c00lZdmoTRl1Y8m3jPBkP8AtseFHrz2rxeIT eIbqS4nlNtpsGS7E5wv17n1PcmsTRGPql5c3zPKqYSMAADhU9B 9fQf/AF6taNpVxDewwR2z3usXDAQWoGSjere/14Xvz029NsLq81OC00bT2lvZMmxtO1un/PaQngMevPT69Dxbcx+EdPutH0SdrzU5f3WsavGpKxk/8u8Tfwj+8ep6eweyHsOutXh8MM2k6FcxXniS6by7zVQw2wEnBi gJ4HXBk/L29f8ACsum+BPh9cQXjLJAsDSXzkZ+0MeWHJ5J6D8K8Z+CehWm q6pcapfKkkdltWOJuhc5wSPYCrfxr8bTz3Uvg/R1Bj+VLtwMs78HYPbpml6Es3xeReK/h7JdW0Pk7mmRYy24xje21cnrhdtVrOOP/hGND1gDKSyGO6UDo0bgPn6xyIPwNafgKLb4VawdFR441LKOOSO f1Fc1onnrY3+mSMDDFfONvdSwYj8wF/Sk+pUXc5XVtevR4atfDU8rp9guZ4pVzgSbSCmfplhj2Fc5ZQXd 5q09zBdRRhj8xZwFOR6Vr+PNGiuPEU0yl/MeUXFyAR9yREcFQSOcs4P4U/SvBmj6mR9k1G+tLjtDdQBFc/7LhiPwJ57VWhJJ8S9Xi0+ay0dFt7yO3gRblJEyGkwM4I5B9wao aVqkd1ZpZ2l8yRZH+h3p3qv+4x6f+O++az/HvhnXLG8a5nt5ZB/FIBnJ9/SsvQJTd31tYlSjmQAkCqSZB7N4gjll8U6oyIWEUKs2B0AQc13n hFPN0z4hnGceHQv/AJDJ/wDZa4/X4rKHUNZu7p7lZHFtBbCIDaXkB++T0XCN+JHvXo3w+jhuPD/xFMY3ONGCFh/17S/1U1mja+h4H4av7jRSL5rKSS0j3jzViZhv24A4+oNcJHqDw6jNJ PAyQXDsyuFwCCe1b2seO/E9lozeHbDUmtdOUlmiiRQXZsZJbGc9uvQVVljTSbC1Z4JXkkRZ JhKd0bZ52lTV9DJ7lzRtJ1K6vYp9PbfuOVYHg/Wva9Pj1bSvBdza3jIJZgEhVT0LHAz+Jqn8E9LtYtLk1SKxSDz+ Y16hM9cVteOZJIo7SKKJpSZC5CjoFUncfYEA0nogjqzLuZki8K atebVTzBHDEF6AMS2B9AgFYHiG+e1+GEkTHEl9cKxHqpI2/wDfJt5B/wADrT8XSCPwtp9oCF+1XMkz+yDCj+TVzXxJlEcmmaY2VS2WWWY DsEVEf8pEuPzqVoay0PNPEYuZLiHRYZHJVg3kqeDK2Oo9cYpdc 0ptOnhsbe43q8as6jru75/GpfD1rdTy3PiyWZYhDcFlOf48Z49cZFbfwu0b/hKvEUpmj/dqwc4PGCelX5GR2Xwe8J6dfyWw1ZpUXduGwYJA6jPYda9V8a/DAWdoNY8OSm6sWxgfxR+zf49D7d9iXTrPQNLhtLG1iWRVAllxl mPpn0FX/CviCXS2kleRWtdp82NhlSMcjFFxHn2rXMd9b6daeIrCS0ZYBG2 rDiSCZXZV8xeu3aF+bsSexNS6ZcX2lXT+G9eiEkUgyo/hkX++h/XA+vqBmeJrDWPEF5N4p0e6WAkstvYO37qVMnMeDyflxz9B2qXw hqVnr+mR6DqHm26q4Wzkb/XadP2jJ6lCfun8PTC5rmmxrazpwn/0SYid5UxDIw4ukH8Deki9j349s+Tarb6p4X1+DVNGuHgurd99t MvG4A/cb+Vev6ZIZZLnwx4gVYr+D5lZD8sgHSWM/wAx/Q1zXivTJJrieyvyHkI/1gH3vRvxGP8A9dS/IaV9DpLbWfD3xV8JjULkCw1a1xHdSquWtH6Deo5aBj35KE46EA +ZeINKv9E1KTT9QhMUycjByrqejKw4KnsRWZpE2reEtf8A7Y0+ MNPAxjnib/V3cRGGjce4zXqM0+ia54ftPts7nQL0t/Zl8V3TaXN/HBJ6qD1B6j5hzmm9ULY8w3HFJuOOKu+ItJvtB1STT9QRVdQGR1 OUkQ8h1PcEc5rPDccGotYY9ZXUcGpY72VMBWIGaq56imt65xQ2 B0uj+IrvT5VkgmZG5DfNww9xXfaP40TUUEZZYbgDAG484/nXjDyFORxg9acl8VOdxDA5zTvYTR7nLrTjrLk9SSPvVVfWt2CZ 2H+zn9K840zxAJ4BBPMVlzlXJzn2q8184fBnyC2Qefb1qrgdrN rRIVTjGcYx0qlc6nuiYMwYdjjiuY+3uG+/yOmKha+Xk7+SOKL3EP8AEcMcxaVT82c5rmnfDEScHs1a89yGzl uP5VjXrLz0OfWpluUindQYP7sBSei9j9KqOxByMgg/lUtxMYlKSHfH6g8r9Ky5r14ZliuSMH/Vz9iPQ/40r9BM29O1ZoWEc3K9jXRQMl5HgsFOPlIHTpXBu2F54q3pepy2 cgw5KVWq0A6+9ihu4Vs7+NEYDEdwFJPXgHHXsM9qoLJcaZc/YNSfKqdsM/UD0BPcH9K0tOvbXUofKuSfnBAZB3PTp71Beoscb6TratJAwxDO pG6M9j05Ht/9an5hcw9RsJLO5Nxb/KAcsAfu+49RXvn7PHxnuNEeDQPEryPpkrbYZ3BzEc9R6j1H4j3 8NEtxp08em6mVKKP9HuO2DzgnuP5VPDGPN2SRnBHGRjy+/FJSdwaufo7bzRXECTwSLJFIoZHU5DA9CDT6+Wv2ePiu+g3cPhT xHdF9NlOLW5c/6hj2P+yf06+tfUikMoZSCCMgjvXRGSZk1YWiiimIKKKKACiiig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK5f4l+JU8N +HJJ0O67m/d26DqWPpSbsrglc4X4weI31bUh4X0+YpbQ/PfSqeg9Pr2/OvPtVv7XTNPk1GeL/R4MRW1uDgyv/Ag/mT6ZNXYbeSKP7M7h7y4bzbuQ/wB7rjPoorxH4xeMlvbsWunuTaxK0VqB3U8PIfd8YHoo96xu2ao wvEWoX/i7xK9olx5gd/Nup1+6e3HsB8qj0571Z1W8t7GwjhtYs2kTbbeIDJuZR/EfVVP5n6cwaJbLpWjukrFJZlEt444KIfuxj3b9Bk+lXdCtPtjX GqakY7aKNNiluEt4+mB7ngY/pQyl3On8Ha3pOmfDe8js9YsrPxbqaSNK985gIO9lUK7DBAAJBB xu615dPpfji20G70yHTXvNOnlEsr2TJcqSMc7oy2OgrZ+IQjPh 7TbaLyLyPTxKILmF+Ghdw209/lcyHnn5z6UzwP4d06+0y41qO40uZICFdZ7qSzljc8gB8hfocmj die5T+Fviyz8L3N7Z6wktsZ9uxnjOEIz1HUdR27Vv+CLAtbXGq XYtri5vJ2laaNgwIJ7EdO/FZXiHxVF9sXT4Le+xG2ySDV7qLUEx7Fo8gehDVv8AhTQ7PUWd9 Diu9LusbnFojmF/rE5dT+Ei/ShWYrHVeHFEWolQfllQjH6/0rktTjNh40vYypEc0QuB7svX+Q/Otgzavol9C+pWQuIEcZuLXIPvlDz+RIpvjTfZeM7G5hwZGtbuI AhSCXiIGd3GMkUdRx0OL+IomsdW067hZ0aW2aJmU4O4O2PyXZX QfBm81JzqEmrXsiQvYttkQkMPmAGR75qt8QrZbvwrp2oMD+4mh L8c4mhXn6ZgP/fVU9OvtP0vwZLFbX0UOoGZknjbO7aPu49juJ+v0ojoEjmNN8ca 5Fql3YTag15CkrBY54g+VBPGeCK2dCXS9e1eK7g0QxTxsC0scg VB9Qa80tpJLPVJLq+s5sO5YOwKjrXrPwmkiu9JuPKHWXkj0p21 M7l/x9eva+N7GzjSJlvUgGWQEghxjB7V7L8LpJJpviNp08CQzNZOWR TnBMFxxn04rxL4swtHrukakiBjHbhskHgq4bP5V7H8J7mYeJdZ iunR5tQ0lpyyjgqbaYAfgSBUpGvQ+Wk0dNU8az2cs0VvbpIzyy SttVUXk8/560eLryK9u1hs5TPGuEUjoQKz/FRx4iv1yR+8zj1pfCMiDXLdJFBBcAg0zN7n0/8ADSAw+FrWLbjbGP5Vj/EWeZNStYoGKk8PhwPl3x5Hvweldd4SjC6LFgADaDXlPxiumXxv ocQyRuZnwOi+YBn8AKbVxw3NfXVVPEen2WqKqx2iIsqA5xFhpZ W/BA3515b8QNUnupSz/NPcxRxyY6lmxNIo+skp/I13fxBgeHWtXdLt5zJbraQTO2SzTskTZPr5byflXmfiObZq1xe lOYQDGO3my5k/8dVgPwFKJUmVbOxkv7y10YTxxxwgmQlsLvblv6D8K9u+CGk2On m7ntISFJDFt+4HHTH4188Q+ZJcRxIzGSVwuR1yTX158NdJSy8L RKEC78KPoopozNS6a4vJCXYgHtXP+MCYraDSbXJub59vHXb3/wAPxrt4rZVUu2AoGSfQVxdxIplvPEspI8uMm3B7ZysQ+p5f6bD UyZcdzjvFN86avDp+mv8A8e4EUTBsAbfvP7DOTWdo3iO3k1K11 PW4o5LOB/KnnCEOwVWZBx98cDII9B3rJvJJmkuJogWlmP2aADqzNwcfn+tZ vi25stN36dHIHtdMt3DsOk1wR19wX2j/AHVB9aSNJOx31z4gstYt4715ltI/PH2e5Tn7HKx43H+4xyDngZ+tT3F/dTL5N/****m8uRf+eZ5OPdTyV/Edq8K0zU9eheR7jV2ggEe6SNVBVg38BXGDn0r1LwZ4gHiKzS0P/IXtosQeZx9tgHWJv9oY+U+w9ADTREZamvqdgL2IyRoXlVfmQdZ F/wARWJoGqr4dv7mz1Ms+g6kFW7GM+S38Fwg9V7gdRn2NdHYMxtV vbdyYg+1c8OrehHYg5B+n0o1/Q4NbsGa3RUaUkBRwI5cZ2+yvgkehB9BUoqSGmeFgPBfiiVFVSf 7M1HduEBPIUkfeicFSD23Bhwa43WbC70fUZrC+iMUsTFWB/n9Kk01ZdT0Cbw3fbzqGmo7WRPDywLkvF/vR5Lr/ALJcdgKt6NqB8VWH/CM6mT/b1mv/ABLpz/y9xAZ8onuwHKk9fu+lO19iUY+/I45zUbnn6VVLvBMYpMjBxg9qm3Bxkc5FZu/UZFM5BIPSs68lK9GAx/OtCYcdayr9CfUk85HantuBX/tJo9wJb/6/rW1pHiMykQzOOcYZuK5a6iY9M8nJGDzzWY3mIf4tucniqSTEz1 FtQGcB2UZ7etM/tDJ25Bxzwa4bTtYbiKUHK8AnvVyXUWQjPGRnOANw9c0ctmFzp3 1AbRg9TjkVTuL9W4zz9a56TUMr1IJPNQNd8cfT1ocQub73cbfL 2rNvwjxmJhmE/wDjv0rMN0x5GR60G8BGGYk44p8th3Hwyz2G23vGLwEfJL1x/wDWq55piYZbKEcNjrUdjLFMv2eRFKkcU6a0a0BWQ7rVjwe8Z/woTvoI19L1B7Vwd3yE13lhd2ms2X2a78tNq4D4wVPrwOa8phLQ SCJ+U7N6it3RNVuNPuUdJWGGBVh1FF3e4bnTXMXkltJ1pdkShl t5n/5Zk8/iM4+mazWa6sLn7FdpsdFBgc8+auM9f1H5V2AltPFWjSfaGVNQi XKPu++OABzXPWMX2oN4e1FfLuYifskmMsmTkqPx6emTS3QkyW0 nW5RWBwR1GOa+nf2afii16kPgvxDP/pSJ/wAS6dz/AK1B/AT6jt+XpXyTLJe6Vftb3cZSePhwTwfcf1963LG9lXyrm1maKWJ xJE6n5kYdxVRk1uNq5+jNFeb/AAF+I0PjzwuFunVNZsgEvI+7+kg9j39/qK9IrdO5i1YKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAbI6RxtI7BVUEknoBXgfizWz4i8T3GrPzYae3lWiHo 0nr+HP613/xo8QvpuiR6RZPi+1FvLTH8Kdz9P8K8kvZLPT7cxTOY7DTYWluH +nLfiTx7/jWU30LijmviLrJsdLOmxy7bu/jaS5fPMVsM5yexfBH0DGvC9DtpNU1GbWbuPzY0kCQRngSydl9l AHPoBXYeNL281iYW8nyalrbiedc/8e9svCJ+QH/fOf4qxr4OVstE0aMNc3jC1skXspOGkP8AvHv/AHR/tVCLQ3T7bU/EGo3P2C2ubqysjvubqNPlaQ9WJ6AccDsFHpWrJpN5rVzb6ZJBN ZaNaASN8uGuZP730Hb/ABNaXxW1jT/BfhCy8D+H7lfPQiS9ZR9/jkv67ic4OeAO2Ki+CHiGPVdGudFuJM3Fp8yKT1iJ5x/usfyYelMdzF8aSXESrBcRJKtomyVhGA00LE4dsDllJIJ6kY9q8 tvnuYWk0xpj5MUrSIhb5ckDn6kAV9Ca0tnZajb3uoWxuLSJzBe RrwzQSDaxB7EZBB9q8g+Imh/2XrSSSASJFN5MpTo4B4YezLhh7MKmPcTOKv8APnr85LKig+o46 V6l8Lkn07R5bl5HZLhTlHIIGOjD0ryiad57qSdgAZHLYHQZNey 2lzbx+BUuzGYAtuMrt2nOKuzMzktU8RC1vpJ4NSvYJGY7mt5Sh/GNiUb6DbXU/Ee6bXPA3hvXraZrl5P3bv5e0vIuVbKjpllbivGtZvTcXjMvCdA K9K+GUy618PNT0BiPNsrlLuEMf4TgN+A2n/vqk46FRep3Vrbpq/gBbJXaWe80DzkDHJjltm83A9jGkgHua808ZXQm8LwxpbWMIiIl kuEgH2iYMdpDP6KdoA969A0C5/sbwR4a1OziR76K5MpUHO9EwCjjtnYR9Ca4/wCKGhrpMd7YQuZLaJt9rIf+WltKBJC34goT6HPpRfqVLa5zFhB ZS6Qt7Z2MqBBtlLOWDEdSATgj8K9H+C7rLaX6BI1IIYbBgY+le feGUN34RaPcyNHKTuU4613XwAlhW71WxeRZJOCD3PWnszM6L4j NE+kDfuUQoomIUEmNyy4H4qK2PhLr0P8Awkmi31zJlru2jt7g4 wIxHIokH/fCE/iaofEmA/2HKeAkiPbuT6thk/La/wCdcR4RsdT0aymleO4+xsMGeTP7suNuR9Rx+VS9zWKujhvH1tL ZeNtTs5l2yQy+W4PqAAazdObZqMDjORIp4+tdj8b1W78bJ4iRA I9cs4r/AI6eYw2yr/wGRXX8Kx/A6wPqDuDbvdJjyUlbAJ9fc07GbPpP4fX7N4fcyvkIcKT6VwHxg 0ua51O11CM8whoyc4xkk/zxXV+G0lXw2pHOWG8ioPEqNeWGs2kpEk0F3cooI7rK239AtEn1 HA4vxYivrVrZIzLFc3EL7ickNFA2457/ADyD8q8w8QX/ANuYTqcfabia6KjtucgD8Aorr9V1N7m6huc5SHR5JFI7MFVSfz jrh9RTbd29tgAw28SnHqVDH9SaS0Q57knhaL7R4s06I9PNGfw5 r7R8Pw7NDskXj5M/ma+Q/hnarL47t0cZ2KWHHfFfa2jWBXT7VSPuxL/Kq6EHNePL/wDs/QxAZ/KkvHEKt3UH7x/AVwXxAvntbC10aP76Iskyg9ZGACr/AMBXaBXQeLZRrnjiDTY5YkihVhucAlQMncoPGcqwz6GvL/Gt+8esXASR5pg7KjFtxZs4znv6/lUSdzaCKAu1hvnuY5P3emRlYnB4MzZLP+HJHuEHeuF8UeZPNHY lduzbcXXPRm+4n1wc49znpXR65djRNJgKok0m4GONhuEshPGR3 G5ScdxGn96uT1BpkmlS4n8263tPeSk53zNnI98Zx9Saa0VyJyN GyghMqhwLy+JAht1O7n1OOg+tfSPwP+GFkYYtb1W3WCYMGPlLw x7geg+lec/s4eA5dRu01S6ib97yCR91B1b8a+t9PiW2hjggjCRRqFVR2FWlY g8V+L/g9/C2qyatp5ZtIvfmmwPukY+f6jgN6jB9BWVoxt73S5gqlby2G24i T/lvFnO4f7SkZz9K+gdcsbbUdFuLG+ZBbyDq/wDA3Yj+WO4Jr5t1vTb/AMI64pRJIZbUgruBG+L+E8+mdp9tvrUWtqaxd1YyfiTpcoht/GekyeTdQTpHePEP9TcLzFMB/dcdfxz96uI8SxDUYbTXtGzaPKzNGiNj7NOv34QfTJBX2ZfU17U 0mlrLFdzrnw9rkRtL6Mf8scng+xRyGB9/avJ9V0m58LeKdQ8M6nhLe5kWFpDwqyjmGYZ6KwbB9nz2FK1wsV tUuo/E+i/8JFCoTUIiE1WEAD5zwJlH91jwfRv94Vz9rdeW4WQ/Ie57VZS8m8O+IVvEtS0eGivbY/KsqHh1PpkfkRmofEtnFZ3ay2btNYXSedaSsMFkJ6H/AGlOVI9QaVuokWzhsEEHI4xVW4i3H27jFQ6bcj/Uv+Bq6wz2z3qWrMZjzW43Z6EcDjkCqs1puDHaDnrW68YJJwKia Ac8fWhMDmprNlkBXoOnHAqMo6LySCDn/GujeAFSMc/0qGWxEiMNvIFaLUOU5wuAGTeWIJPA44PHSjeGRlwc9iM1amtnW Rx5XzA54H6io2hY4JUsQeo6Z64qnYViiSC4wWAJ6HmkJ28gfMv TnOeKuiM8g4XHc1GtvI8fyxk5yAcdaN0Kw23Z1YENgjn0xXV6P cR3dp5E21jtwfcVzElvJGwQbiWGWOOo9au6eWgkEuSsn909+f8 A61JpW0KWhevLJrbEDHMbH92390+n+FR2rN8yTDlcDit8+VeWf zLuVhgjuP8A69YlxBJC7KW3TRj73/PRex/z/WoQNWNvw3qdzp99HLE/lyxnIrvtf01df0VPEFlGsM8ePNCsCx9/XqP1ryyPMirIgIdRkY712XgPxHJpl5DINvlO22VDjGPQ57U7g0 aVgieKdOGmtDGNbhYsjMMbySBjO4ZBHXOa5q3eWxujBcAp8xUx t1Qg4Kn6Guv8baY+hatb+IdLbNrcEyRtHzwRyDik8a6fDrXhqP xZYF5ZwQmoIBynA2Sfpgn86bV1oJMs/DzxVqHhHxTaa7pjZkhIWWEdJ4z1U/hX3T4X1uw8R6BZ61pkoltbqMOh7j1B9wcg/Svzn0K/YALvZHXBB719C/sw+PxpGvf8IxqFwxsdUfdCznAiue49g/H4/jVwkKcbq59TUUUVqZBRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAU2WRIomlkYKiAsxPYCnVwnxo1yTTfDP9n2jhb3UX8mPno D1P0/wNJuyuNK55T4o12TW/Fl3ref3asYLMH+GNfvMPqQB+BrivHl5APJ0WeQx20cf9pauwPI jXmKL6k849dvrXQQSWlqklzcEpY2UJlfPXy0HH4k/mTXlniO4nvkjguuL3W5v7R1AZ/wBXAp/dR/Tj8lWsdzQwprhp/tOr37eTNfZll28eRbrwFHpxtUfUVN4OvBo2i6n8SdTjUSkG00a EjjcRtLD2A+X/AL69Ky7u3u/E/iGz8N6ccPfOrytjiKBclSfbG5z9QO1V/jfrdpNqlp4X0gbNN0VPIQA53PgZJ9xj8y1Ky3Gzj9Tu59RnfUL yczT3DmR3J5JzV3wJPdWHiq0ubJZHYNiVVIy0ZGG/HHI9wKwZpVKRxg/dHJx3rofAljPqV/Jb26lpPKZ12nqR0H0JIpvQR7tqcKXlmjy7JI54/LkI+6xx1+hB/I1wniPTv7Q0IW8533NtvtJTn5nCAPE/12Fh/wAAUdq9I0bTZo/C0VlPIZLiGJUdiepA6/0+gFefaxrEWna95E0zRmeS3l27cqzIzqc+nyyGoKRwPhrSrPTL hrq6jadklPlFbdW3r2JLttX6BSfpXrOt2WgTeDE1DV75Y7S5jD CPyy7EeoKZAx9a8w+KmjT6dqF0bNnWBJXAVWzlM9OPQEH6Grvw 6ur7U/h5q+kXkKXem2brJEJFBMJfO7aeoycH8/WrTutSHoZtz4I8I6gobQ/FFuJCc7J2xn8CARXZ+A/DNvoWmzxvNbS3Mn33jbIYZ+UZ7AnAP1NeL2OpNaXklrJcMYQxC nqP1r13ws8f9mW0cGCrjzHI/iPvVWfUkt6JdsdCudEimjWaC9kfMh27M5ZTz0BDdKl1m3TxD4B yriW80ZPs8pxy9rI+Y2/7ZTMyH2lTsKg1bSrgPc69auu1Qhlj25+YHBJ9slT/AMDx2rH0fxKdK8RrqcxSfcGS5hcfJPG67XjYD+FlOPbqOQKz62 Z0WvE4PQgVtr3RnkW2nlO6LzDtVsZyM+v+Fdn8AtPvofFtzHLa vEUhzJ6deKtePvD9hZQxa3pAe80673TaXeMu7no8Mo/hkXPPHJGQMMMX/gFPJC2pz3GyG5mZIwQflIIyOemT2q077nO1Y9F8VW6XOg6pAFL SLbNPEB/fi/eD/wBBI/GsfWfHOianoRt00oMZrYIpVkAjyAcAkAkjpn1rq0s7mNnnlIEa oxcn+7tOf0r5blLNIcOdoJxzUtmkXY7W7tzq3hM2xhE91oty89 soYfvIJBmWLPOCpAkHs0x/hrl/DFtpw8S6eZ1Fk5u1iltywlkPzYPBI564q74E1az0rWtur273ej 3g8m/gRsOU7Oh7SIfmU+2DwTXW+Lfhp/ZfjGy1WfWd+k37JcaZrUUW6O4QMPmI7SD+JT0IJ6HNUmhS12Pd 7uCwt4PsunQqlvjsm3P4V5f8UtYTwx401a3aCSRbyc3SlWHG9R kdfUE/jXceH/EmhC6m0q51eK5mt2EYZEJLN/d4GCfccc1yv7QV74esfGgs9T05rwXFsju8EgjliZSVBBIOQQOh x0HPJpPVCR5ZqWlS2ot1PEeo6aREQMAB5VXr/wACrjb+2vUu7q58tuJX5P1r0Hc2tada6PZzvO1sHhs5GTDGOQn y1I/vCVlGOfxGK5aG/k3Mb+wlktZZCGI4Knv+RyKQ57nR/s66RNqPiea/ljPBVVOPfmvsHXbg6boM80eFdECR/wC8eB+przD4M+Fn0TTEv7mzeGMoJVLADdxxiuj8Va1JdafDFJG 0WbgcMfvYVjx9MVTdiEjx3w1d2mq/FzVra/JNtb2zRx5YgBkGeT9TWXeadDc680izFYEDytKvPlxjJ3j3Cgkf 7RUd6WDS3sPiRdzStKtrKjyylG25ARzj3ztrL8SXDaV4PtrFpP Ku9ZYySvnJitUY4P8AwIqW99kfrWdja9kcf4h1EX+qG/WNVJJjsYQfliUDaX/AKEX/AHc9qd4L0J9f8SW+kxqTAh8ycj09KxtTuPka82eWZiEhjH8EYG APwGBX0r+yb4Ezbrq97Fl5yJG3Dt/CP61olcxZ7n8OPDFvofh6FfKCTSoC3HQdhXTi3QHqa0kjUKFA4 FS21obm4WJeM8s391aeoBoOjR3MyXVwm6GJsxq38TDv9B/P6Vwf7Snh+O+sLTUIYA1yAyFumegAPfBztzzjIPHWvXppLewsm lldILeFMszHAVRXzR8ZPiBcat4gt5ba3iOk2x8tWaT5hv8Al/eL2R/un0yKc7JWHG7dzzHQ7lfLuNCvGY2s+Wj3dmwR+fbjuuKs+M9IP i34dm7kXfquiAWV96y25OIpf+An5Sff2pfGFn5FzBqtjvaOX97 Gx+9uAywPuQCT6Mrit7w1qiW+q22sagyz2Goq1nqCEYzE6gc49 jnP+yazXY1b6nhdwZNSsBPcAm9gP2a9yOWcDh/+BKM/7yvVXTZ1ntJPD13IWBYyWDt/yzlP8I9nAxj+9tP1734weG5PCHjJLhios9QP2G7f+ETLhopvYM CjH2dxXnGtWmHMsasvfrgqQcEfUGhuwGe29JD2ZT0I5FbFjM1z ATxvQgMDVPUpVv0TUOPNY7LkAYxIB97/AIEPm+u70qvaTm2uEkGSn8Q7EVLWgjbyM89adgHFK0alRKpBRx kFelKmARg8E1mxkbxDrjB7cUiopGCRgVY2jdjb+dPMQDEdN3ar UuhSKF3aCZC0aDchG046/WspbRyX2lgc5zjketdQoIYLgBRVG8t1juVkGAHbn6+1XcGjHaz JwIARlfmLHGD+H+eagltQEDKAQGHP9ev1rZfapbGOONrdv88Uj xBQoJBQjJUdD6ZpXFYofYWkZWClAQAcLnP60ya0EcoAjUE7SCO eOlagMShWcKUOFKYwfamuiy4cyZ2DgNxnHToPp+JpBYr6VN5bl ZSAjZGV5AP1q/PaC5+XcUlXJjPbd3B9jVOVEVd8YymSFBOcfpVqxn+0QZ4LJw3u PWlcZnxIYZSFBVG/hYcqe4+tTIxtpw+0GN/vc9DV6+tlMayovyufmY9pD0P44598VTfa8LIw46H2NN23Eeo/Du9tta0+fwvqSFvNXdbvk/K/qPToM0zwfqMvg/xVcaZq0G+xud9tcwMeGBGCP6j3Arz3w9fXCTRCN8TWzApwORn3 616z4rtLbxR4St/FNmhWeILDdjvuUYDdPYD8qqPYzascN8SfDtx4P8S7ADLZXRMtn cK2RLEcY/EZwfpUulzGeBJYpvLlDBkcdVYcg13GmQwePfhxcaHdCRtb0pXm sCnzFwAS0eCQMHr+J9MV5X4ZuvKuHtpDz24xSasxp3PvT4F+N0 8b+B4LqZ1OpWmLe9XP8Y6N9GHP1zXfV8UfAjxfL4H+IUE87Mui 6mwtrlv4FbsfqpIP0Jr7WUhlBBBB6EVvGV0ZyVmLRRRVEhRRRQ AUUUUAFFFFABRRRQAUUUUAFFFFAAa+fviLq/8Abfi+8ulfNtZf6Jb46biPnb/vn/0I17F8QNZXQvCd9fk4dYysY7ljwMV4bpdm/nw2spBaBfNnY95XO5ue4yVH0BrOb6FxOQ8bFWFj4cd/LF6xvNRbOPLtouQD9WGf+A15dqWoC6W/1y8HlpeMSFzjZboMBR6fLtX6tXVeLdQOo2+oapESZNfuvsdl6r ZQ8Mw/3sDP+9XmXxFv9rRaRacjhSB/dXoPxbJ+gWsmWej+C7Cfw18MdY8dywl9Y1WBpIjt/wBRAThePQnDH2C14FO4d2cs5kY5dmGcmvVNa8VeK9C0vSYfD/iaR9LmsImENwkTtbuBskhJZScBlbH+yVrkH1TXNRmYP/YTkfMxNjZq3X3QZ/CmI49i6tlSrE+wr3H4NW+nWHhOHVlXzbuYurqDwp3Y5/AD8682v/s8bCG9GktNnmMWnl7fxjK/pW/4b0a4nKroGvWMUxPEEV1NBn/gMqMDT3QHrVtrEi3yyuCIicOo/unr/j+FeVfHDTprbxVFdxuoieIyRtjgkEEgfXrWtdad8UdIIkk0j+0 Ij1B8sZ+hUjP/AHzUWpXOp+J9Il0/VtDudMu7WMmETA4c44wSBx2PX+HHQ0rWBG14hNnqVxEk0cdpaa hDGDJIm1UmA2+b7JnCt7MSOlc/4OtrjQdK8T+HZ4zDcRXCTNE/D+Wu5WHvtbAOPXPStrxtcQ6ra6Zb+b5VjBYK8EjLhn3Fc9CenP 5Vd8KronjS2gk1aGebWtHgZLlYJNkt3ahNqzof4njGA6/xIAf4TQmrlSjdXPmzXYkh1a4EX+rLll+lerfCO4+16OVeTc0Xy 4z0rz/xpp89hrVxHH5gtgxMbSAKSue/vXW/BK5h/tS6s03Hdbl2JxwQfatb6GPU9FZ3hguY+SssLrt7H5T1/p74rxTU5XkvZQzHaHIA+hr3GcYcOADg5rxbxVbLZa/e2652pKdv0PI/nWb0dzRPQ3PAPjO68MGeyntYtW0O8I+26bcMQkuOjKw5jkGeHX kd8jivRLR7O7sXvPBXiNbq1eNxJpl+g+02xbnmPpKR/fj5wTlRXiKHjNTRuQwZGKkdwaNtxns1/wCMPEV1o99by3EMtslq6S3EbtGi5XA+UqCTkgYz+dePAHb35qz Hd3dzD5M11LIgOdhbjI9qYwG3pU7jsivyj4I/+vXe+BPHb6Zotx4X1uJdQ8PXb+YbeUnNvKBxLEwyUceoBB6EEV wkowMj8aWFiDzjr3ouxHpHhS80TTPEY8R3U7z2mnlZHiso2HnM DiPcWIHUg4JJ+U1yfjjxDc+KfEd5rN2Njzv8iA5CIBhVH0A/nT9almvNHtbyOQi1BEcsK8KkoBw2B6gHn61hYycj+VDA9JHhp1 +GGm+MPDs0guI96Xi5JMcoYgOPTI2fiUPY1zPxBvRe6vbeILaw it9UvbcNf22G8l5DjE0YGBhxztP3W3DjAr1P9lqddQ07xH4bug s0BjS5SF+Qc5SQfiNv5CrOt+ALG5J8Nz3CWuq2rvdeHL2ThbpD 8z2jHjktyPRicffpx2Bo6r4L+JpfFHgTTYLq+Sa+tUMUse75hg kDjr0xWN8f9QHhy38N6kyMyx38m/HoUCkflurh9G+IWt2esWEVtFp9uIkBiUxZBc8chepxnuB1yO1e weI9EsviV8N47O8miN2WeUlf+WE4kchSByPlIB74b6U00ydjz2 8t01bxlolvDKVW8hmVpU6iPaNzf98FjXk/xJ1GHWfEt/co6xWqMIIFHIWKMAKo9uAD7rXr3h2OCyi16aWRVfQrBrMNyfKL fKT+C/yNeEeKY9MuNYnfTtQll06SRvs7LF8wXPG4ZHPrUaocnpYXwPpU 3i3xba2bL+5QjIUdFFfoP8MdFi0vRI4o4wu1QP0r5N/Zs8HX8Wrf2kIWls3ITzjGwwfTkV9v6LaCKwiUdSMmtVsQP27VL McAcmtvSrf7NamSXCyP8z5/hHYfh/jVK1txLepGRlIwJH+v8I/Pn8K86+Nnj+GytbjR7K52Iny3cqHlj/zyX39T/k1otR2u7I5v48/EhJ7WWxsJsWEbFcj/AJeXHf8A3VP5n9PAFmNtaSavqlxuW7JQ25OfOQ8N9PUH2qt4t1 mXU71pZGwi9FB4UdhXLXM19rF9BaxCSeVsRQxr+gA7Vi5XN1Gy seq+GQ+s6NPpTXI8633PDM+V3beQ3PfIRvxlqjp9wEs5rB4ymQ WVCfu4Ygj/AICwI+lYE93N4VEuj6jcW1/qMitF8kh8m1jKfNkkYJyeewHqWq1aaj/aNnb6uhR5WJ83YcgyIAJB/wACTDf8BNBGl7Hc/EaxXxp8Exdt893p22yvD3wMmCT8iye5K+leAabPJf2YjlYeedy urf8APZBhh/wJQD9c19FfC27szrk+gXr40zX7c2cjHojsMxP+DYx9a+e/Fmk3vhrx3f6VPH5UzTNtXsJ4ien1GR702tA2MRSlrdYlJEMw2s fT+634E/zpzqQ5DnDDjFWvEcEMtsl9CR5cq+Yi49Thl/A1UspGu7MS7iZVPlyAd/Qn04xSQzZ8OzGbNo67jyYjjPPcVfliKPg9R1JP6/rXNo7RzCRc7gcgp35ruFtjqGlQXwXYVGCcjLN/9bI/Ck0BnooJAX5s9sdDViKPcNwUHHvxTZrcoqurAhuQc9cY6D8alt 0Jwe2epHFRsMnWI7AQAW7gjNVr+2Z4GjbqcA8/dxyDW3ZRkrwpGfvEDNS3dmGj+UkHnIxz7VaZVzzi4ldJmQ7kx8 oUn7v50GaNm8p3bqRlsgL/APW6Va8W25hlW6IwpBWQZ4yO/wCorAe4EjbVyA34A+/6mq5U9hM1fOVsERjPIYn8+n+elNa5gVgrZwo6YxgevvWW9wBIw WQZGfmb+Hiq0l2qFQ4O4cE7vUUcugrmtJdJJGqlSGHYHIJx6fh 0pmnXwguvNTDD+IHuPSsm4nkWZQGLpwH+fPPt+Ypsd0IuhKjoS B1xzRyiuehGKG4he2OHjkXdGQeo6isWdmMXn8+ZGxjmA7MP4vx 6/ifSneFb9721eAFjLbfPHx95e4/CtfWYk+1QaiEX7PqR8i4b0mA+Vj+v4E1mt+UH3MNZzDdxXSYJR uxr1r4Vavb2Gp/Y76Ez6bqqbX2HlMnGOvIyAfwHvXjcsb2lzNayqwKnauR1Hb8a6 zwNdm5il0x5I0cLvgdlYtuGSACOmT/P06UtGD1PRAs/g34gWrhnSGOcecwHDLn+oz+dYXx50Iab4qh8T6NaiDRdWAlhKs Col/5aLgdDkZx0549B3WplPFPgSzv7iJlvrCHy5+PvqOh6fT86PCEI 8cfDzU/AN0cXLhrnTnZsiOdOQgz03DHt96tLXM1ozzPw4DrMbaarMssyb rcDGPNUErnPY8j8a+xP2afGn/CW/D2CC5kLahpgFvOG+8V/gY/gMf8AAa+INIabR9YNneRss9pMUliDYIKnDDI+h5r2n4PeKbXwb 8YYGtmEeh65Gm5QxKIXA3AE/wB2TP0FKErMqSuj7IooBzRW5iFFFFABRRRQAUUUUAFFFFABRRR QAUUUjMFBJOAOTQB5Z8ZtRW41jTdGJJgt1a9ugPROVH54rzHxj dXOn+Bp/IP/ABMtZlFrBj+9ISpI9MDzD/3zXRa5dSazrWqagnzG+vFtLfP/ADzjPOP+BcGuQ8carax+LzKx8yy8Lac10y9N88ihYlPvsCke7V g5X1NVoefeL5rez1SaKBwLXRrZbG3PbeBmR/rnOf8AcrzDwnDHq/iebUb3ItbdWlkx/CijoPfAwPetvx1eTQaIlvI+64nYtM3952+Zz+v/AI/T/h/pT3WkR2UKkvqE6iZh/BCp3Nn6kLj6GkMv3FgusaFHPq1tDYRtkxbUGwLj5QTywY9ieOx HNeTa7p0+l3z280hJ6o2OHXsRX1JrVpAdP2eUphVNpXHBXpXln i7w/bXdidLeJVkjLSWlzkkkHqjfT25xjrSTuDVzydJob3UYTqjyupK rI8eBIVHH0JxXs/h3wfZ6HcC5tbu7lBAIErcD6YAwa8l0XTbhPGFjp1zB85uUVkYZ yMg/iMfmK+iblAsCmqIDU70yWpayuJo59uCPPkjJ/wCBKT/IV5/eeKdfsGkTUG1KKInrlbiLHuSN35kV18keWznFRz3VpZxGS7uoY 0A5LkU+YDnLiGezksLu7tpG09SZbVTGSksRyWX0+ViT+VY19dX MGu2useHLmSxv4XSVLhDtEUxJIAJ4xjj0PPavb/ALaL4t8HHwbORF9oWabSXYYKgYYqPTqGx6Z9K+fPHv2vQZbjQ7 2Bobi2uGDgjBLYAx9OM596m1jaMrrU7aW/0j4mWItbS002x8TRbvtGizAJDescbmtJONrHbnyieCTsznFYOi 6dZeDNWlR9C1S2nmbE6XCcW6jJ2EgFhnjkge/SvKjI7S72Y7vX0rudO+K/jOCwi0+8voNZtIV2xR6lAs7Rj0SQ/vFHsrCqvqZM9hbWfB6QvJBK16qEhimQMjrgYyfwFeF/EO8gv/ABdfXNtEY4nK7UPVcKBg+9T33jjWbp2cIkBYY2rLI6j3xIzHI+ tc0xeR2kkYszHLE9zSvfcEIme9Sg471Fkk49OacrHgdc1LXUC1 bybHzVvHJ7hhWcOtXbVty7GIyOlD1LTEI+Yg9MVHghiv5VYKnm oJuSCD9aSfYGa2iTNNa3ekk5+1oDF7SKQw/PGPxrNQ4yCMEdQa0PCphbX7SOfiKSQIT3AJqtqkxn1S7naMRGS Z2KDopJJxQmJHb/AXVrrSPijo7W2WW5m+zTID95H4OfocN/wGvp/XdD03UkbT9TtI7mKKTcgfqp7EEcg4PavjvwTrDaD4o0zVwu4Wd ykpHqoPI/LNfa+rMHmhukOY5ogQfp/9YinGw3qjxX4oW3hLwNYBNL0yE63c/vY53LFraMHlxzjkqRg543VyngzV/EGgR6frsevQz6lrUT3sumyQtseEE4d2HC57HAxnrV34969put6 +umWlvKJdO862uJnwBIcjhR6AhuT1z2rgfDV4174W1CS7vQlyS LKeZ/8AnlEoEUSADheMn1NPcdtj2TXTY3mh+NNUtlW3TVdIt7lEYgHz R5yunu25cGvnJ9KvNFto7TUYvLlklOQxyF56cV6GmrSt8PbuFG E0liFkCk9U3pJg+wMTL/21rnfEGrw6/rNtGLWVVhWKUyNj98m0bXPTDFQCR3JNFrkSVj7N+C+nR2Hw/wBLi/d7miEjlRgc816ha38EUHGG2r0B615lol3YzeDtOXRp99vJCpDq ccAdPzrO1rWNT0S1EizrN5h2Rq45zjr7gdau/UlI7P4heN10HR7ewtpUi1jVV8xju4t0K5yTjg7QB+tfKHjvXZL rUGhinLxRkhWPcd259ff2rc0PWD4x8b+IzqF087WUAjh3yY8yQ 8En6ensK4nWraEte38jbbZZmSEA9VU4z788D8+1ZtuRtBJGTcy ILdppGIXPyg9Xb/P5VpWN8ng7SZbq5iVddu0zACcvbQkdSOis2cjPQYJ6gNVkZNBt YdX1GNH1GZN+nWUg+WJP+e8g9O6g9TyeMA8w7XmoXInl826vLm TMaHl5nP8AE3tz0/rRcU59CrdNqGq6vHaxQy3M07gpbqSWY+rE/U9f5k17d4G+GGt6b4Z1K980TSbUneBF/dxOpyMevBIPsa7/APZt+BZ0+Ma74hUSX86hmB/5Zg9vrX0XdwaFoeizQzRRQ23llZAF6jHNaKOmpinqfGOnOFhZI C6NaurxP/EI35Q/VW4+tH7U+mrq2maN8RLKMK9/brJPsHC3MRCSD9B9cmrerQ21j4rlEEgawllZFfsYpCcH/gL5P4iuk06yPiT4X+KfCU4DXNiP7StVPPA+SZR9Btb61mvI1Z8 92E0dxazWwVGj2C8tQxzlSMOn+fSufsNtnrTWEhDJN8mQRtY9V IP1P61oaJdSaVslZd8uk3eHjIzuiY4I/mPxqHx/a/ZZElt42WNSCJQSQyNl4z/MfhQt7BfQk2bBggkKMEbeFOe9dL4IumOpLbySQqsw43tgKcnHB HI46c9RXNCSC7tYL9mcC5Q5AXgSDg5/HNWNPukt2idcfu2+9nJye4x6UWsB3OsabNZXJjaRQpO8Yl3L1K 5OOOTnH17VWt4ZQxLHaMgAZHr9f6V2iwjW/DkOsSzRMRGIrlIVAzIOmTjA4yfp2rDazjgg2HcQzb1lRgVbsFx gc9j+PpWb8xphpwUbSNrDvkVptGrp8sbb3HJHOODn/OaoWkSgEAnaDkgdB075961MP5YQh0Cj5hyD1HpS2QzkPEllHdL NDKQFk43duDnOfqa8rud0f7htsciOwzxjr0/l+dew+I1whEYDDGSD24+teT+MIQ94bhiFMvHyjOO3IraErjexl hzIdihTz/EMEmoWYhgkr8hsZJyNv0702MEDzBJhI8ZZDjOegH8/wqvMwyh3uwbgjqcVpZXM2ye5kAkVFXGFHAOKQEyO21lJ3AEEYJ +nbFV8xrLuZSY+OQfu59c/jRcbPN2WzMVfH3l5z6VQmzd0PUJrO6inLBhExHyntnnp0zk16Z bRQala3ejEF4L2PzrQ7jlHxkEY79q8XVWjPlkEENhhnv8Ah+Ne jeBtWaXSVVXzcacwlTdz+7JwfyP86xqRtqiosiv4H1LRYdVdSl zAxhulJxhhgEn68H8TTdCvIbe+huTlhGwJAIGfatu8RrTxhPaN 81hr0Qmh5BzIB0/Uj8a5GeOSy1CS0lQqYztVs4+Xscf561LWlxbaH0f4F1LyNWjsb lT/AGVrMeFVmHc4BHQADAH5U2RbjwX43iNsfnSUYxxnnPbsenuCfW uZ+GdwuseHJ7NIvM1G0Pm2+wEs4C4wMA8jJPbr3ru/FltH4g8Iafr9vEiMU+zzqBgq4Jq4MlnC/tH6Stt4wtPGFgo/s7X4vOTgAiQAbwQPqP1rFuLp73wlp0sF35k2lSuxjZQuyJ9v3T 1b588dt31r1aexPjr4KXmibC+paP8A6ZasGGTyd6j8SfzFeM/D6d01JrGUKDPG8SeZgKshU7CfYNjIpSve6Ki7n3T8DPFa+L/hxp2oPIHuoU+z3PPO9RjP4jB/Gu5r5J/Yz8WLY+K77wvLKwt74EwBxg+YmSPxK7vyFfW1bxd0ZNWYUUUUx BRRRQAUUUUAFFFFABRRRQAVgfELVBo/g/Ub3PzLEVT3J4rfrzf403JuJNH0FDzc3AkkH+yvP9KUnZDW5wVm iafDF9qbEem2ZlmP+2w3MR+BDfhXiGpX8uo2U/mkifWdVa5uuc4ih+4v03E4/wByvUviPqn2HwjdTRtsk1CdmUntFGCw/A4Kf8CFeGaC7r4elvblmxJuWPJ6Rbm6fT96fxrE0LPhDw9J408 f232mBm0mzJluyfunjcE/H5FPoK94vNNs5YEWG1tYJoAPs7eUAiYz8uB0BzjI/pXJ/A+xkg0Tz5VAaaD7RJx/HO5fH/fpLc/jXeywoRwSPpSfYGcfceVK8sKKUdGKPExBMbY5U44PUEEcEEEcG uN1zS8xskvC5yjjqp7Ee/8AOuv8UaKtjLdeINPhcXax7riKLpdKvPI/vgZw3vg5BIrMjvLPW9G+12UomV49ynGDx6jsQRgj1peY0eaatp MIudL1OOWM6hHLIQn3djxspKE/3HVwwP8ACd3YV0Y8RaTcoTJdLZuhKvDc/IyMOo54P1GRXATa5LB8R7JRloEu4lZWGQCflJ/EEfXArpNZivtH8YCLSb9oJxcYTZny7leD5bDvwcDuOnpVA1c15 byxuYCPtKGNuN2cA/jXC+KPBM2oTCfT9UDoWy0Tvn8jXrXiPUrrxDoWzS9Qt9KmAyU8 sAMf+ujZI/MfjXiWr6h4q0idm1K/+QEgSJdRyKfwFPYg9Hllu9Hg0S8sH8uezuHMbr2IVP8ACtj9on Rbfxx8PbX4iaVbhL2yxDqkSjnHADf8BJHPow9K53T7xbrw1pji ZZwY2kLersRuz78Y/Ct3wx4uuNJt7nSLxTd6NfRvFd2x/uuu0svo2P5Chq4J2PmcgbvrUicHHSrGsWps9SuLc8+XKyZ9cHg 1WB445pDJQcnpk0rHb8vX3qNBk96kbkdOaVmAnJPNOyu7pikUd M9afsyMHgjrRe4Ei4NPRirAjtUaKc7VB9q67Qvh74v1q1+0WWi zeVjh5iIg303EZ/ClcaMMsroHHfrUci8Yq+2kapY6hLp91YXCzpw0YQkg/hTZrK5gJE9vLEVPIdCp/WoK3M6BzFICOGRgwrS8RADVnuUIEd0q3C/Vhlh+Dbh+FUZ0KuGxkVc1MCXQ9NnUEmMyQN7YIYf+hn8qoWxVV hkAcV9laF4tttZ8CeF77yWeTUpVtiy42xzBWDA/VkIH4V8YoOM4r2f4Z+JPs/wS8UWzsVm0i7tru0c/wO8q7cfRlP5mhMpa6HGfFi7a/wDHGpT6LIsUd3qbJG5GRhnIB59ev41UstEj8P6Rqdrd3sc1xJK AQGBYyBueATgAA8+9L4zhm1DxO0Ph6ye6ilmN0ixAlo0DK2Pwz iodbQpq1yjKVZZCGBOcEHB/XNUttBrVljwxLbLqBtLtttlfxta3JzjardG/4C21vwrQ8afDi48KtptprZlNnNE02nXYjEiyQkbih5GHQnBHcd xiucTIOK9Xj1/WfiF8NrDwTGltdXelStMqySbZXXaVUoc843ZI68Z5BOEmE11O2 +BHiaytJIvDWp6rDDbRQ/6P56BZHPU4CZAGO5OK0fG3iCzvvGf9mQSfNb2omVCCPkdsBvxA z7ZrxD4dLNY+KbLSb1rdM3OxjG2SkZ5fJB4wM16B8XYrnRPjTp WpsuLbV4WtHP8AddO36p+tVdtGSOH0W2ubLxd4jt/tH2eB4XmkIUZYcYUEjueP/wBdAgt/DelRa74hRbieQbtM0x24kI/5bSjsg7D+L6delurix0/WNT1vU1xpsECIynpPNneFHsMKT9QO9eSXeqN4v8TTXeovLcTTv tghIwMdunA7cdBUbluVkQ32o6h4j1kCIS6jql5KC5A3b2zxx6D oAOB/L6s/Z2+CX9ksmsa/Ek+sMAxVvmW2B9ff2qH9nz4L/wBipb6zcwqmoXZ/dknP2dO5x619E6hJDomlfZrNQqqpJYnknuSa2StuZXuSahquke HrAJLcRxAep5J9a8v8Y+LNI1zdZrPc3CscFInwD+NcD4/1K/8AEGui0hZpsN90c4PpXq3ws+G62FlFeayg8wjcIf8AH/ClrIqyWp5F438F3aeHo9cispIrBHMbM3OFbv6nBAOf9mqHgTVF 0Xxpo2rXeBDNKbO/jboVceW+fbkN+Ar6v8S6TBq3h270p418uaEoq44B7frivkPUbI qdQ0qZSJVG5PUMh2n8ThT+NKUbFRd0eWfFzw23hP4xalosi7IL lnhBPRgw+Rv/AEE/jWJDAmpeD5rSaITXVgzWbks2Qr5aJxj+66leR0Yfh6j+1HG3iD wn4W8dRAefPaiC6YdTPCdjE/X/ANlrzvwbsuvGEFkVxaeI7Uwt85RRMQShyO4kA+vTvUPQDjvCLh 7S506U7ni/fonPBHDDtV8R3EczF0EbRkE7Bht3pz6Y6duag123n8NeNbS6lV YoblVmYL0+bKyL6cMHHtitW40/ZLOkLlnB/dIEP7wEDIBHy8ZJ/Cm+6Bdj0/4QXiX8l14dvwu27tiB8nKSJkfj1JwM/nzW7ceGpoXjtm2jDAAsegJ4XPQ8ev6YxXmXgTXbrSdQE7Qva3K uhZUXYWXOTg9s4OTkdT1xx9IatZ/bIYdRtoWkgvgkqqQMMGHccDIIVj1GB04qb6Bc83ttEmSSOGRVE XzCRxHwo5XOFyfrx+GagubKaHEcqHdt+bjAHPA9ge2cV3R0GKK 3hNxc+XKxZHkdPnGQ33s9QQeDnGSO5rNn0QYuZXkbyGOTvmL/ADd8nHIyw+vY1DQ0zzbX7do7ZihJOQCcHOSDxjqOv6V5b4wjDT XEKlRnBXjHGCc9Tj6Zr3XxnoU9vZRGRG5AYjDLuGMDk8Z/+K+orynxPp6XE91FAshRQvlYU5kbA3cdOATn/OHHRjZ5bbFzhcsmDgE/dBxUZ3Rfejdc/c3njB/+tWnKsgvZ5ZnjZmP3ZMfNz2x06VnXELvM4barr94Z6n2rpTTM2 McHCb18sEZBGfmGev6U1yokUhtx7kfz+tLIj274YYcD8vWo5Xd 8bnLY6ZqiWTHAlYRMXiDYBZRnn29a3vBGqDTvENvLKAsDMY5QB gbG4YVzkR+cYJAA4xnr2qa3dkYswDZ6hhk9eoqWtBpnrvjiCX/hFUmT5brRbncjLyShKbTn34NZnjKRLqzstehhAjvYwGxyFf8A/XuH4Cur8PRx634StZZkSRrqNrC5RQNxfGYjwcHkdfb2rmPB1rN qHhjW/Csi5utOlaSEZ5z6D8QPzrKPY0fc1/hHq39meJbW4+VIt+2YkkYiYYcHr2J7V9D6DYkXGs+Go0j+xXo+ 0WjxsoA75AHUdO38q+XPB7pDdKzOcH7yHjd7A9jkf/XFfUGgG1uPCujeI4dq3emSeXc+V/zzOcBtoPqMk+voKSRLMT4c38vh3xeEkcR2jkrchu8eDuH/ALN9VHrXlvxT0efwR8VL2zgVoY0uTPbngrgncpHGO4GPavXPiD Zx2XiWLUIdrWs5WUEDgq33v61lftDaKNX+GWg+Ldsk17YubG7u cfeVCQrHjnI2njjLGrnqgTOCfVpPD/xRtfEWmJJFFM8N7AWTaHOAWxx03Z6etffuj38GqaVaalatuguo VmjP+ywyP51+bz3b3/hmxkld3+wTbU+UkBHPIz0AyD719n/sp+JP7b+GUdjK+6fS5TAfXyz8yH+Y/CnTFNHrlFFFamYUUUUAFFFFABRRRQAUUUUAFeK+Pb4XfjvU7nc DFp1r5K8/ddsLn8zn8K9nuJFhgkmb7qKWP0Ar5h17Umur23gZv3mr60jO2f vQxEyH/wBlFRNlROL+PeomK1lsIyf9GhhslX1kkxLL+IxEf+BVyF9pz3E 2m+FbRgryyRWYYdmYhGb6cSn8a0PFt4ur+KNGab547ia41eYH+ 5uJQH6xxx1J8P7ee98S3erAl3021kaM/wB64l/cRD67nkb8KyLPX/DEcEWlma2iKQ3ErPEB2iGEiH/ftErSYgDoCabDHDY2MVupCw28SoCxwAqjGT+VeEfFb4vPPNeaD 4cKi2ZTDJejJZv72zsB2z+VDXQDqfGnxh8P6Hqb6ZaqdQnjyJn jb93GfTP8R+nSvKJviRF/bk2qQxLYx3LZkhtvm2nGA+DgZ9R0YcHsRwVwIFOCWTnv3NULmM FsIvvxQgPQ9TsY9S1iDVrOSF47i4geURk4yWwCuecHPQ8jBB5F bvxTt7e21u5stLIa1tURWI5+YAAn65IzXlnh/Xp9ImeKRDPaShkki3YODwSp7HgexwM16A+oTa34eaeDyX3qFmk XO52G3qOzHaCQe+cZyKLFwdzrfhlrVl4unGhanfwWPiLGIJ5si K/X+7JjpIP7w5PcMemX8TPhVfW12y3kEtncSEeSkrgQuM8lJOVYd +D/AIV494guHtb6MxlkkTkEcEHNeq+Bf2jPF+iaZ/ZOuWtl4l03ABhv1yxA/wBrBB+rAmnbS5E1Zknw4tdGs4z4dutWtUkXfOZJX2iHj7rE8HJ GOOcnpXoEWl+AbfTnvLjxHFeSIhYw2xHOPcnj6nFcne/Gz4dXUTO3woaCdh8wttalhRj9FA4/CvLPiH43/wCEnZYLHQ7HRLBTkQwFpJH/AN+Rvmb9BVXJsY/ia9t77X7y5tf9Q0h2EdCKzCefSmwjoAOa2da0V9KhtfOu7Waa5 jEoSCQSbFPTcR0PtUbj3MxAO1TFRt5NRx/3SKfuB4HHNF+wDlA/GvTvhV8LbzxfCuq3sxstLVtoYDMkxHXaO31P615rGN7DHWvsb4 UW93b/AA90iG+txBOsPKbdpAycZHqRg0NjIPDnw/8ACmgFGsdIhMy8iab94/5np+FdRsBFWAo9KNmKQFNIo0lLKiqzdWAwTT5YIZ42inhjlRhh ldQwI9wameM4yByKY0scURlkZURRlmY4ApgcVq/wi8GarLLIbSazkkOc20m1VPsuCK8A1vSf7Jvtd8NmRZpLObzI3 C43GMkE+3yMT+Fe2+OPjDomjK9vowXVL0cblbEKH3b+L6D86+f 9V1691DXptZmkVrueQyuQuBk8EY9McYqXboMzIsnIzz2p819dQ 6TPpMcpS3u7mCSbBPPl7sD3Hzk/gKsCKGeQyWgwTyYM/Mv0/vD9f5132h/DWa6+Hsni6+u4rSeSUR6XbykKJmDYZ2J6KAG4xzj8xAdP8L9Hi WwNzK5je9Bi81Dho0ORwex5z+Aryq/dpLyV3Ls5Zi7PIXLMSSSSeTya6t9R8WaRp5sUv7C/gERU/ZYzujHTj5Vz9RmuOzleOc96p2asVTXUQjvSCRo3DoxVh0IPSlz gVE5HpSepqXLO/ni1Jbx5XLl8uc/e4wf0JFfQer3Mfjb4daTqjIlxqtldon3uTMAUDH/eVlY++a+cAwB56V7B8CDcXWnXsROURzJGP9tYmX+Ug/KnfsZzRi/FC+tpdZtfD0b2wiii3u1x91Q2GDcnBdjg+w/Tvf2ZPCnhm51O51C/vba+1OI/6PEwHyL/AHh6n6dK8R8Q6fquseJtUnhglmVrto1KkdeMKPoMDFfSP7Ovwx v/AAvZ/wBu6nuS9uI9scJGDGp9fc1UUZNH0Do9xbWEMryyKiqOMnpXEeN vG9pcu2naWVubqT5VUDOK1vE3hjWr7wzK1hIrXT/MIt+OB0FVvgx4BGl241rVow15ISURh93nqfeq1uJWWpf+GPgNN MUazrESPqMvzBCOI/8A69ei0UVaViW7ga+Uvj3aNonjy7liXCyN5gx6OBn/ANlr6j1TUbHTLRrq/uoraFerO2Py9a+YPjnrNn4nvZ9T01zLABsiPHO0KM/Q7lP/AAE1FTYunucrNaDxF8HPFfh8JmbTJo9TtR1+Rxh8ewUMfqa8A0 y6uINCguYZHiutIvg4Zeqq3OR7hhX0J8HdStpfFVpFOf8AR9Vt prC5XHUMu5ePcgLXm/xR8MyeGvjHruhKgW31SI3Ft0AbeBIMduG3D8KhO+xTRlfHzS4t QuB4phd1tLow3gjRG3JHcLlsbuPlkVh2yWrJ0yV9V0HT7wlZUt 4jFKhxjKnjPc/eJxz0Nei2KXHij4Cx2xl8qW0nm0+4eWMb3STFxBuJ5AMqgbged wzwK8r+FpiuItS0i4QSEKJ40JwAV69Pahu6EdNA7wTQJbFvmCr CsozjPBZeMjJxhh19uMfTnwnuItW8Jvptyitc6W4ZgrAhg3PXA BGQRxnv6V836dH8jxEWjW0kvlJAwJZyMMF6nJGRznOGGCcED2T 4CaqE8WT2c10ssU8C24VjuOevU4JAJx07n60kB6MmkyG5EbxSz lGHzFsncB15U56Dg9+eMU9dEjNtK8YeKTKsZCVf5Tg4yGGR9fb 156aKzCSujIuQgyVUkcEBf6dP0qwbRHuAz5QYIyDtIPGB16AYH I+tAXPMdd0a9ubBg8IdY5wsDBcZ7kFh36c8+meTXifxA8P3GnK ZksJFt2LFW4Zfm7dcrycDr354r6vvNGZ08vascIYZH3twzz7D8 AM8g5rzP4n6CLjTJZbuCeWMptlSPczpGCCxUFgM8ZzjnYO4OZa C58V6tZIL1lVNxc5APGzOc5OfXPX0HrWLDmNn3pgnuec16b8Q9 Le1+0JBbw3DRswKwzDdEQRglAcgjBz94ct36ee3cyXKjZGoZMF tyjJPr0/StE9BMoLM0km6aQySOxJL88+vPXNQxssUrFow/BUc9DjrxU22R7nzJVJ5ydoxjv07VLcpPMB5PmP5jBdg6nJ4GK0 0JKYLoSuM46g1LC5AMkgSRjuAVic5x1OPrkfSkMmFCMSrqGDNj Oe4BH1z/kUsUZZ5RDnyh825sZ254z+lMR7T+zrNJqc2seF593mXkKzwFjt y8OWwBj7xUnHPY+tXPE1svhT4y6bqBtjb2OsQgyKE2gF8g9gDh hnjgdM4FcD8H9YOh/EXQ76WUpBBeo0xBIwmQH6f7PbpX05+1B4SnvPhxca1ZwxyPpF8 twjKnz+U5GWBHUYMeR/s5HFYvc08jwPxLYXGjeNLzTlUrDG3mxhU4KPjv9Tivon4A3D3+ k3miyIjmeBmClyPmAAHvzjn6CvHvHEB1fQfDPi+0Clp4vs9w4G 4qw5798g13HwY1C50/W7Ca4BWNZNxwgwPXtjHPbjpSEd34htnvvBkSyKPtGnSvbygdFX dgdvYVFoVrL4j+F+v+Hy8s5azFzbx8FllgK5VQfVQv5V2PiOxK eIby08xhbanbloUKABZAAe3UnrmuS+GFxJp3i1EEjpEky+aoOC UY7Gz7ANn8BV+QbHiPwh0KPW9U1jTLt1njjjYi2SP57iQkiNYx/Cd5AzjADeler/smajc+GviTfeEb/MbzxvBJGTnbPEScccHGGGfeslLKPwT+1FBBbyNFFNeFH8tMf6x SVA+ocDtyK0vjB9l8E/tCWWu6crRLO0N7IoBwWJw4B99ueO5NTF21HI+uKKZBKk8KTRMG R1DKR3BGQafW5kFFFFABRRRQAUUUUAFFFFAGF4/vDY+ENRnU/P5JVfcnivkXXrlx4mu2gckadpLiAA9JZyI1/HdJ+lfTXxvuTH4XhtEbbJc3Cqv4c18t6DOt/4nvLogeVcarG+D08qBXmcfmsdZT3LjsYGuGOPxdr7Rn93p1tDp 0WOmFAU/+Oo3511vw7ns/D+haFPqU0VsNd1WaRpJXCrtgidUyTwP3rOfrivP7N2l0S8v5ju N/qEjse5VMA/+hGvSPjX4f0gfCbQNJk1K1i8QaTbxy/ZGkAeVZP8AWYXr945+gapZZzX7RuuS3NrbQaT4l06fTCh+029r exmRnyMbgDlhjsPQ57V4FNKGyFGPfFbr6ftGZLpAPREz+tTXWn 6FaabJeSXF7dygAqqxEKP97B/qKSQjlW80r99iPTBqxppiScNcqXXpjmu9+HuoabLalD4b06cIc M8lu8jN9cucflXoFlqmjQgk+G7GDHTFk+P/AB1arXYLo+dr+MG5Zo8bCeAK6z4dqolljNzDbpNsjmaZsYjLDL AfxEdfWvVNT8QaMrDHhjRpie7Wj5/8eYVb8LXuna9qkOgW3he0gN46xlbaPy2cFhx94jHqewFArnJ/Gb4R6xothLrUUcl7p6OAt5GvAJAOyQdVPIweh+vFeMPGykgjHt X6ix6XF/Y82m30cN5DNuWZXiASVTxjbzxjAr4p/aX+EUngLW11HTUeTQ9QYmBjyYX6mNj39Qe49waNtQvc8OAPrTj jPvUjrio9uD60hD4iAc8cip1wDmoEHPFTdcDPFSwHZGMAYPrRs 5Pr7d6ap6+tXNKs59Rv4bG2iaSedwkaqCSzE4Ap77jPTf2dfBS eI/Eh1S+jV9P04h2RukkhztX6cZP0x3r6kaPHI6VyPwz0Gz8AeBIb XVbm2tZyTNdySSKqhz2znnAAFdjZXFte2sd1ZzxXEEgykkbBlY exFAyMCnYxUpTFc/48fxFD4XvZPC8EVxqYX9yrkcDuQDwSB0B/+tS6AYfxL+IejeDLXbcN9pv5FzFaI3zH3Y/wj/Ir548UeMfFHjaci8uTDaE5S2iysY+o/iPuay7i11G81a5utde4fUDLidZwfMDZ7g11djoA+wpMjfNIQAo GOfx5P4DHvTbNIx7mF4b0Gxu71ba/l2uW25djtH5f/Xr0m00HwDpKLHe3SO7cMyTIVH/AVOfzFcpr/hnZppnN00UkY3EL1YeledaRcC81EW81w0UbthWdiAv129aSTY3 ZHrPiPw34D1Hzp9D1V7e5igaUxrHiOUqM4GTkdPetrWIYbjVtN sprp2stK0uEhA2Y03oHQD32FGY/3mI/hFcD4Q0i2svEkd1JcNdwQo0rxqGIJA+UENjIJ/QGu18I2FtDfpZxzST2VnH9pnkm6yBQAgPoCdox26VUTORaudKt I7NbqVTvflYiDux2z798VwniCyhuruVrSBobqLmaEjrxnI9/5/z9C1A6lfOblDIH3fIEHJOfX8a17D4Y+IdRvpNaVLaN5FX9082G fAxnpj8yKHqEdNTwKThS1MVSwPAHpmvYtU+Ggl1iaO4ge0uJVJ EDypD5cgBLf6wgYI2kc8kkCsLWPhf4g0+1kvbnTtRs7SKURyTX VsyovvvAxjHfofWpSNVJHnWDXofwM1lNE1TUrm7RmjjsJJ2Qcb hGjNx9cCnal4P0i/Ed1BqdroySxI8azI/lyBgCMEZ2nH5+3NWrfwofsdvY2N0y3F5bS2SStjnzM7NwHTnC/wDAqohzTOd8Oau8Hj9tT06VIYrjUkvfJ3A4RyCR7gcj8K+4Ren 7CksDIxcAqRyMV8J3fg7XfB2qHSNU3Qa7BIYGgyVV4+CkgfIDI fnHsQPWvrX9ny/fWfB8FtdtYRTWw8pY4rhWcgd2XORTTtoZNHb2ur34lVXT5ScEg 16FGoSNVHQDFcq2lKqMxIXAJyT0rM8SfFHQtOgeOxljvrtEBk2 tiOM+jN3PsKtO24rX2O7uZ4baB57iVIokGWd2wAPrXk/xC+NWlaOslrooW7uBx5zfcH0HU/jj8a8X8dfErxD4vvXt7aaQ26tgKvyqPwrkb7R2t7CS/wBRnLquCVDYB9vepc29i1BLc1/EnxA8ReIL9rmS9kKg/NI3KoPT0H0FL4MB1ddT066bEhDTxlOASQwGB6Es5/AelcdqN5ex6MVk09LeCT7r5I/IE1vfDi/L+ILK8RlWIkWzx5yQSFUN+IL/AJVknqW9jF8OajPpmqJdJxNa3KTqB2ZHzj8813X7YNokVz4L8b 2Y3R7ntZHxwVVg6Z+qs35VxHiC0Nl431CyVeGlLJj0bn+Zr1L4 k2h8WfsrtcLl59KNvcepARmt2/QA1S1QSVzjfgolxJrXjLwexiJvLQXtirqWJmgxLFjPbYxHHYV5 LrVvD4P+M7QwIY4ftgkjOMAwyqGTjtwwrvvhZqrad8SfAviKWR RFc7LaV2P90mKQdP7rp/npnftbeF5dC8W6fqKhtrrLahtuOYJCF9j+7MX+JOaCNySyslsb i8W4EKPGxkGyISYU7gBhuhJQnO7ocDk103gNJ7G9s76ZnXy5DO jRIRIAWIwACBjoSO+OvFZ9u9pfabpmsuFM91bxSvI8mAgBEfOe o+QjAz1PrWv4dn1S1draCyaG6jCps8yOSREZU2kAdCMtgY9e+T RuB9Tgidbe8iDFZ0VxkEHkdMf596v2sB8vOCFBI/X1+uTXPfDycXvgqylEu4wpsZw4YHnk5+uTiustF/dg42knoBgDn09f89qrViIhaAglW4xjJHI+nt7e4rnvE2mE2rpF tLlCDuxwh4Ocg59cH0rtYohkHrwOAMD/ADzVfUbaNom3qWUjkYP9PpRYVz42+K/hKTT59QnWJYbkwSXUM3nGLlxggFeZPvHjIIbrkNmvnd5obK5uL OaPypuW3A7gWPzcZ6A/L6+uTX3L8afDsMuk3MlxZWdykGZCbidkwCrHcTyFAc8jA6n6V8 V/EqxisNcM0CwPHLllZJkbd0IYqucDqQD1GPxI9mUcvJ9sMEz20E htlZPP/dn5Tk7Qx7Z5qCW8O5ztZmblPmBVOc8gg57/AKelXreDyJ5nublECZUgkku2w9CAwI3AD6svTkitakTNcSySXE CRQMpkt4s7m24UNyMBiME89TwelWkiWVYYnndGIkKlTuKoBjaO R/3yBzUqbbC52yRw3DGMgoxyFLKcHjBDLkH6jnI4pv2YM0avdQpE TgSEk7eeSQBu9+macC93eMSis8nyRhBjnoMU7iNTQIrVdUjgmn kj3uoEsALhQcEcDk59OCK/QD4ZrF47+A9lbSEB9S0d7CZ2BY+ZGrIGIPqBn39q/PjSXtUltoXkeFWlBknA+4nQ8Y9PQ19xfsR67DqPg3UtMhd/LsLtZoYnIZlV85+YAAk7ef8A69Q9yrnkHgPTpdR+FviTwrexMl/olyZEVjyhBJPXp0ar/wAO94ltZHA3KuHJIDfQ/wBD6ZrtrvSbbwl+0rr2iIJTZ69b/aPnIxubLEAAepYVyHh+zGneIb/TpWdfIuXQDHBHHf0xz+FS+wM+gPEO6bw7ouuRB2ktHw2DnKkYO e3auE1i3Fn47PBWK6JU9yA4967jwkZNQ8B6lp8T/OIS0HOMHnA9uQK47xrvksdM1by9km0BgHDcq3c96pAc7+0pBPb 6r4S8bQwrb3DRpJOykEGWMrgN0z/F+RFdh+0lotv4q8G6B4v0iaBlhgLAyZVpY32Fce45OD6mqHxxt f7a+B0km4M+m3qSBlI+5J0yO4yx9P6V0ngeOLxP+zPZso81rew 8n5uSrxMykjr/AA/zpO6Ydmd/8EtWOs/DDRbmRszRQ/Z5fZoyV/kAfxrs68U/ZV1ItpWuaG7c2tylwgP92RSP5p+te11qtiHuFFFFMQUUUUAFFF FABRRRQB5J8frwLdaXbZxsV5uT3HP8ga+bPDMgtvD+o6gf+XbS 7q4Hs07rD/JDXsP7TuoMurSojY8qAqP+/bbv/Q1rxDc0Hwu1+5XObm4tLJPoqlmH5tWMnqzToT+EtLW6fwnpJXI ndHkX1Ekvzf8AjrCrHxq1Bx8SPEN5bRxzT+fBY24ddwXEQ3kD1 B/nXU/DTT1k+KWmwY/d6bbB8f7sOz/0LFcLd3MOo/EBby8ljS3m1G7ui8jALtL7VyT/ALtTexS0HX/gS11WwafY1pMRuDRDAX2x/EB69fevJvFHhrX9BmaR3mkhXJE8PGB79x/KvqJ44zEskbxyRsMq8bblYexrDvdLPlsysJF67T1pX1Dc+atK8 Ua/p0CRWWqTLGnRGVWX9RXoXgnxD4s1aMz/AGaymiVtpk3+U2fwz/KovF/hjw1MbqX7QLC+WaPykiQfvFckEleAdpAz0J3DnjmPwnpOs+E9e FpqgMlkVJDxZbZuGQSgG4Z45xj3qk77E2PRbS/1N4dl2+P9gyeYv6ikmmOnRnUrGCCC7tf30UkUKowYc9VANQw3t lM4WK5hdj2DjP5Ut7eWdvFsu50jD8AE9aabEfSPw08bxeJLWKG/WOK+MKyll4WUHv7EHI+vpWt8V/CEHjT4eapoVzGJJZIGktWI5WVeVI/Hj6E18++Ab6TFktkXmeLMRI4G0nK/qK9yHijU9D0mP7VB58sy+XawnJeVz0A9s9T2/KqaTEj85dUgMN08RXYVO0g9c1S288V7/wCOfhNZQI1rNf7ddJM11KvzQrIx3eXgc4UEDcOc547V4r4h0LV NEuzBqNq8R/hcco49Qw4NZ6lMylGKec470ADb157inr69KLiEGO/er2ialeaPqdvqOnzNBd27h45B1U+tUCRmpIjtG4j6UrAb3iHxL r3ie/W51nUZ72ccIXPCj0CjgfgK+s/hzpq+BfhZYx6o7LOIzNKpJyHc7toHtkD6ivn39mnw9b+IfidaL dRq8VlG10Y26My4C/kzA/hXuXxe1r/ibT6Ki5+yxIzHP8THpj6YNPQq5z3inXdc1Z2P2x7O1Y/LFEcNj3NZlppEiRLdTSzhmG5AHIYj1J7U/Sg2o6nDbyg+UoMs2P7ijJq22p/a5Jlgy0hOAABx2/qKoRzmuzLcX0aXEiXFyi7VMp3PtPGNx+bHpzx/OXStZ0fQ9GuZdciaK9ckrKvIkUckKein1zzzwDXQ2/w88Q3KyX8Vq8/G7cMZ49BwT+Ga5TW9EHiCyl0tyIrlVbBcfxKM4IP0NS0WmeceN fH13rTPa6VbfYbQ8HB3PJ9TXO6PYalvWe2tJpGQ7js4NejaL4C ls5A119lUjuwMhH/AeB+ea6H7Hc2QT7Bq13AyEkY2bAcf3cAflRzIN9xvwMsJb0ajc am21pY5ljUnJHlQucf+P11HhbTwuleJ7rJBQ20Gc9FJZj/6AKxfDd9c2vimKZrp5XvMxMMDBZ1wzc85IHNegeCo1ez8U2O35 z5FwufQb1P/AKEKE0yZbm/Y2Vva6DHP5S72EcQJ/hLEscdumR/+qu+8BLFeXtrC6jDMCQfQZJ/lXGM63HhCQwgF4SkowST8v3vxwTVn4Za+lv4htGmbbF5m0k9AD xn9atNXEzU/ak0K3l0/TtbEalop0E4I4dA68H14P/jorwaDxHeafKIYtU1Kx+zFhHFazF4VzkEGBsqVIyCAMHmvo79o y8hm0yx0UMpkuG+YegYhV/r+VfIniHUbOTUb0xSAOJi6D++hPOPof/QvaiTVxdC/4u1fxdr2qWTaRoWjxadZWvk/6M+2KYAk4IYlo2yxGOe3UVl23jRINQFhf2t1p9xGy53LuMbA8H jrgjPHWoLO80fUJhb6xLdRL1WW0I3HuVYEgMMdD1GO4OBzHje+ mtruTTbe8urnTSQ8AkmywXqM+hGcfgfWk31A9W+J+qa74mkvPF N7JbzM1ssEcioPL8pSN0YP/PRXAJPUgkjArX/Z01awtXvLFbKa4ViZhKZgox6hdvH1LV4boPiC6tY5YhdEW8oBk DAlWI6ZAzz2zjvzXvHwcjt9S+GHiX7JFCLw25hDRDk7kkPB9yB +VKLKaujp/iJ8QtXm8M3t2s8iabAD5MAYnfjgFj1PPbpXm+keIYrbwA0ly0U up3hkaRtw3oD0z7ck0zSXbVvg+IBIzt5Lpljk5VzUGneVZfDe3 svKP2vUZGQOG+VVGVIY+2T+dT1Kii3Y6pBo+iWiWhjubyRcsu7 AQYGd3/16wNS8QyTzia5m+2upyIhxGp9/Wn3nh5LWEya1qCaerNiFZATJIPVYx8x/EAe9O0CxvNSvlsfBfhm51G4zg318m2NPcA/KPxyR60rNlNpGZLa6vq7f2jqM621oTkTXL7IwP9kdW/AGvSPAng3xHqdpFdeHtIZ4chv7TvT9nhOP+eaDJPcbsH8K6zw9 8KvD2mRxav8AETWW1vUz8wtImbyVP90Bfmk7dMCu+TxF4mu9tt ouh22nWKAKhuss20dMIp+X6c1ol3Icm9jw74maa2heNISskkrR ouXkOWJQg8nv94DPfFep/BKCHxB4D8S+HFAMV1Hcwop7CRMp+RUn8a5X9oKyv0XTtSvnRnc 7CVjCgDpjj321pfsqX/l+KbmzLYWaASD/AHkYD/0FmqY/EN/Dc8Mtdtr4NjkWAl9K1MoR1aMyrnI9OYh09a9g/ay0jT9c+H8HibyiHka0vgYgpYiaLy5Mk8gAxp688cVxXjbRf7L 8b/EHQUiO1At9CoJHEU6ucEdPkLc+9enG0Piv9mm3ilVZbiGwvLNs AMQYmE64x3AiA/GmrE9Tx74Uyxal8ObKK4uHghsbuSGYqM5VhuXPbqD/AJxXS2n/AB/+bd3A8hmG0REM87Y5JJA2jCjlccMDk4Ncn+z+Y9RsPFGjXbCOE xRTgRjaPkO049Dg/e9cGu30KJYkaOIQyWc88ck3nIZMuDncoZzkglgSeu0dSCQAe4/BW6intNStoRtgZt8SHlRgYIHA4Ax7/wAz6RY7WVWUluBtHrXkXweeCwv7WBJJHVxsIMOACc8bv4ufyx+ NewWihZXB4wcegH+eKaJZejU5IbBB6GnTIHXay5XHI606PG3A6 U/FaJEnn/xMsLeTRbhJ4fOiKtlGJCHA4yRyBkY4BPIPaviP45+HnsLu+1aG BWtbl8MYgykoDsBJVQgRnXI78Dpmv0K1eASx4x8xPBx37V8pfH jRtN1TTb2KK8eKGKEhi20BigOIlwCzZdYgBtI688Vk9y4u58jR xeY8aJHFuKDahkb5CBkuPrt5Hvx7R3lpOsUInmKiYB0VoWXOcg MOBlcKOffvg1sa+sT6nPcmO/dQ7DzJEEb+ZkcsoyAPmX5Qfx5qjEjySJ5skcdvJIZTtcLt4PQE 4HU46mq5gMqBN1whny0UoIGGHuB9Bnt6VZ1GyexGyWQSGRF2Dc SdvqO2Plxg+1RzWqx3iQ+UT5YDSgSLg55GGHGMY/EmteaVLzSo5ZUeOSAhZGA3SY56dD+oqriKsSXcNskjWqwQS/MjSRglkORwSMkcNyPSvpT9iXWvs/xJfTZJhL9stHtgxO5mKAFRk9gEJGPX8vmW2uI9kMNr59q5DJcS BwwZW4wBgEDGQQWOc9q9a/Z21S68N/EfR9QhiKIL1I3RcEOr8MFJyW+VgR9al9xn0t+1PE+lePvAviqO JCPtDWkrFipAYjgn0wW6+/vXH+O7L7F8RTcwJ/x8wpMOcbieDgevQ9K9Y/a60yW/+EEs9vFvmsbuK4XA5ABIJz268n0rzrxw3m6f4Y15yBvgMUjD5c FlDD6dPftQ1qC2PQfhVKwufsrjKyKUJY5yce3QVj+K7QjR9Ssy p32NyWXjsecfTkU/4d3TxyQNkBw+clsg+vr3yPwre8XWqrrmpQmJU+2WvmA7QN7Dkn r1/CkkBk+GIBrXw21fS2JdrvTWQgNzuTOMfnnPsKg/ZB1EX/wx1Xw7JmOaxuZBtHJVZBkYH13U/wCClxGb5rVuPLnZTnurgj/P0rG/ZpdNE+NPjvwwMYaRpEJ6kJIcc/R6a3F0ZT/Zz1Sa0+NGqaZc5Vru3kiKn+/Gc/yBr6er5A0u6TQv2nFljdvLOtSR5YY+WRip/wDQq+v6uGwpbhRRRVEhRRRQAUUUUAFFFBOBmgD5M/aWujcapeOhz++kjH4sij/0W1cLqFoV8A+G7BR82oeIJXYeoVlQf+gmul+NFwtxqdoh5a4vA c57edM38mWs++iKH4ZWzj5BDJeyfUlpM/lWNzQ6b4VSwx+NPFOs3DbLWwtpC7gZ+VmDfyRq53UPhbZ3+gWy 2msfbP3e5ZljUo4JJyozyOfWpfA872vwU8b60wJmmtVjLepYNj/0YK8O8PeM/EnhS4zpV9JHFnL27jdE/wBVP8xg1LWgzrr7wz4s8GXkraTfXBSH55FgO8KD3eLrj3wR71r aF8TocJF4gsRAx4F3bjdG31HUfr9Kn034veFfEVklv4qtLjSL1 f8AV3lspkRD/eHVh9CG9iOtc54kC3Ye5t4otajHP9oaVIGdl9ZY+WB/3wT/ALVAjC+JSpP4nMtvKDGFV0KnhgXXGPrmuu+IM9wEt7m8gFpNNZ o0flnkgcAngZzjPtXPz/2LqXhxTZXhm1CKPYyPFsc4YFflBxxjHBPBP0rc8dXyeI7WyvYd kaRWaRpDgl4yoOUbjrx+tKysaR1LPwTu7fX9YuvDGswxXo8rz7 QzYZhg/Mo3Ag8c9MjBr2A/AvTL1/tmmau1o5XASSPcEPtkkD8AK+Y/AV+mlfEzRr64l8mGG8iMj9MJuw34YzX3np+Et/M7AHkH0qkRLc4rwb8N9d8ItcY8b2kSTsGkdNOR5sAcAM+Qo/4DVbxRrmkaHdyzaXc3Osa0y7ft13KZfK46jPA+gAFUPE9/qmo3kqyTSCLcQqZ4ArmJLJixPO6i9xWMqZ2mkLzyF5HYszMeST 1OaiurOC+tXtbuNJYJOHR0BBq+1k+4lgcj8aTyWC/dC4HY9aBnm2s/C3SJzI1jdXFm55UMA6D29R+Zri9R+Hnii0Mnl2K3Ua9HglVsj2 XO79K94liKnc2SRwRTJFU87c8ZpXA+XXRkfYy4YHBB7U58AY/ya9m+I3gWLWA2qaPEkWoA5mizgT++T0b9DXj17a3FpcPBcwSwy ocFJFKkfgaWyJO7+AHi+z8F/Eaz1XUiRYlHhuGUZKqw4P4MF/DNejeDtavfHd1rfiPUlVXnnUoqjhVG4Kv4AKM188ovpX0t8JNG fTvCGlzpCEimt3nkYjG9m2HGe+Rz9Iz+FIZreHdNC2mvXO3Gy2 WNR/vPk/otZvgawFv4lu7icEw2cSSEdiz8Af59K7vwoscw1624y1tHKPUg Ng/+hCucMlnaJrcjXVvG88UexWkAJKtjAH0LUWBHqnh7UIrhY3kZ1 hA3Sbeu0DJx+FeTfEi2FvqMPiTTI5Jo7tpZgJFKmTbIwK4AJBZ cDp1OelU7Hx5pWlMqX+ooI9rKyINzHcpX2Hoeo6VgeOfiPoOra NpOl6Ut3MunxSK8lxtHmu2MttUk/wAI4ycUMEYuteLNUhg8uzSw0yZjhWKfaJPoSflU/TFcm+p3gVIZ7kv6Mr7Sx78Zqtqty1wxnSUSMvIjzgZrBneS5XI wCD0Y/dNQ/Idzvfh7dQ/8JtZtcNI+FkZS7k7TsIxz9RXq2k6rFpXiuC6lkC2l0jWtyT02t 0Y/RsH8K8M8JO2m6pHdyhiAu3AOTz6Cu6uNZtbuMhZA6kdauK0E9z 11NRbTbqW0ZV2+YAAehP8Akk+9Yz6y+mXDtbLE27O1XjyR7jkd K4a28TTtZpaXaSXBiGIpVyTjHAb1wcH8Koz65Gko+c7unzdenP Hb60mx2O61jWtSuLeTV7y8aaaJN0Qc5OF+6SOwBC/hXzvrRmfU5plkcFJAU56cDj8q9M8S6lqtz4YY2EMS2jkrdT7xv XGSFx2BOf5V5jfHzbmdEPzcfyqXLUbRUM93cuDZwzSOnLbFLEf lVIpe3NwRKGVhwd3Brol1m5isbdoXITGyRR6Dt/Oo9cja7jNzZI7JywXO4qP85/KnuLlKkmgyxeHhq6XiEiXymgUHI9ya9C/Z78R3en+ILO2S5ijs7qb7NcQkH58/d/It/OuG0K9L6Zd2z8r5qSYPPYg/zFdj8H9LE/i1r1YEWzsXNy6rnLMFUKg9Msy/rTW4rHf6To39haHqFg9yILS2mmL3UikIoZs8euM4+uOeRVbwRp mq+Ib628O+DXtrJURm+33zh5wueSq4+Xr0Az6muW8Ra7rfiDUZ NJlltvs8Eob7DtKhj0AGMZ2jjr1zivpb4UeH4/DHhOzH2SOG8ZN0h8oB1zztJ6/rTjFbsblYj8KfB7w1oLLc648+v38hy7zkqrH1wDz+JNdnF4ZtZ yqRRRWsC/dih+UAfhWr4eUXs0k11xhQsYJ7c5/p+VdBFYj/AJZIT9MVfoTc5yx8H6VbkukIDt95u5+p61pRaHbxY8vIrfgsVA y5/AVbSNE+6oFPlFc8Q/aQ8Ozz+AhdqmRbyZPqM4P/ALLXkH7P00uneOdMmlJCzXMlsMnrmP8A+uK+qPitZC/8Aatb4yfJ3D8CP6Zr5F8N3Taf4ntZR8qW2oRTD2BIB/QCokrSNIu8bHX/ABw0wD9o1IFIjTXdLe2J7EyQMn/oQFbH7LVza6h8Kr3TQZP9EvojOX6FZsxN+Gyov2qP9E+IngLXl BCl0DEeiyA4/I1B+zzPLaeKfG/hu4yphhl+zxCJVUrBJ+7b5eSf8O5NHUXQ8Y+DkIsvixc6HKssb XKXdq4BO0NtO35eCMFT39OmK9Ts7LT7ux+xzyRRq0ozM44Rchm GQR1LDof4iRjpXA+LPtWg/tKXItyVgbXFm+7wfNJwenHDmvT106Wx1ArGTbWUDzEIJAVlU9z k9jwOep6cYqQe50XhGR7fV7cWrSGOF1XfMc7sMPmVh1GDgcevs K92QqLgSAcNjGDwev8AjXz5osyRXFtDC7NaTh2H3JPmVycjaMK Dg5GO3XjFe+WE4urGynUD95Cre3aqiSzWj6U+ooMbf/r1LWqIK92oMJBBIrwT4y+HYNTiuC/ntstyy7DsY/vFIxk43A5+bBxgA8Hn6AlGUI6ZFeXfFiJotJeeW3urq3+dXgtB +9kR1KkA46YbP/AQT0qJlxPz01K3EtxFbNbAXaM2I9rEyLkbQcNnPUYCjoPXhYYr qK2SF9K3TxupBHP7w8oQo747DrgZ6V1Pi3StKttf1I/aIYEjZRGIFk226qdu4tjJJYAblDA5LDtWXcNPPbQ22GRGZ5pER UTMuG6KuAASMAYOB064rNblM4/VLK+t9Sktp4JmkXAKOhLDjgHjjA/l6Vd8NNLBqluqQb5LhxCWZgExnDA8c8Y7jn8qdfOQ9vcR7hIrM cyqGwfTp83br0qnF5Ud6pEMhycsJX2MOQV+YevXOO/41Sfckl1HTLmLVn0+O3dmYs8CouSVP6ngfnW94Em8jVoJIJp4p G2qWX7oBOD74B/Wqdyp1mLci7b+1UoyFwWcDOcY6njr/KmaDcRW4ifMMsrPgb1PyZ49OvQ/ShjR+kHjqJvEXwI1Ab8PdaOJGZRu+YICfTuPavA9FuDq3wAsLp 5WklsZgCeSflk2jP8AwGvcfghK+rfAzTobt1mP2SW3YnDqQrMo HHBGOK8K+FYnl+H/AIy8O3ZLz2VxMGAwGz1PT3BpyEjrvAkok8iZHfaDz6A+vTvXpH iqNpr7Qr1VYrIjxvjB7Yrxr4dXYeFGjYynILHjpzjpxyPb/wCv7H4im87wdZXO4hoLlQWXPPPIGKEM4nwO32DxlqEe7gvvxnq Vfg1kaVcJo/7ZlxJkRwalHtGD94tCACfqy4/CtaIeR8Rxg489WA9Gyuf6Vn/Gwx6T8Yvh14gJVfNmWOUEjBwygnpk9etK4I5f9oy2Oh/GwajFKzmXyLobjnaRgY/8dr64s5lubSG4Q5WWNXX6EZr5e/bDgdPFelXvlIEktNiuvVirZOeOOG/SvoP4YXv9o/DvQLvO4vYRAn3CgH9RWkSZbHR0UUVRIUUUUAFFFFABUV6/l2k0n92Nj+QqWs/xJJ5Xh/UJM4220h/8dNJgj44+JkgfW9JVuSIzMfwgRv55rR8aQ/ZtZ0CAcHTvDE8n0ItF/qxrO+IMJfxNaRgcppVx+YidR/IV0XxOhH/CYa/t6WvhmSMe25kj/pWTNTH00fY/2W/EUzD/AF08KjPfLQCvnO/YuxcnJPvX0f4gAtv2TdvT7Rdxrn6TD/4ivm24wGxmky47FNmxn5FPrkVCxUOsiZjdTlWQ4I+lTyDJxiq7 gEmmk9wsTT3uozkNNfSyuOjy/M4/4F1rrPA11qWp30OlHVpPtM7BIFmHmRux6KTkMufUVxqgg9/au4+EItIPGNhq+pMFtLGVZnXu+05AFK3cm1lcta3oqLqU9hqkT 6XqkDlWBBZA3vxkD/vr61758HvG+t6Hp9j4Y8fWktpDPGo0vVZFPlSqQCqs3ToRg9uA cda8R1a4uNd8QTavemR7i4lZmLjrk56jivu/wv4c0vU/hpp2h6zYQ3dqbREkilXPIGMj0PHUc04q5MmeYSWYkeSN0xNE21 l7g1UudMWMgCI5PHFdLd+Frzw1fx6a80lzZHP9m3b8vtUZNvIe 7KOVbuAR2pZIn24ZmbPQ5xRYDi5NJRSxIGRzyKqz6aGyAMntjp XaXdifLVew+ZveqX9npIdo568hv6UNAcPdaaTw5OMcfWsqWwkS UjaT6kV6i+kKYcbB071iXOkL5pVOD2wKVgOGNo/JIJxVe9021u4zDeWsNxFIuNskYYY9ielegf2A+w7e/Tiuc8TW/wDZVuZZgQzHEYAyWbpgDuenHuKGM880f4c+FLTxCLu9gmubVW3 tavMFQLnnLcYX6n8zxUsXiq60jw6PC+kXVjcaXaStLG1xLmRAS ThWGDtyW4x0Yg8Eiu20rwYl7Gtz4mDygneLLfhE95CMb2/QdBxT9W/sGOE2OgabarJ0JhtowmfqVyf1qdhpHntt4ykW6V9V01Gib5Wlh kbAU+uD09jXeaHBoOpkNp+n2FxKybwpXLlf7wDZyP8AdJx3xWP c+Btdmtmf7JYyBuqwosb/AJKAP05rgZ/7U8KakIJPPgiEm9GGQ0L/AN9e49x/gKFIHHsetapZWsp8uaO1PGAFAbHtgCsX+xCl2Xg0uJo+wa2D5P 4jpXqnwa1fTfiBp7w3cdvH4hsVHnDaCLhO0g9+mfz716ZF4Ufa AY4h77RVcpB4dbeAtA8V6JLaalo9nYXLD5LuC2WNw3b7oGR7V5 N4i8I6To05sPDxt76TJN3qkvJIHSOFMkKuern5j2wOW+tvFHgz WptMu4tHngimlt2ijaQAbCQRu9D1/SvmrUvhp8QNBnuluPD7mOWd5Q1tGZI/mJY4xkgc4ptajON0bRoYfD97qE1rDe3f2lY8SDIiQgnp2JPf2r Rt/sMGh3Gl/Zk0+G+2hrm3T9/bSj7jbh8zxkkhl649wM0r2317SJ2la0uLYkYdJIztYehHSsS+1 dJTJi1uWmkXbs3Epn/PNJ6AU4rq702RoLh5Y7hC0ExL7njboWB/XPpXv3wN8G+G9Y8JWmu2dkDr+nT5nMkhcTlSD36ZBB/GvLfFekx6p8MdO8YwIn2yzuTp+qIG+YqAPKkYeoB2/QLXafsieIja+LLrwxO+37bF5tsSekseSB+Klh+XpRs7DexQ/aM8O/2Hq76hpSmLSdaiE4jQYVZFYF1x25OfqT6V4HFLnVXLMqKW6npx X3f8cPCkeueC9QtY4dz24F/aDGTj/lon8x9WHpXi3ij4OxXnhnOiWcJu0s1uZWCAHcVyAD780uRod9D zG28HG78LXd7Zrv8AIvVDeoVsYH5En8DUXgTTZ7fxXYafcxP5c 0hjhfHBLggD6hsV6L+zjImp3XiHQLhQxlsY5VU9inyk/X58fjXeap4CjmgaaziKywzm6t37q24Mo+m4Y/4FQlpcm54z8ZvAo8L61dX1jGwsLsIyNj5RuUOP5NW3+zzZmbRf E10c5V4Cp6/dDn9cCvb/AIoaAniH4R6/GYd00Fqs1vxyDGS4x/wDaPxr518CW/jaX4ceIT4QiBggdZNTdCPNWLawAUHt1JxzxRYa1N74C2ct18Sr DUXJijknlkaQPgvyeMdcZNfXvl2ZdfOQsncAda+PPhfbX2jfEC z+ztdXVkk0UjLaxCRsyIHATPqG6elfatvYhoVbaVyM4PUVcSXu QW+l6DqUwEVp5Uo6PFKykY+h/nXVRosaBFGFAwBWTpVqkF+HAAZkIz+VbFaRJYUUUUxFPXIBc6N e25GfMgdcfVTXw/qim21q9j/ucj/gLD/CvuwgEEHoa+I/H0H2TxpfQEfxyj/0I/4VnUNKfU7/APa0he4+GfhXWouVt5sZ/wB9Qw/9Aqn8Irxbf9oe6tmYGPU45CckYHm26S8D3J9MV1XxMtU1z9ldL hwGktrW3mU+4ZUP6M1eefDbUVg+MHhS+mfal9ptiEwzAlghiOQ Plxkd+4GD1zL0Y+hyn7SFitp8RG1YAwTfZ7F0UYG4rHtYnnOQU xwO3OK9XJN3q01ubr/R54Um2mQ7wGjGdmcgDIHb+InqOee/ai0pzqkV1FFbusllcwyhgquNkz7SCfcqePmwrepq/orJe6FotxZXE8VxdWEDsydHKrsJPfAA5x2zUsGdDprwx3AaI3j iMszGZAhhYgkDDYJJwTnjr78ev+EpmuPDFi7MpkUbWKjA49snH 07V4tojhYAJJI/LThZVKkfKRkEAcAEH+I4ye+RXsHgoH+wSnmBikgLN/ePGT7d6aEzrIDlAfWpagtlCqoGelT1tHYzYh6VyHjm1+0afcRC RY3lUxoWAxk8Dsc/T+VdgelYXiaNTatJuaMqDh1AOPpkHnp+NTIqO58K/GPSpLHx3fanqSvLZSJDIIymftBC7VQnb8uFD/Njt05zXniW9tdW+6KGdNsTskeTJIpAGXJCgFRhvp+HPufx/s5tQ1yGS+/eWsMKhVMjD/loVBOOh3kghf7pNeSakIBqTxYWMM5KFULGIqWwnXdgjC4yfXPS s9y2c7bWMtwgtpLt3CsUggKtuBbnO3BAyew5OfxrDuYIlJjBM1 y5wvlgswwcDIz6e3pXV65NLNeSlLS2spGcfJCjKowMZG7JHTJy ep6CuX1IgXh8lUjbG0YGMe/JOCfr3od0JjvDMklrqcT+XJIjts2gjJJ9vqRWvqOlXFvfHULS3 KxbgzKvRSD29un51g3L3DXH2grL+7CgOd3GAADk884z/ACrp9A1aW20j7RcBp4lYxkKclB2z6dRz36U2I+3f2O783fwums XjEZtLtkK98MoPPOfWvMfhSkdr8RvH2gbw8U0rkJuzwGcepz97 1rt/2Nr2ObRtVhhkR0YxTggc5IIIP0xj8a5S1tJNG/ah8Q20krEXkRlwU2hi2Dxye3fjJzxT3SGjM8BSYd1/jh+Qc9emT7+vtzXu0Ie68DzhfvIN4zj0+teCaIjW/ivULcvtjiupNqMSc8kj1x+Ne6+Ff9K8L39sSAXh5HX1/OpQHD67IbfxdpN2oJVygBB9eDWX+1Fsg07wLrccbmS01DaWAzj o2P8Ax0VY8YM8T6NPtJVCOc91Io/afhWT4RafeMAWttUUqB0OeD/P/PcYLcZ+17cXUun+FkEZaze3ll8zHWQqvGfp2r1P9mu8+2fBzRS TkxCWI/hI2P0IrzX9oQ3V/wDArwjrIihdvLhE8pI3DfEOBxnkrzgjp37db+yFcGX4VNATzBf SLj0BCn+prRaMT2PZKKKKsgKKKKACiiigArG8cvs8Hau+cYtJP/QTWzWB8RTjwNrB/wCnVx+lJjW58t+KYPN+JJtyv3NPdR/wL/8AarZ+Ig3a/wCPZv8AnlpcMY/4FcN/hUWtw5+ME4JBzZw8f70kQ/rV74hxhZPiVNjpa2a/nM1ZIs53x61vbfs2+HYbsHyJtVTzQOpTdKxx+Arx34ot4Kl1rV f+EWSR4nmt/scigpEkYixIMN8xJfGM+h9a9j+I2jvq/wANPhxozXX2S2vLyRHlK7grEfKcZGfvEde9Rax8MPhn4M0BtR8 SyXV2yKDiW68t5j6JGhBPX1OPWk9y0fMZhfJXKj6kVAI5HO2NG duvAr2A63o99qos/Afw00+Q7jsn1EGUkY6kMSF79WNbWlweJ7ZSda8UaTpybSDaafa KcD38sKB+Zo2QNniEGia1cW7Tw6beNGvVxA20fjjFNsYbpJDGx 2kHBBIFe0QWfhqHdDJealqYbJcSyKoP5gGkg1Hw5pJ/4lXhK3ilU/6yaUyH9Ap/WhXJbMPwZ4f1l7VJJFDWm4OAkqMSSQM8HNfoVosflaVbJ6ID+f NfGPg/xbdXniO1tb2LT4LZ3U7liyqfMOWOWbjk4zX2fpl7Y3VpE9ldRT RFcKyNnIHFaR8yJDdc0+PU9Lms3OCwzG39xwcq34EA1wVvbG6i jnQbd6CQD3I6V2niDUjbRC0tWDX1wCsS/wBwd3PsP1PFc+YYbaIW6Pt8pAg+UnjiiWuwLYw5LNi2Su5jnPB zTLfT183cIghGegrclS18stb3sZYD7o6mrlpCbiLduUnHHvU6D MN7JsbSlZz2GXACZ3Hk5rr3RUbgqeOSKrW8QnnwEU4/ip2GYtvp67hkcDj9K84uYhrXi251LG61sHMFovYuB87/AIZwPct6V6l4vum0fwxqF+o+aOJjH/vHhf1Irw/4a+ONE1bRYLG2dvtsULtLHkElgWZjx64Y4OD3AIBNRJ2HEm8W3 c1xcLpFqTjP74juT2q/4a0aKziEzAM56HH4VU0e2aWee/nUq8mSAR93P/6q6BJlAAXG0cVCRZo2wVBnIrL8WeH7DWrZJ3gDXUB3IVOGcd1z 2yDgHsasRzMTx37UXFw6qTvBODjH0o1EcTd6Xc/DLxJoXj7S8zaW0iw3gQYGHHXHYMuSB2bI7CvX9Q+LclksUD+Hr u/nml2W72so2XCkBlK55BKFWwemetU9O0aDxT4P1/wZcFQ0lv5ltn+HcSw/75kUn/gVeaaL4Z1nxn8MNIvtEtA2taSGtLmKTYpmhDuEYMykZVg64749 q0T7EM9Zf4pa0Uff4GvVUDOGvotwHvVK3+NulQylbnRdRgjGd/7yKTH02kH+dePWHwi+KE1x5yaPplu5bJaVoz+gGP0q9L8HPim5 LOlmz5zkXGAD7DbgVXQWh6P4j+J9wurWCWXhee403ynmvDeWpV 5IhjJjbPBVecd+elR/Ev4daN4wtUl0+2tRa3cIltLqCFUdSRkNuAyfoTXnj/CH4rkkzbLgONrK+oZTH+6Vx+Ve9eFtG1Tw58KrHTb1PP1C1Rmd YskDLk4B64AOPwo3C580/CTwTfCDxp4C13EUrQl4skkOSrAMM9eQpryz4Yai+k/EnQp5ZDBJDfJFIem3LbW/rXtviPxY2mfGG1nUmGS5QxGFuCxwBjHevn/4lRtpHxF1WJY2geO7L7CMFC2G/mayLR+jJhtbrFtOv+krZuxKj5WVmwcfiufxrkhYTweGEjsoA0s +YCR/CFJWpPhVrEviXwpoXiPJwkbJMTx+7kQH9HVf1qPxVquneFrHUE ub1hNIV8pFYcAM7ZzjjPmY9eK1ZB88/DXRZPDX7UsmloD5c0chYdirJuI/MGvpa8srKySKxSTNxOJHiTacOqsN/PY4I/P2r5q8M65LafFSfxYNIn1mWQeWirIyeWv+zgMT+P6V7VqnxN8K GOyubqK9tdQhkIa2mi8t4lkXG7nhl4x1/lSjohs7NdNtpIDopUlnMr7x0ZUKDafqJAP+A18Y+Dtf1nwjr3i/wvo00cUV5K1lLvTJCB2UFT2OD1r7Y0Fobm4tb61uEngYyN5g6F Zfm/mK+BPGU9zpvxl1pdm2Q3spZXGB1JOfYjIPsaJMImzJbvo/xB0uyjt5Whtlti7QnDybkUg5HORkAeyivtPw5eajb28aXTvLEV GC5JZfx6mvirVNT1TxHrGnXmgm7j1CKCGF0gkIkZ41K7hjBzjr XuPgT4i3WlaSlh4ng1dr6EYdseaW+p3E5+uKSYSPoiKaGD/S5rlWCqcBeSfYDqTWtG6yRq69GGRxivB7X4w+F2iaJbTWJnR+i wDORzjhv0q+P2hfDkUSqNJ1AkDHzFVJ/rVqaJ5Wz2uivDZP2htPY/6P4fuHH+1Nj+QqGf8AaHgRM/2DGD/tXoH/ALLT5kHKz3g9K+MPi+UX4l3gUjBunX9cf1r06D9oae4bauh20a sxRG+1F+dpbI+UZHykfWvH/iItxF4sg+2yrLcPLGZXVdoYtjccdsmonJMuCs9T2zTCb79lXUI wNxj02Tj/AHHJ/pXi/hGfytb+Hd4WZSluFzkchLmQOBxn7vUg9OO9ezfC+QSfs+azbv0 W0vgR/u5/xrwbw/f+Rpfgtt4Ecs13C4IOCqzBwCRzjJXjHNS0wPWv2nNGS/vLU3doDaQzXbPOGUMuER1HLLlMuc454GPfC+Hk0reAfD7GNiiW rQodm795vbgqQc4wP1611f7TxD6fFKWiWSK9DxbyuwM0MWC+4H coPVe4PQgYriPhHdTn4Y6RI8aSJFdT+a245GHAGMHk/O2KHuLodvb2wS6ht41EcI2/e6kg52gA8E/n17dfUPh98mj3MTkNs2ngdRj09P8ACvLo3txxAfLfBKksnzjOT wOccjnvg/j6L8LWIsZ4lk3MECtwTtxx1PXGcZPpQgZ3tuf3S5OTiphVOxb9 2oJA46Z6VbB4rVMhjj0rN1hZDaSLFJscg7Tjoa0qpamivFhyuO evTFEtgR8m/tG6SIUtJJpJbh2mfyyfkYDJyuSu48FRuY4yvpwPFryNHglFkhS 3hOBcSIxk5OdjYyo6E/Qdeor3n9peG4gu9NNrYJcebMfMkwQyMBjbuPyqThuOOgyG4I8T 1mIzo1zdStLdTNudmIWRX+bOSepOAxPOMe9ZK5oYd1ZxQsYS0c 8RYYuYVJ5CgugzgHG7k+oGDjmua1y2mtZyqhf7jHIbuOh9e3Ha uzkinsd8jWZcj95NHEcJ5J+Yg45A47YrnNTtEXW49vkBIyGlml DvEDz9/bnI442jn0ND1Ec3eW770SCcTrIM/KuNuDtAPpxj8xWjDa3cIul8qNY4mXzYztbaRU06W+oLD5cNtbS SkruRyqg55Yrkhc88cD8MVLp7yW8lyHeSVVUq+OQy5IPzYI7nB APWmB9ZfsWz51HWI2c7TbxlVbkgA9BwMYBAxjuMdKf8TYm0/wDam06VUKx3tn945wSAc9+uQPSs39jKQnxLeuqRCOWyypBO7gj gZHPufXFbn7Q0cVt8dvCF0JcPKhQoSCBw2047ZJPOe1F9BHHzq 9r8QdU3AMBcEgZ5I6/n/h717h4APmaddLwwMBHv3rxDxJJHH8Sb5jktvVhhQedo9f8APHv XsnwzlWSN8fcMbDDfSk3Z3Gzh/GJB8PW8u0KyTvgdhhjmo/2hjHc/Ab7TuYtDfwOgDcAsMZPrwfzxT/HCIPD8owfku2BYdRnrx+VVfjJHFP8As6XrOSSklmykeuR/n8aoFuXvEBF1+yDoUlzJl8IAWOeQ7gc+owP1Fbf7F8+/wbrNv/zzvFb/AL6X/wCxrJ0AWuo/seSLcILn7Or7CVwVZZshgOxAP86l/YplH2PxNArZAlgYf+RKa3E9j6LooorQgKKKKACiiigArnviUce BNY/69mroa574kDPgTWR/06tSew1ueA6pFC3xhuXwd32K0+m77RAM/lipPieAmm/Eh+clLEf+RqNUX/i7U744+x2/6T25qf4qxY0v4hZ6H7CP/I4rJdyzN+IkGlX37OulWd7P5N4jxSWLAE5fJUrxzypP4gV4XHo OrTSJP/ZtzehcLvmYkFRwByemOOtes+PXk/4Vn4TZXK+XM7cdikcpH8q8NWeLyFjk1G/wq42rMwGfpmlbUeyOwEXiC0uc2uh3fkbSoihjVeuP4gQD+VVdR m8RAFx4JvZcDgyzjj8h/WuVi1RYCRDq+pxH/ZuW/wAa0LXXb5YZxHrl5cDymPlzuXHAzkZ6UXYiGXV/G7TiO28ORQHbvChS7bfXlunvTbDXfG6TBja2Sc/xrCmP1FaHwlk1Ez6zOoW7cWCgvKc+Um0n0PqB2rC8USJ50nku5 TA2hmJ25A4/Ci7WhSiep+Fm8aalaBptNvb2KVfkW1hYoxz13qSCK+gPhPaeOV 8OLpVxbLYgSMwurqYSPGh/hWNe/wDvMO3HXOb8ObKMtaQlf9GhgSOFexVVAB+lewWMKRhII0CR7gC AOOmf6VauQU9KsLSyle2t5XuLpgHubmQ7nbPQk++DgcD0q6bCH JyF55yVzWBdeG9bstSm1LSdZLzTtmWOQZV+MDjPt2Iqhdy+PYv 30k8CFASwFv8AIfr82fyo0QHVf2Ta7gwWPPsCKelioO1c46g9A a5GDxjrqTKtzpMUiDh/KuRn8AwFXL3xbqLpmx0lY++64k/ouf1NF0B0R0yHfucs2OwP9KZDYRx3JaPA5BPGKh8N69HqxeIwy wXEWDJGxHAOcEEcEcGtho1SctuIZu3UUxHmnx78yy+Hd75bkbs tjt8iNJ/7JXyR+zXp09746uWjO1Y7JsjPByyj+RNfZXxotmvtFttPOz/SFu0HOBn7HPivm39k2w+x674ha6jZLlIok2tjI+aQMMfVR+X0r OWjLjsegX0X2WC428gziP16c/1qBJ9xypUZHQHitPxQyRSXPK/Le46dMqCP51zccmJAqnC898gVmaWNhHwRz8x6ZOcirFqJJbkBh yHUf+PDP8jWazlACzAgDJ6c+/14q/osqG4tuGyZADkfl196aZJ2Hh2Z7HxvpMyr8tw0lsw9Qy7h/wCgmr/weiTRzrWmId0ketXtupx1+ZZEz+DsaxbeRk17Q2I/5f1Of+AMP8a0/BV0kfjzxTGxGI9fMi5/2rRCf5itUyWeoG3mYYa8k/4Cqj+lLHDIFCyXLtjvgAmsqTXIVc4diOmBjFQHWQ/3XAPueaq6M7G6YYDwy7/94lv51R12dbTT3yB5O3kk4Cjvz2rNbVgbeSYuSkYyxzx/nivnD4gfFf8A4Sm5ltrCdmt0laOJA3yjH8RHc+x6UnLohpGb8b BDq/xG8P6tok0G6wuVMzNtG8blPBPXGD09a5746aLpWpyfEPXSCLuw m0vyAvUb1dW/Dp+QrCuUDah5ksjvMDu3sec1qva3HiPxrdapouraZd6Zqtitpq Vo4MjoUAB3J2YMoZST3781HQtM6/4BfGbUdJ+HEfhxNGkNzp4eL7W7DyiCSV/EZ6D0681QuLu68Q6lLeajcSSoGzIxPLMeg/z2pmv6da+HtGhsLOFIIYk4Vf5+/wBal8N20hi0u3JI85TOwAzkknGfwAP40asR6j4NsrPTtJjlEKq z8/KvSuN+Pi6Xq2iwSLG6X9pJmNvLIyh+8ucfj+Fd5DbO8SW0JK5X LnHTt+fFQa/8NR4h0i5NvMUngiaTLgYbA6cDgmq1aA4v4E/FKHwtp0uk69JiBSXtriRjtjJxlWwM89j6mvFPGGp6dr37Q7avb FZtPutVt1fByrKdiuPcEbq32sSjMjLkg4xivNbqyl0v4g2drA2 2Oa8ilj9suP60twR9D+Fvh/ptteeC/G+mTokNzYvHcwlvv3EcTp5i+5KEkevNcn4Y1O4vPAl/qk8oku1klG/GM4xgn35q94Q8badHJ4H8GWE8l1NbT3JuGX7kQd58An1IcVQ8G aXNZeDrjS7rHnPNNvGemW6fkBUytbQpGT8N9S1JPBep3ZjWcKx keV8kR5OSoHv169qo2Gq/ZoSXsraeWQ7meUFsZ7AZxWn4dY6f4F1XT7TY0rziOUOccbeMD2 IIz9KyrHR5bmwE4uYI2A5jeQK2R7Gpb7Gi8yW512WWB4VtLOIM MExxAH86g0u80uB2k1CKSU4ICgcCqr2jjOWYflT30VzGGaeAFv 4fNy36UajaRp+Hr86i0zGFItkkO0IMD7+P5Niuq+KLef4q0yXu 5hz+LH/CuU8I2T2xmRurSRHBPI2uGP6D9DXQ/EYebqem4OciAf8AoVV0Ie57V8Jf3vwt1+0HQjUkx9dn+NfPfhm 4kPhXwpCDGqnUb4MXUNgL5LjGenI6+9fQXwPy/hDXkPTzbzH4on+FfOfh2SMeEvDsbSmNjrV2A4kxs+SE52nryB+ NN6EHvn7SrzHw5aTJykslusrHI2h4D0K85JQDjJ56Yri/gnayyeCraONSjQX10Vw2NoYJ/eB457//AK+w+P11JF4Kt2VZZi0WnEhFVtoMcuWycjopGSMZNcH8H71F8C tf3PmHydTkY4bcdrBcgknA4pbsR29vYrFOkzwojLJtkMUYCrhj yOpb6Y4wO4Br1H4a71e5jZcKYyMZ6YOMdSf/ANdeZs0kJhbzHkM4JcRBXRyMggnJwOQB+dei/DaTdcXT/Njy2AXII4PUcnr/AEPrTvqDO7sX4wTyf5ZrQU5rJst+c5GSQP51pxNnI/pVxZLJaqX+fKYqATirJNU798JjG72/KnISPmT9p22mi0i3mheVbdLwuSvB3lQw6dsruzj/AOv4yL2CGw8q4hjkgMnm7JGJaRiuCGJIwmN3K4JOORxj6K/aF0+zl8OedeyvHFFcqC0ab/vHkHkYBwvzcn8DXgf2KKKQStuQK5cfuAE25ADBskA/ezkfw9zxWZoZGoebZaPDZ6lFcizuSNqpCEk2q24nJHLYIxk8Bv TGed1BJtRv5YoblvKiheNPk58sBjgADjJ9cHn3xXT280txe7I7 54Lhd0qI6NuBIT7vO0kjJzkZ28noKz73TLcThrjEkfl73dWEMo DZZfvZLnLckK3CqRxSVxHn7DypFMLOIyqkkg43d619Gs5NUvpH tjczGGHzpC4DHhQTk5wFyOvoeQcc7FzbBMxzSCOCZF2rJGxKjr uzjuT2POegrI0ye8e6uLeWeNFZz/pQLDI+6VyBkqeOMU7AfSX7IUir40c5ixJp7llT+HG3r+XvXUft Qxyj4o+BLuPICO6kgjqegx1/GuO/ZGbb47mVZDtFlKGA7gbcHrz+Fdx+1Sbn/hKvAXl4MTXrKf8AeIUg/kDT3QHn/jJGHxCu5CMp5iHOeVBUc8fjXsnwrkzEVViSYyWyMA14n49lQeP rkO/3ZIhhR6qO/wCFew/CCVpRufJYREDHB4paAcv47ZRo98dm1fthAA4wPWs74nSCb9nXV RIPn22Z/NwPWpfHjE+HL+UHAa+YY7E55+vPpxWd40d2/Zw1ZVEfENow59ZB/if8imgW5s/AuabVP2VPElsikvHHciMZyQAgOP51N+xI5+0eJYyf4YT+r0n7J gQ/s+eIxv3bjcDkdD5P+NN/YoYtqniX0MUR/wDHmprdA+p9N0UUVqZhRRRQAUUUUAFYXxAXf4I1lf8Apzk/9BNbtZniuLzvDOpxYzutJB/46aTGtzwHXYSnxHaT+/pbvn/caE/0q58WrcLo3j9vW2gk/wC+bn/61QeJJF/4TDTHzzPoF634+UCP/QK2/ipb+ZovjEY4l0qVj/wF3f8AwrMs8q8Z77j4c+GI05LX1xEB6kiVQP1FfPmu6XrNoVn+ yyC3mOY5BjDV9PWWjadrfwT+3atdyWkNncho5o1LMjvOAPlHXO cfQmsw+EdB1CxVLGWDUbZGLKDOW2seT0OAfy+lTsx9D54tfBPi 66to7qDS2eOQblPnRjI+hbIroNF8G6lpGl3+pa6IoSLdlji8wM fqSOPb8a9V1jww8MaIt/qmnDGB9lDTDp6BHx+dcJr+k3kWTp3jeeSVeo89A4/4D8jD8qHdiViLwJqFppd14ktreVCLuzjit5ZON/GGGPX/ADzXKeIrGTDm33TBgcYHIIPSory98Z2cwMniS/BVsrm7fB/DOKJtU8Z37hpfEtzIR0xqO3+oosWppHv3wX+L2jNYWVl4mlm07 UbaNYWmmRvKmCjAO7HynAGc8e9fSvh7xBpuqWyXVleW91C5+WS GQOp4x1HFfDfh+/1VIljkvtTaQYKn+02KlvcBun0xX1F8D/h95vgqPUtZlvE1S6YutysjpKq9hknDD6jHWtEmZto9aYMFDrIC mfWp1VJEHmjJx+dcpFd614UnVNaZb7S2OBfxptMf/XVB0/3hx6gV2UXlzKs8TEBhnjoaEtRNlB9NspWLCFOep9akjsbRV8pb ZFXvgGrix4z+8Y/WgQR5JK7j6scmnYVzkZdKutF1lb+wiE0e1lKk4yjYJUkDgggEG pJ7HUtcnF5I32RYv9Sglbj3yMZPv+HrXXBRkkE80MEzziiwXPP fEVtq1vqOgXuq3huLePUljcHbgCSN488KP71fP3hAnwh8V9a0O Hy0tZFeIhvmIkRwww3qVzx6Z44r6m8b6eL7wxdx2wT7TCouIM9 pIyHX9RXyb8dtf0yH4kR63ZKpa7ihuZAMbkbCjHHIJQMDxzu74 GM5KxpE6bxBfySf2kXUbormOUc5yCAP/ZTWLJdHH3yec8dv/rUxrn7Q7bpA0dxDsyOR6g/ln86xLl3VCrHaVHPPU/5FYmp0seoJIuwlVUoOc4FXdP1ExylumxlJwewYZ/kf1riTdlBksTnIHtkHn/PpUtnqHl48wFt3DYPOD+PoTVEntMNyv9uabJv+WGdp3A6YWNuf zIrlfAvixdR+Iviton3BdTk2Kp5JEMEQ/wDQWrBvPF9taaTrGoTyhWsNNWN/UyTyYCj32wuPxpvwJ8PHRr26vdTJGpXCrdXaE/6qWXc4T6hGTPuTVpkM9e2XzP5uBuGflZ+n4io1h1HzOTbRe4dm P4Yps+pLjBk5+uap3PinR7IbbzWLOEgZ2yXCqf1NWrMVjqdPuE is5bO9bzopeHbJ3cjHH4E181+NvBN14K8RtPJA0mjy3DS2t4qE o6sxYo/911zjHGRgivWG+I3hNbhLddctGeRgq7CWUkngbgMfma8/+LXxb1Dwm0r6ebe7t2xG1ncoJIZieu5T7Zqb3BHGamLcXcs8V1 FcbwdgTO5iRwMYzXovwb0IwnV4rjS7Wxu4Gj3RW86zIeWDfMrN 8wbAYZyD1xxXjN58afD80y6xafDvTbDXIRmCW3u3FqJP4ZDbkb SVPIGcZAzWL8HfHGveCNdg8Q3CTyaNqNw8M5ZvlkbjeQf7w3KT 68egwBY9/wDi3assRbr8grd8OaQqatpsqxnH9nwEN/2zX9OtVvHMlrrOipfWciSwSw7o2B6itzwZdRXvh7QNQVR8tuLa QejRnYQfwAP40COssYfKvrgepXGfTYp/qa7rwyFOm3hIGSuD9MGvOvEMz2F5HfxqTDOioxzxuGcZHuMD/gNaWm+MIdO0bUri8DxR/ZXIJH8YU7R+NUmB8/ajaM082yLcC5z74PP6c1wvjLSJLhra6srVpL9bmOC2dV5805wu fbO78K6vVdat7e2uJ5pFiTG4uzYAzkHP51zXwu1xNd+JSXF1PF b6TYgyxvLhRv8A77MfUZ+lIpGtrF1H4CU2GiBFuLfYrlYgNzkE FmYjLfMG9Og9a9C+Gvha/wDEnh2K/v5Us2lJIMVmAxHrliVP5VwfxGNvceLob7TtS0+4tWkTa0cgdGa NQxyVyCf3mMZ7V9Q+AtQm1zw/Z3YijBeIFzH9wHuBSikxPQ4zTfhHohhnnlvrhCDudxaQDd7nEe a3LT4EeEb63iuJ555CRkEwxqR/46K9FgS3RFglsUdWIBZgGyfetqytorS3WCEEIvTJya0STJcmeV xfAfwpEeHunHoxQ/zWp0+CnhVB8sV1+EoH8lr1OijlQczPMU+DHhBXDi0uN2clvNG4 8Y64z0r56+MmiSaL43m05pGkWG7jEbng7CCV6d8EV9p18s/tMRB/iKAo5eS3yffbiomrLQqDbZ0/wQwnhPW27h7zP/fC180aJGJvB+jZxiLWrl8n/ci/z+NfTPwkAj8Ga04PDfbjx7ACvmjw0AfCukhwwWO/vJGK9T8kWPpyAKkZ7v8AHcwN4Vsp55YIrV7OyBaQ5C/uJeigZycrjoDtrivgjLBH4Pu5ndZbeLUJSrkspKYXB6Z5x0x3r pf2ixa/8IvsljYlYbFFYIG4EEhGeQOpH58c1wHwluzD4OhnmQSySak8ir 0VsBR06Z/DGM0tBHosF7ELwYtTBNcyF3jZCGcKCQCByCST6nAr074XfLJOA xKrCUVTnO0YHJJPvXm9tcK06CVZXuFGwJ5oO1skjpwTgH8V7AV 6R8OZg9xduqMB5I+dl27uTjjsfUeuaAZ29m42qOSwOP6VqRSNw uMjrntWHaTnPH4dK04JcDB6+3HNX5g0Xmb5Sc7aoahLmPBGAeM +9SSTbUByMVmajM5RgCDxwaLiSPE/2j7mFfDtvaT3LRxT30XmAMuSM8Ag9h8zA+x/HxW6iuJpJ4LiaMxyZIMpUBsHeAoBwpxnv3IOeteq/tJanLBo0NxbyWix+ehaSQ7iADkhQM5xknOD6dcGvHUjjl0hYor GeAvLG8eZFAVSuVLbgOSCDnIIyevWpQ7lHWzaIQ9tDFfPKGikl klUI53H5shgyZ+9n3A5B5wbaa6fTWSWc7JAECkFiAoyoHcjIPI P+FampafC97JFZb1RcR/NychskMxODyM8cfzqAWQu/JjMc0dsquWZRhjgKX6EDGQe/f16oVzNkuI2vkeZUe2QsUhRiy467fmz3I9c1QghW3WCaJSYQA7 IVDFcnKgn3GDwR16cVcvooWkSYJci1kD7EcpIxyRxux+vUHJ4q nfWz+UkKIltGNqyAfMynPc4yMbT79qpXGfRP7I7RN4reURtGTY TOVwQFYlcgfhtP+TXb/tPhzrfgmQrnbeEZxjOV6Z/XHt7Vxn7J7ztr+pNKrtHDYmON3GGC5XA9en8hXTftM36nxl4I0 3eC7TSTEYOVCgDg9Oc8/QUWsgPM/iDcJH8QLreEYvPGgHdfk6mvaPgu6+bKvmEkRDt049xXzz45uPt 3xi1G1DkG3kSZMNgcDkfqPyr3/4IbAt5KMYEfBJzgfWkmByXxJlYeG78yIo3XzKuGB4B/wA9azPFs2f2ddWyQcR2SgZyP9aKZ8S55U8H3TsSzSXsjA7SDty cDH6ZrN8azhPgBcxmRyJpLKPjjGNzZ5+lO4+p3n7HoP8AwojV1 x/rbmZenUbMUn7ESn7X4kf0jhH/AI8/+FXv2SUFv8E3R4W2GeZskj958vUYJpv7E8ShPE8iKQu6ADP1kp xtewnsfSFFFFamYUUUUAFFFFABUGoR+bYXEf8AfiZfzFT0jDKk HvQB81eII2PijweR/wAt9Nktj9XilFd343iF3oesOoyLnQ7kj3zbxkf+hVx3i2N7fVP B10FysGpmFvZUlZD/AOhCvQrW2E+m6ZA/Jn05YH/4FBtP/ouskadTyjwas118BtRtLWUxyw6jYkSAZK5nhO7HtnP4V6Nrfgz QfEDJPfWdpLeD5hcQqYpf++kwa4H4JYl8A+LLCUZMVu0233Qkj/0CvXbciOzQp3UYI9KT1sB5zqXw7uYoJE0rxLdRqTgw3apdxkf3 SHG4j/gVeceMvh541uFEdo+nO5XJW2mlhU9jmNmZMf7oFe63BdJZN7M2 fWsa7mu1kXy5hGM4G4jAFTew7nzNqfw5+IGm2sdzPoVldRF8Yh n5/EAjArM1eJ9FMS+IfB7Whk+632zg4+qmvps3F0krRy3sMz4yAqD Fed61Fc3F3GniMW73kgYqmBsYA/wjuBxSv0A4HQtOt5DBeW2gXkSZDq6yxkY+uAa+4fAOpS6r4O0y +nkEs0luhdx/EcDk+5GDXy7PHnSp4IFCZiZFAGMcV71+z5fi8+FujyccQKuM/wB35P5oa0gyZI9CuYorm3kt541kikUq6MMhgeoNc74NlXT0vdG klYxafP5UUjngIQGUE+wOPwra1O/t9NsJr26fbFEu4+pPYAdyTwB6ms/wtp1xBpkkt5tW9vJDPP3Cljnb+A+X8Kt7k9DUa9i3bUV5D32j/HH6VH9rmbmKGJx/12HSpUtYlOWG/wBj0H0HSpwqjoAPpT1AgQXEi5MioD/dHP65pi2UA+aSNXJ6mQlv51bqOeVYoyzfgO59hRYBkcFuBiOKM D2UV8f/ALT/AINbSte82GM+VkvAfWJiW2/8BYt9Qx9K+voo5SfMkkcE/wAAOFX2965D4teCIvGHhuS35kvogWtyxAHuv4+vqB2zUTV1ccX ZnyB4PvmXTY7Wd8tDwjY6r6fh/Kt54o7g+ZFtz3qnbabHoWrTafq8ZtvvYLqQr/4dOvt+NYF/4kgsNRdbPzPLU4Gec1hJWNkzpG012JfGT/SobmzS3t3mmOxVBJY8D/PFR2HjeN7c404vIB94vtX8fStrw/os/i2UXWtZj0mM5lVQVEuP+WY7/wC8fw69Gk2NmD4F8Efb1PxJ8U30kOltN5tnprIf36xDEUr89AS SBjn6Hl8l/wDb7y5udRnuPKnmaXyIpTGCSeCxUgnjAxnAxXq+sWM+uQ/ZXxYaeAIwVAyIxj5UXtnpk9ADx0p9r4X8JwptXTIXUDGZCWP61 foZs8oS806NQgS4ljHSOa6kdP8AvlmIpo1LTIH3waZYREdCsCc fpXrctn4RsF3yWOmQonJaSNMD8SK53xp4k+Hc2hXFl9rt0ldcR yWtkzbTnruC4x689KBHnXinxOv/AAj1zHJJHHFt4GMZbOVAHrkVz83w48c/EOZNV1O2/sHQkJML3gxJJnqwj+8SeOTgehr0bwxqnwr0C1+1yarDqOqlSEn njI8o+iKR8n16n1xxWnJ430/WAsFrq0V3IecKwyPwo2A811/4H2cnh2OLw1HLJew3CfaLqeXA8o5DEjpgHBwBn616BcfCmy1D4 Px+DNPYPdQg3FtPIAC05JOT6A52+wx6V09veeRpT2Sj5pnG9vX 2rr/DkRUxlflxgA+nvS1Yzwn4GaD4oh8JanbySPdHS7iSG+0l4/8ASLYDGXT+/jnK+nIz0PafDvUobLULnw7Ncxrb3jefp8u75fM6FQf9oYx7get VPjb461rwB8U9G1Tw0tsr6naul3E8IbzjGfkZujZAbGQegxzjF Yfj+7tdW0JfGEVrHp882GvrSI5gaTOGkjbjy2z1U4BIyCTmquD R7Lb61HJbtZaigbaNrq4yOmDnjFeRfEjVLhtZi0PTrZyl2y29r FkkvKzD7uT3GR7Z7VJb+IvEVrZ2o17Sbq5hlQGG9jU75VxhfnU NHKOnIOfeqcPiJ49I1rV7eeS1kaOWBCCplVFBDLnB2EtnOOThe eOVcSMHx98PZ72SDw5oeo3GuatLIDdSKVSzs1X7xyOTzwC3Jwc DNdP8E9E0X4T+II7vxZdw3EVwjxzyLEWjiOPlGMZOeR07is/9nmxm0rwBJfuGSfVLwzZPXy1BVf6n8an+IbLe6fKrHOHBP4kD+ ZFD0Y/I4jUNT0K/1O5ltdFni06fWLiWMq6hWZypQbOowm3pjqetfafw3MMPhGwjWa SQLCoAeMIVGOARXxJq1jDpnxBg0pifsVlcJLI6jJKME59+F/WvtHwwyS6dBdW7nyJIwQRxkU4ikdZ9oiaeGM9WkXA+hzW5XJyX 3h7TAlxealHGzHC7iS5PoB1zW7oGorqmlw3YikiZ1+ZJFKsPwP r1rSOhDRfoooqhBXyp+0RcI3xPhic/fuok/LH+NfVdfJfxnlW4+KnODtvv5FazmXDc634XziP4ZazOxwFj1I5/Fa+dtFuXsvCumRGNW825ufk25J/1ZyPTpXvHhyb7B8D9XnI2lrO+cZ77mwP5V4PDEZLLRFADAStlM cncwAx+VZ2Gz039paeWRUtYoyHSSIKy8nKW6ZBHTo55/wD1jkfAEcK+DrZ/tUSolxPIEljP7wEp6Z2nj/IzW3+0TcpHr8zssbut7KqIWb7oghUH04Y5/LjHXE8DCWDw3p8CZAkLggHaTlgAVPHIJ9frVJAzsbW/nfzSuLi2ZAqyL912X77gMckAjv2weea9a+FYZLa+eVmG1EGOwB UHjHbOa8esJrf7aLO2mmlMaqyeYPkjb5Q2CPfPIxyRznp638L5 Snh+7kwFcPtkcsCC/rn/ABpAdtavhhzkZ+nr/wDWq/DLwQTz04HWsO1fcqszMO/PXvV6KcFN3O3rz/KhagaMswxnI/PrWNq9ywVs5AAP8WB09TT5rrb944x156/jmue1zUVjjLbyDwF2+p6fXnA+uKLgeI/tD3a3GmRwzLCkv2hZEZv4QoYlSSOp+U4HYdK8bi1LU4QsZjtXi Z2DrCixrvOW+YjAPXIOeg9q9G+LkkWopDaLqBkcOMxlsKygOdx YdsDGcY+brkGvMrwSP5bTXMsRaNmIQBg20cAED7oCjg9M/jTSBmzrGpTLcGHyovLERulOQjSqecAgDnHH3euccc1BZXSX9o6 yKq27M2I/NHyYJA5HX64wcfjWQYixLSBDIqDAeIgtgYUYHJ6g8+n5xC5gSN WVEMn3n2MyjJxnIJ4AyRwOo+hoFc1f7P8Am2tFEil2OTk4+uPp x/hUb2vlIgRGKPGoYuo+bkDjjpkfpmr9gRNZCd3Yyum8tuGF57jr yM+lNNzbLJHukBZ3K7W68UbiPc/2alVbzV33s3l2cSK55yCTnPfPy4wPQU/4+3PnfF7wlaBFBhheXft5+Y4259Bt/Wpf2ePk0fVJPJMYaWFBgg5HXHr3z+J965v4oXYvvjxbxqcrYW6 KRnoT8x/Qj8qTK6HmUsX2j4zazevjyxI4DZ4bjA4x1zX0d8FTt07WHC8qN u7JPbmvnDT5Y5dbklbPn3Fy0m7P3VBwP1/pX0D8L5BH8P8AWbr5TuVxyQATjv8AmKLdEJHm3xO1GKXwlDGGx I87u2MkY3H+prN+Jt35HwJETSbZJ9QtowhPXbG7H+dSfFmZW8O 6ZavMXZtzPk85JHP4nJ61zPxrvJV8A6HphJAn1GaeTcP7iIv82 NCQz6K+AaJp37PsIJZFSzuJHIHPRyTVr9jC1EPh3X5gdwe6jUH 6Bj/7NXN/Dy9ez/ZdMzsAWsLhFYHj5mdF/wDQgK739kW18j4cXMxHMt636Iv+NXBailsezUUUVoQFFFFABRR RQAUUUUAfPvxlQ2WhSXK5H2DWnII7B5Uf/GvRNLdBbadMSNguWiH0E8sY/R1rj/jtZmbw/wCKrcLnyvLvB+MZH81q74U1H7V4Bhv92REscw+pigmP/jyvWSLOU+CsKQfEbxXoEuBHLJPAR7ZI/wDagrvPDt21x4T0q4f75t0D/XHP61wmlH+yP2mNSixhbmYSKPXzVDZ/8drq/DJMelX1kWH+jajeRD2Czvt/TFS9hk3imaO0EUjypEjlVyxwCScAfUkgVzXjTU7TSfC1xrVxJi 3twC7Lz3xxWr8T9C07XvC0Vrq8zx2wZJXZZNmCjAjJ7DivN/Hfj34b6N4Pfw15sWqwsgQ2dkd4x6F87RzjvmluNGVpPjB9R8Q2 kWhWElyl6oZ5n3bUTBwf6U/4q+GNa1yayuYLuyt7eyV5JmcfOB1yp7fnXB6f8WdaS2h0rwf4T trcRDCjDXD7e3TGPqc1TutO8a+JJ3uvGGsxxQYLm1acsOByPKi 4HHqR9aLDNDwR461W/vL6x8q2uktYGcF5PmkAwBtA5JJI6dq+hP2fvE2maR4ENtqEwtD BO8QgbLOG3l9iqPmY4lHAGa+XRPFpLrp2lR3EMk5VAIAIPMJOB kjLnnsWr61+EfhzRdCskWC0WW7jQLcXLHLyNj5jk9B7CqT1uS0 dppEOo+JdQi1TVbV7LTrdt9pZSY3s3/PSTHf0Xt1PPTsMY+lNhVUjVVGBim3NxDBEZJpEjQdWY4FarQjc lqpcX0cLmMrI7AZbYudo96oXHiGwKiOzmW7uH4jijB5Puewq9Z W7QREMxaRjukkJ+83fj0ouFisuovcnbYW0kpx/rHBRB+J5P4VagixktJ5k3dzzj6DtSvIBw26U9wo4qGa4EI3Hbj HCBgPzpXsBdBXjnNOBHrWatxIZGRSJHP5Af4VKsxUYyGb+Ij7o/GhMLHhfxkih0y60iw1vT7e8tprWTIU4kjkjOcq45GVZOOleaj4 a+F9TT7Rp+tXtur8hJY0kK/oK9m/aJ0ea50K312CJppdKkMzRjrLAww+PdeG+i14FoWqxXFpe2OSUS Q7N3O5Dypz/AJ5FZWV7Fps6DQvh94d0y6M91c6zrk6H5I3gkKKfZUXj8xW7qF 5frJGi6bJZ2kA4jkULkdhtH3R+NZ1x4vkv9DSV28y9tF2XMW/BfA4f1wQOffNeVax4mtb7V2trWS/SMgYDSOrA9xkGk0kPc9RvfEt005EjBQBw2axdW+ImlaSp+26jA jf88kO5z/wEc/nXn8+gprEMiRz3TThSy7rl2U+3JOM/41xlrFptlfSW2oaVLJcwSlTCJPL3jP0J/Wi40j27xnBY+J7ZvEml6jb3GhGFDHjJMUgUbopFHKPnON3BGMH qByOiaRpWqpeXuoXbJBbMsYjQ5eZyCQAT90DHXB9q1/Des2kulqlrpNnbwMmxo5DkFfTBTBH41ka1pq6cJL/TAscMhAltixZG54xk5ByabsSaGo/DC/uLUXVjcQ2qbQfLC7iM5xk59jzXPeEtB1BfFdnFdurNazeazKc4 Qep7Z/w9a3NI1LXGK28zzWlkflY5EjBfpxn6ZrstGh01EAtWdLeViZJ5 Qd8p9WYgZ/DikCOp0mF7qRrqTgNwi9gK7bTpBHZr24rE0i3iEKiMgjHBB7Vg/FjxD/Zfhx9MsZljv75GRDnmKP8Ajk/AcD3NK9hnjXj3VJfGvxNutQtiXtbX/RLIjoVTln/Fsn6YrqfBF3DDBf2NlOWS0uPLJB43FQWH03bq5KKe18NeEZtQH y3Nyfs9mWHIHVmx3J6/p3Fafw3sJtO0m5+0qyy3BjmIJ5GQcULU0na1jp/EEsA0MwtbwBvPQwFECsrluSCP9ndmuCunmutT07wxG5P2ycveY 5zubcw/AZ/StHx7r32G+trWNC7W8bStjoHf5UB/DJ/GoPhDpbXNx/wktzKX2oUjJ5y7cs35HFNMhdz0y8u0tYFtLZVjjjTaqqMBRjAA rltSH2q3uLRW/eSxkKx/hbsfwNaGsTkghTyTWLYiSXUDGfM3Nn7o56H9PWlYnYyPFVrrE+ k6d4jhswl39mWG+lMe8xiM7Y3x0xgeWxI4dOcblz6d+z/471DVp5dL1fUb6+uTgQfMGUADnIAG3t61h+KpRDJ4W0mQyxS3k N0waMlSOQTn2Iz/ACPWuDvbG70jVHi0+WZ3ttkjDJ2MhPCsB7jqPar5rMbV0faNms sDpIyLyw3Hvit6O5ZD8ny/SvAfCnxr0dbCC212ym0wgBN4Bki/P/65NereHvFfh7VbIS2OswXRA5VD8w+oPNWn0I2Oyh1GQffUMKux XsL9SVPvXIy69pkGTNeLGByWeNlA+pxirVhqdrfx+ZYXVtdIP4 oZVcfoafMFjrFdWGVYH6V8aeP7oXnxMuJA2QJJpPyDf4V9Pane yW2n3UwypjhdgfoCa+QZ5jN4n1K5Y/6qB2yfdsf+zVE3cqC3O2vr2WH9niZmbLz2oUf7r3Uij9AK8z8K Rtc+J/DkBAZEmhyPTMzc/qK7Px1dPp/wc0PT1HzTQWat7fJ5p/VxXJfDlzL4+0nJUJA6SuWHZFMh/UGpWqCQ74xzvNrUl0JMfaZ7ptu7JANw6YxnOMJ/nirGlpMNIsEgMZlBHlov3zliB7d+/YntXKeJ7oXWpW5kiZXa3Er7mBOZCZCfx35/Guk0wbbWFgN2yFN+ByvB6E/UcCjQT3Ok0oNHKNsRid2b/UplkGAuMHjJ6Z56/l7P4GRrfwdJEzDeZdu7jJ4B56flXi2i7p5FlkYS24bJjXA+U4J IXjJ4HHTOe9ev6Cqw+CLOBwQZg7YXByCTwBn6d6GM6K0ufk3Mc sOME/59ferUV1tOA2CAT0Axj8O34ViCcuXKn23FQ272/n7fWpS+CqrtULxwMZ980rjL99d7UZgxJPG0Eg//AF+lcV4r1V0tpkWSPLdQSdxzkc56dfX/AOvr6jcLFHI6EsR0K9MY7/5/xrzjxffK5WKbzZXJcbUGT7cZ5PJ+oGOKV7gebeOrzUJtRMdtcD mNUk+dG3Btu4Ej/az17ADGBXG3m0vIpRSSRhAMrnOTg8Ec9u9XvFD772V4ArLIAT5 ahQFboMD6dTWOJgkTYRgrcbg2Cp9atEMmErjdsiLKy7S7nKkDA GDnsQOQf0qMrJMHcRDbJhCQy4yTnp164/I013JTeNqIQTtXOB7UqE+UsSJvDHJJjGDjsD17mqfcC1GGtrQR tvVwTuz+PH4AVn6eSb1HO7O7PA3Y/Dv9K0dUGNzbcZGcDoDVPTWVZlMilgp45wB/k4oEfSvwKfb4RcmNczXw5XqcKD2/KvONXvftPxa8SaiW/wBQZFBJ/ux7R+or0D4WyCx8H6MhdWDG4ncqMhRnAJ564GP8mvFop3m/t6/U7vNZgxPX53H/ANeo6l9ClYuqX+8A4VABz7Cvozw4RbfBm5DNneCMDvyBjj19fc 1836UxbUFO0lTIOB3HWvo3xBNJY/C7S4WDJLc3CEqw3FsnIH16Hr60PUSPF/izPIl/plmcFYliUc84OP8AP4Vi/FyaK4HhvSZLgRTG0klVivTzJSMfklWfiPdG7+IENuQGKOAOcj5 R/n8q5b4rzvcfEuzsbdwTbQWtuoAwAxAYj8260J3GfQl2z6T+zfY advdzKkKZY85Z95/Djj2r3L9my0+y/CfTmIwZpZZP/Hyv/steGfFV/I8F6Bpv2U2zSShmiX7qFUGV446t2r6S+Elp9h+GugW+MH7Gjke 7fN/WrgTI6miiitCQooooAKKKKACiiigDyv4ywnOqxfw3ekMTx1MbZ x+RNcB8HtTmufhxPZ7x+6sgm0rn5g80TfkskX6V6z8WbaNxps8 vERaWCU/7Lof6ivDfgi81jrupaLPxLHNcw7AerSIsq/rbH86zejLWxZ8SanIfip4U8SMEV7+wgaTaeN4Ow/jiuE+OniHxR4Z+KHiXStF1i4sbG5u1vCqkLlnRXJB69SRx1xzX afEqI2+k+HbxPvaZe3Fvx6FyU/Sqn7S+n6Rqc/h7XYnVLya0eK4GPvhBuDk+mC2T9KllI8i8V+LfGnxFu7exvJ3u I0P7q1gj2RA467e592Jx7VO/hbw34YsBd+JLpbu5HWJX2xKf7u4csfZayrbxkmjFrLSrZLm7JI 3v+7iT2JGGf8SB9c10Ph7wINX8rXvGl1Pe3cw3raZ2RxqegIH8 hgCp6XFuYVr4wmuLS7n0qwS10q0XJ8uIRo79lwOp9cnp6Va8B3 WqXeh69f3apcxxhYHc/wDLOMkEhRjgn146Cuu8cafaf8I21laww20CKQiIoVF9+Peub8L Xsdj4K1+1VSTfamIy+OTGvykgeuc9+/fFJFxRyjytp3iO2udxcW93HIMnOcODX2T4R1B4dWlSOMujNg4r 5G17wjd2Zju9dvBodjKwMck8bPLLj+4gH/oRUe9dVa/GhfDenJY6Tqepa7Kq48+/2oB9MDf+BZvrVIU9Wfc2nahHcWyiTfHIBzkVQtdEgZmbUZZdQO Ttd5CVH1Xsfz/CvkD4b/F3xb4n8TwW13fSQ2hcLILdQhAPcFlbp6d6960vxA7xfa9L8TF1 Tgrcw9T7kH9OBWi1IPSrdrGyZ/sGllXHDMI8Y/E9fwzT4rmZEaedw8jcqoXhOOn1rm9B8Ux61bTMVSO+tWVLmIPl SGyFdTjoefToRxVi6uY9ok3NIANp2HCD0Pv9aLhY07i7dnCyOr KR95jjn6VnSXUhv1jBeTPYDA/+vVaL7Rf38R3jyQfm29COa1xnODxu7twB+NICzAxefaVXketW3 kjjUk9QeGNY6lI+VBdv7xOB/wDXqyrjIYnDAfex1pgLfot3C0U0JkhfghuCfoK+c/ir8JbjRr2XWfB0m63bLSWUnBX12E9vY/n2r3+9v/JySM++a4bxx4ntYoHjkbcxXGFpOw0fKGoXlzayb5Ge3mBIZXjY Y9s4wRVOJ457lZW8mPeuWdY2PHrjH8q9OsbywS+1ez1eMLpWq2 7288mBmEnlH/BsGvGbeS4m1GO5tMC6t+HjBGXAPVex+lQ3bcuKNzWH1LQ9aiu2 vfN0x41ZZrcZ2AjAZgfvDPX+lWfE2k2HihQvmRR6nCu6GaFjsu E7FScEr9eVPBqbRbqzuAbHUBssbknyJQOIZO689Af7p6frWHrC XngW+FtfWxu9DnPmRFSQYGPR426rn/6xBHFStRtHY/C/wDr+p6fcTWnie3s54mw9qxLOp9XUjv2PIPrW/wCI/D+s6PY2Eeq3cF7ObsbpY4wqhMHjH5Vw1lrd28Mep6TqMF28OSs qyGC5hXrlh91h67Sc+lek3PiWLxD4Ftp76SFNWgujFPCrYOUUE sB1xhh+OapCZR0TTkvbiW5nUm1tsblx/rH7LWvJayXW5349FA6D2Han6ZCqeH9ItkHz3W+6lPbaSQM568L Wxf2zQxRRQ581xnd3UdOP1pEoxNOvr7RLlXhdmhB+eJjww7//AK64vUtOPiLV9Q1jVtS8l4ZN03mEhY4OdrAdMY4A65/Ovb/BngdvFEF1E7+T5MWVkIJy/O0HPY814j8VPCl/dL9ktX8m7glMcq8/MvfIHXBA4pNaXY4s4yG4g8WeMzeS/wCjeHtGj3KrnhEHIz/tMRk/gO1dl4R1v+0bTUNZvk+zWrOpgV/lxECwQ/jiovD/AIDhms7LwnC0jNcP5964P8I6ux746AdyR2FT/Ey40e7knstNiENlYmK3BRuH8pSF/Abj+QpeYpanJ+KLO51Td5IL3d/cAgc/KM9/YKAK9L8PadHonh210yEZWCPBP95jyT+ZrzJITZ7L281KS342K5 l8vGewIxzTtWcQQr9o1O/kE3CRi6djJ9BnBqkhXO21vUbC2s53nvEilRchSCTn0471i/DLVLrU/HFkJlaGwkLqQxwSu04Yt9QOBVD4VeDYNZ8Tq+pEyQhs+Vj7xwW 2/krfkfWrXxD1u5j12K28O2CwRfaJMSRALkq5U4HYBlIH096fUdj vPiRDLP8AGvQmWEraWemzSAhcIGYsuPT04rh72a6T4zxC1fAO1 Nr52HOcZ/WvWrfwl4n1LR9O1SSVbi5htwhtyV8w564I+8enp071wd1D/ZHxIt7i6U2806+UzSJzHwwb5T35FKS1HF3Oe8TW/wDY/iO6t5pQoaLcoTJUn0IJ6dD361Qs0dImmtVktCefNsZCNv1UHj8 ABWhqGh3cvieezeYyOwYI+dwbB/wxVC+0LVNOlLmGRCp4kQ/rxU3saNJnaeBfil4x8NOkdxeweINMBwYrrhx7LIBkH6givVdJ8 T/DjxvfQeTdXfhvxDKcRsreTK7egkXKSfjz7V803F7I6FbqBZWPS VPkkH4jg/jVfTLudrwQvKGTOQHGCTnt71Sn0IdPsfYPi6XxH4e8O3CXuvxa nA6GLE9kFlw3Gd6MAcZ6la+aVnIi8RXIOW+ypCo92B/qK7zSNd1tvhnqNnfahLeQxSupkuHZ3RfuCNS3OA43HPoMV534Y cX9ytmF/wCP7V7VG/3d+SPyJpt6oIo6342z+TaWGjwniM4wOwjjSIfrGa5Hw5K1hd63 qaSbPsWnXBVgfVDGOfqwrW+Imowan4mtZI5kkj2546gtM7MD/KsBdw8Haq4ba9/c29kMYJO+Qs2AcZ4FPoR1OfuEMupLECXcFYi56HCha9EtVYFEZ tnBAOQRtPHP/wCvtXF2UTT+JoEibeHm8yQ4xk9TXoZjXykBbJOGIx0wT0x7Z60 N6CJtDiiju41ViE80DDxA4PQZ59/517HcskAsbZwrSJGM9cZPPX04/Q15l4Yt/PvreBY9qtIpJ3Z3H1PGM8H/ACK9A1OVX1jau3aBtwBu2YIJz+PPapYyWGMyL5zBgA2cZ/n6dT1q5H5jMMx/LgjLKMp279e9ZdsPMijhP3NwIbPzZGc/z/StiCIzogIzgDPHHSiwzO1hALbywWY5LbQQA2O3T1ry/wAYOFfeu4COTnBByRznB4xxjB7/AFr2O9tg1sF2hcgcdefXn+leO/EWJyLh4WOY13M2QCB90Y6H8KLgeL6hLu1GYKxIduGL5JI74zUE iuYmcPuRiCozyR/Pirl+AZ5Gib5PmO5X+bHbI7c4NCrExEJt/M4+8D82MDoasgzpIyoVTkHrtPf/AD6VNauxnVJCBsPC46e/5UTRsxODhASRg/5JpkSsJVI+8G54x+lLqI0dcYvDCASVOe3U1BpcPmS7cKGA3AnP 0xikudrSsGbO1QFGPWtfwlYSalrVpZqpzcTLGNuOQSM81XmB7X aSRaX4dZTHGZLLREJKqc75ASQSDx94Dpzn6V4ZatJF4emJzme4 UH1O0E/zNe6fExBY+EPE19G7RNdXCW6YbqF+TAHHHyn8z9a8QvVZNJsom 4Lb3IznqcD+VTFFMPDNqZtSgXBJ3cD3r6H8dyoI9C0sscCLzHV VAXgZH5YPbvXknwx00XWv2UUibg8oGAccDnnivR/iXeMPEN1cqVAtbQoobknPcenX/PFJjR4bL/xMPiayDkCVmBPXlv1rm5SdU+Ok6LHuB1UjYfRDjB9OnXtXXeB4 Um8V3N/KN6QoXZu/AycV5t4Vukfxo13O7CKW4Ls4B34LZ4I6H/PrQthn0r8WbuS/8RaPp0ZLSLG2ADkDcxAxj1AFfYOlWq2Wl2lmv3YIUiH/AAFQP6V8VfCuyOt/ErRLYs00a3Ua7mJ5RW3HggbRgdMDFfbwrSGxEgoooqyQooooAK KKKACiiigDmPidCsnhSWcruFrLHOR6gMM/oTXzpp10mjfHAOzjdNJbSyDtvDiJ/wDxx3NfUuu2gvtGvLQjPnQsg+pHFfHfxcuXsfFGl3q7g/2d1JHXLLgt+D7/APvmoluXHY9L+K2jsvhHWFRdzWs6TxD1YYT/ANpsa434gWcer/Dnwxqa/MAzWUjHtuDJn89teyasia/oD3NuoxqdgksfoBKi/wAsymvJ9BgOq/B7xHoqZafTXFxCvcY5Ufmn61DGmcd4OstNuPD9hNPZW80sC4R3 QFlOf/rVt3VxHFuaQj1+grmvD13Mks1pZwvOkzG4jdB+7jVucFugwcjB 544HTOP4wuPFJPkaDpj3MhGWu5Qqoh9I0cjJH95h9AOtQ9SiX4 ha5ZxWax32ojTrdxv+Rd88wHQRpkcZ/jJA9Ca8+0D4iW+latALDSSun26sxR5d0s7YO3e/G1dxBIQDI4JNYmteGdeF3Jc63qFjDM7bpGuL5JJST6qpZ/0rJnsLeMlU1GGdvWFG2/mQD+lUkhNlzxR4i1HxFqct/qEu52b5UXhIx/dUdhWUj5+ta1l4WvbmEy/aLaCM95n25/CrcPhNf49Vt2I6+UrNRZ3JPSP2dHN3rsWn3cGIY4ZJkbb94hSR 9ef5V9LaRaabp0cVtebQ8gDLCoy5A7njp/kCvJvgJohtvD93rcTRTSWSi0gUjB3Hku2fY4FdxFO8sr3EqNI4 dQGOAX5GeQMn37j3q1oCR0kNzCviMmCMQmTTZEkCqAP9bHsHGc kEk5PrW8tvI7ebcyK+5/TAHuAf8jmuG8AzNrGuX+qtgWkbLbQuOQwjBGRntkn64HpXeNAs oCiZwGP3NpJbHfOcUkGxsaI8awpIUjxt9c4z+VXhP5jklSydjt 4PtVGy2wx+VsC4wSOOP85qeS44JV8cdqoB81z5JJKruxlSx6Vj 3mrfZjuZhz71leJtV8gM273zXmPiPxdJI720bcg9T1qbjR2Hib xe0UTrHIpY8DjmvHvHvi+DSbZ7/U5DLNIT5FuGw0h/oPU1T8W+JItG0uS/uP3jltsSbsF2Pb2A6k14Lr+p3urag97fSmSRuB6KOwA7Cob1GX 9T8T3+rajJNqMpKOx2KvCx+wHpVtFLv5kLHOMqynnt/jXJBS7Z7Vr6RetasExuj6Y9KhjTOrmuzqCiQMYrgkLMoHyuQOH +td14QurPxNoB8N6xCs5wRD03IeSVz6ex/Md+C0kpdxecqqrM3AB/Cpbe0vrW7GpaZcGOYPuCk4zg+tJSNLqxmav4M1bQvES22nSs8D yqvlnggE9OfY177c+HLRvh5oGuxIsU7S6qjjPLbplIH4BMV5Fe eLEN15erRTR3pbMLlSVcg56jpXeaT4xj1nQNA0iIlYtOuLwvn+ Nbh0aMj8pB+HvWkZEySsejWFkJrLQJI1XyzpYX8cMD+tXtdi8r XYodw2tAjR5PpnP65qDwtcrJ4ItX6zaVPJayY67Sdyk/gx/KsfxTeRaw9o9pdLbalZZVxvAEiE5yPXnJ/EjtVGZ718JIo4bC7RRhiyE+uMHFeL/Fmyz8Qb42qkt9rwqr/EzK3H55rd8BeMf+ETsG1HUr+G7hdCnkJIpkduowB7+vbNcvN4r s9N0C98Z+JSiy3VzJLBH/ABOclQF/M8+h/Nt3QIyfHmrQeAPCptrACbxFq5EMO377MeN30GcAep+teceHrK8 awMVpZi7g8w4unyVeQcMc9D8wOORgYrC1fxFrGreJx4wvWEdys itaRMgdYEU5Vdp4Ncz4hvbmXU5Lsv8AYopmUPHDhEZyNpKquAA 2M4xgZIrPnjcprQ6691HSr2S7tp51uLm3UA4A8rk4ZR6kcc/X2rDFxBaKGLhiqhFZzyFHQD0FYERube7l2wySbgArggKAOxJ4A qVrQzyLJdokrdhuKoPoOp+pIp3W5Nj2rws9hB8FNX1gzm31e6u ooNMuFYgxO8uPMBHPyiCU8epHeqHhqC98UeLrRdL1FNWgwqSbJ PszzfxSMyfw5cs3HrVLwyl08Hh6zjG60trH7Z5QXI80yShDj2E rV1HwNsk1r4jtqCQxCG1jMg+z/IqOT0wPxprcb0Vj6p8PafpekWscVpAqFUC5Zizfmai1/wAHeGPGcwh1jTYpmjjJWVPlkXoAQwqrm5biGN3PbHSt3whDcw3 Usl0MGRdqj0xzWiV9yNjxzxr8DL+1ButDupb1Y/mjHAmX9fm+oOfavMb+PWtLL22taf8Aa4UPzh1w6fXIyPxr7YrK 8QeHdG16Hy9TsY5jjCydHX6MORSdPsUqnc+CfFP9m3lyr6cCpV dskZxkEd+tZWl2Ew1e1yjKPOTLY4HzCvp34hfs8Wd87XmiyLI4 5Ech2OPo4ryXVPCOq6Bdf2XqFvepKARCJV+RcjDOT0OAfXrisZ Qa3NVNNaEt6/2L4Tbzw95Lv578An/x4GuL+H8yW+o2F44wluLvUHz6RwuVP54rp/iLdFPDEVns2xwo2we7AH9HLD8K5DTra5Oi6vDaKWuH06LTrdfW S5mUKPxAaq6gtjB8JJNI0TTBzJKrXDg88MCV/PIP411mro0dv4d0sbIjPcT3rjOTtRdq4467s9f0qaDSol8c65a W65t7DZZRnsRGoQfpHW3c2bXnxEezVXMel6PFA3HG6U72wPqKb MkjnfC1iZPFJ3E7IbcsAONpbj+ld4kAwBgbjxx+fpWf4Vsi2s6 teKilfOWJc88IoGc/jXS/ZxtBxj04Of8APSlcEafga1xqccrhf3IZgScn2/nWwMz307Fvlc8kDB25P485/wA4qHQI/s+mXdwcIGXyww/WrdjGzhWc7mbtjnoMfp3pNjLllbqyoQNxHAY5zjk/gcf0roLaIhWHI56n09cVW0y3BwjKT7VtQooQttGCOe5zmmnoBm 6pFmMABsDIH19f0ryL4lKot5niIRmG1AOP4vX9Mew+lewantjh PPbntzx/jXlPxDjS4iijI2s0mSQPx7dD0oA8SbTcFQQCyn+IYI5pDYqB8q HcPmY7eT+uK7Z9OHmJujIf+90zUM+mNtAAOGAzg8fQ1VybHFfY 5NjAIuxfmYY5HTGO/pxUUlgqnzEwQGPIGCR1PFdjNphVd4SP5Bg4H5fzqu1o7Z3Bsnk jvkf/AKqLoLHKPZSNl3YMT0wADx9Pw4r0P4JaR5/jeyujGfKtt9ywI6hVOP1IrnxprSEh03Ec5I5r134F6OY4dSvmU Euq2yEnk5OW/pQFir8b43svA2i6VJFG819cGeRlB4Y8kj/vo4rx7VbcT61FbAZ8qJR9Pb+devfHacXvjqxskUCOygzx3/zmvPNMs2m1Ge7dcBmOT146ChMGdx8G9N/4nazNgrbqWIIHHvms34iXRaw1W63HM85jDDoAD0GfpXX+AIRp/hzVL/btZl2Lx7dPzNee/EB/MgtbZCAzje+G4z2qWM4pZpNH8C6xqJQGaZDDE3oWOM/gKo/s9+DrjxH45tZ1mMYtGa5aQnYMxjdwQDnkA44yO460/wCKU4s9B07REmWNbuQyTOd3QdPwzjt2r2X9nHQh4c+B2veLpxc JNeWc8UQY7dsecAqdoI3HuCQcD0oXYDW/ZbsX1P4ky6rNGAbeKWc4zhWb5MDPP8R619VV4b+yPpRi8PanrU h3PcyLECc5G3LNn67h+Ve5VutiGFFFFMQUUUUAFFFFABRRRQAG vkj9pjRza3aXCJgW11LAcfwoxEkf57pPyr63rxP9pDQvttheFE y09ss6e8kJwf8AyG7n8KiexUR/wQvhrfws0lGfEkKTWMjem0kp+UcjflXJ+Fx/Y3xj1XQ7hBFBqeQI88fON6j8AP8Ax6qn7K+rqtjrGjSPgxGO9j HoFOyU/wDfDj8qt/HtJNG8c6N4kt1Id0XeR3ZG6f8AjqD8am/UpHEeOvE3h34feLNU8Hp4YnNtZ3AImhl5kLIrE4bBH3sAZxgDF YB+JfgOckXFtrUKkHcpjBGPwY1t/tZ2cU/jTTvEFsAYdX02KbcOjMuVP6BK+fNeSeCIPEF2k4Zj/DWbH0O61r/hVeqXTy2L36SSdYyJIkXA/wBiJz71yd8nhqPixtxIinBZbuU4P/Ao0rkLxpg7hZGKA8E8ZpNO1CWzkydjDvvUN/MVd2I9LtPEGlWNmI5rRm2d/t8GT+hakTxho7tiK2tUz/z2vnfH/jorgdY1u4v7RLeZrfywdwVECYOPasK3hha4QPGzgsOAeT7ChLu Fj6v+DeqSDVns3EAsdRhZXEIbbkAlTz7jH410fn3viOS80jQS6 fZoC97c5/1Q5wg/2mxx7AnqK8aOsP4a8r+yory2s/KVYUbiSPgMcn+9zzjp2619Jfs7WenL8LLK5tkBfUWmmuWLZZm8 xlwT7BQPwpeg7WR1PgjSrWy8L2tpZQxKkcYCuw5BI5P8627+6j t7dUgYbj0xWBplxe6dvsLqN0VHOH2gB1JyCD0qrr94/wBkdodiPg4PUgfWqJNyG8Z4i28KcdT1yaoy6zGkzq0ydcAk8E4 rjr3xFFb2ju0p8wqAABXC6n4gnuJyqysyN3PFDYza+IPiOS4na C2lLKCBkH86841nV7TSofPu5DJK/wDq4VPzP+PYe5/WoPGXiW30eMKSJL2VcxxN6H+Jvb+deYXF7PeXLz3DtLLIcksev +AqGUkHi7XL3V7ovcEZPyogPyxoOw/xrnZ0JfYGznrVq9kV5xH/ABg5Bx1zS+UAMD8Se9TrYLFdYgBgdP51LBbndkNin7DkY6npVu CPau0fjSu7AkTWMsts+6NiB39DXU6ZqcV1tiYCOTHQ9PwrmAFR CTwK0tOsGd0mmbbjDKoP86loZ08lraTQfZ5YVmQ9iMk+9FnCLH VLVYgqRmPaATgEryB9cbse9Jafu06ksexpb20kvoWijfY64ZHx 0btQnsD1PStK1ddK1Rrycj+ztQjEV4ozmM9nA74PX2JrI8YJJa TiaECYEDa4bh17EVh+ErDxTrNndW0Fgs0kG0EG5VSQc84PUe9b +n+DPHskH2QWkVvCvK/aJo2VT/s4JIrW5KdjA0xZtQ1OGHz/ACI1VpbqTGfJiXlmP4fmSB3rE8Y6lN4h1kTT/urC2AS1tyciGMDAH14yT6k12njiwTwl4dGgQLc6hq14gu9Skgj JJjU/KmeiICM5PpnHavJNOmv9StLq6j0+RIlmEbHJKqT0BY/rUy2KViXUr+B5Chl2FQDGoGS34e/auZuSdU1WKHOYIcvIQeCfQfoPzNWteaK1SZEuVnupJMEouCi9/pngfSl8P2xgt3knXa8nIU9cAcULTVhvoW9VuorSwe5jjBfAKkn IyeAQPwP5VgWUtzdTee5kKr8zM3T0xWnPAt8S8hVbK1OCScB29 Pw6fiat6Gk+v61FpVlAqRSyJGmP4QOp/maFsB7ZBaJo+i6YJZEh/wCJHbl5CSAvzlDyPTzAc9sZrjfhJ8TLnwPqc8ZtomtJ5B9oTGW JHGQ1eofFALY6rpkKxK629kFntyo2shOGBHfofyrxbxj4ch0m5 ivYLeSaC7diEhyqxnP3cHJ6Edz1qnuTp1PuLwf4it9S0u01exI lt50Ei4OQw9PrWP8AFn4kyaXBb22jxtHL5ySNIU6bWBx+mDXNf s/TaQngS3s9MunZoyWlhlI3oT149K9Gu9BsdU00meFWBzncuRWno Stzd8AeMNN8XaStzausdyijz7cn5oz/AFHvXS18933h3VPDerDV/D0ptp4jnYnKuO4+nsa9T+Hnjqx8TwC2nUWeqxj97bMfvf7Seop xlfRia7HY1na/o9hrWnyWl/bxyowO0svKn1BrRqj4gvE0/Rby9c4EMLNn3xxVPYlHw/8AFoyDUI7AsC7SZkx3Odx/8eLVf+EdvFL4hs5HjDxC+lu3B6FLWDEZ/CScfiKxPFd1/aHii7uSNwt4y30Ykk/rXWfCy2+y6PqN2wwbXTYLZD6vcM1xIPqFMI/Cue1tToexW8AaY13q2qXE3W61SRsn+6G5/m1XfBUAvJ/EfiAnel9qUrxn/Yj+Uc9+h6VtWaDSPCmoaio2PDayyKQP42yB+pqXTdMTRPA1rp8 aqrCEK23oXblj+JJpsgqeGbLy9O8zB3SO0h/E5rTERLZHGeasW8Iit4owOFUCrEEIlnWPHDHBpagXDEYdNtYcf NIdzD3/AM4rSsYPu4G0KeBnv2pkgWa9AVm/dDCjp6VrWMQ3D5SCT+VFragXbOJVTqdo4zir4IRQDgYFQR9MZ4 61HNOFUAnPpTYilq0mUYAnJHIxXnXiRDcX4JJO3jJ/z9K7jUpdw681yFyheVnxwTRcZzzWoII2BfT0qrLZAEhc46c+ld E9uoHt3qF4Mjpmi4HNvZKMkoCT3NQy2IHAU8dAexro3g6DHSoZ IBgZAOKQHN/YgJFGP06V7b8M7BdM8MWhcfMytM/48D8hxXm1lZG6u4bcL/rXAGPevVNdmi03w7P5fybYti+2BgU7geKeKJZNR8VaheFid0hR ec8CorOyEYGwAH1qzaQiWaRiM85P1Na2lWRuNSt4FH33AP0pCN 2/j+x+EbSy/jnO9ifTrXmWuo174hcBfMWM7cA+g/xr0vxtPtkfBDJBEV257153pcMkkzyqjNIx4UdX74FPUZw+o+Gb zxp47e3tYp/s1h5VuHiWM5ZuTncwx1PQHgdOQK+kvitJbeH/AIRpoFqhCeTFbqAeirt/+tXm3wS8H/bvFh8Rap4fjVJZfOSaW4IVCvOVjBOcnnk4GOCeAO7+J8Fx4l1z TNBt9zefdRoT/dBYEn8qatcD1r4G6T/Y/wAMNHhZdss8X2iT3LnI/wDHdtdtUdrBHbW0VvCoWOJAiAdgBgCpK3MgooooAKKKKACiiig AooooAK5L4o2UU+hR3Uq5jt5cTY6+U42Sfo1dbVXV7NL/AEu5snAxNGyc+4pPYadmfH/w4uZPC3xhgjvsLE8htLpexVswvn6Nz+Fes/HPTH1LwLFMcm5sLkoz+hb5S3/faL+deSfFe0ay8R2+oNmLzCFmPdSwMbk+4aMv/wADFe26fdp4r8IRec2G1iw2v/s3KDY35SRqf+BVknpYvY8k8WQL4t+AFtfqub3w1cbWHUiCTAx+ GYz/AMBNeAX6qVKlQwPYjivo74Mywf8ACTaz4S1JdtnrFs8ToexIbO Pfl/8AvmvB/E+lz6Nrd7pF4oWe0meGT/eUkE/pUT11KR59qunOhJtl3L3Unkfj3rGKsflYEEdjXdSxqAQ3UVkXd jDcTCRgQRxx3ppuwcpybrlwACefSvRvh1o+naR4k06PWQv2u4/eMrYxaxYzk9t5HA9MjvXVfDfwHaoItc1a2BVkM1vE3UqOjn0ye n0J9KZ8OrQ3fxbFzeiNYwlxPIZMKAEZV4zxxgY96alcEjF8WXU z3DwyLHslfzkkC4LA5x/P9K98/ZYbUrXwMUm3CCe+kmhD8BYsKC2ewLK35V4dqum6j4k119O0uJS oZ5PtEpwsEBY/M5/hAHbqScDkiun1Dx3e3Wj2Wg2E23w7psaQTSR2xV9UZABgqD8sf HTPPfPSkkVPax9F+Nfjj4P8LWDyiVdRZG8v/Rl3ru9N3Sua0X49XGvWv2228P8AkWTyGNHaRPMbABzsIx3/AL1fIeu33iDVPE/mWls2m2UjrFHEcKhXPAK9+tensTG3l7FjaLCBUXaAAMdO1XuZX PYPF/irSNW0yWS70+W4BGWljtRBcQf7QwSsoHcErxXkmteJtM0/TvtFvcx3dy4/dRL0J9W9APzP60RzTs4jWRzkHI68Y5/SvOdRiH2hkyTg8Y71EnZlR1MHX7y7udTN7NK0k0pJZj3P+FOs7 9Syp8ysx5J7+1SanbsV2gBpSNw56H0qhAgaEjHPf2qQejL98ir 5chPltk9+3amoxcBwSARTNSw9tbzg5G0gj3punfN97OR0OeKPM bepdiUgZODn9KsxADqOT71FEDIcRhnP+yM1u2WmW7xIGiy2ACS x5OBnvSYzHuWXYFzkngAdSa2dBgvgSJS23A2huo9/ar0emQQHciIrY6gc/nWrbxiOIcc4yaTdwFgU5Zj9BV2yGA0nqcCqa/KqqO4zWgF8qADpgfqancZ0nwwtrq78ZxS27tHDaoXnKnqCCqqf qef+A17dH0rzb4HW2NEvNQYf8fV0Qp/2UGB+u6vSo66IbGctzE8QaTAl2dbWedWzsuImkzEyeWRkL2I2g ++TXk3inSTd+HdSTTSsbxW4vTbxR7Sdqq3CgfMGAY7hx1GcjFe 36zZf2ho89srYJBZhnkrtOSPpmvLfCcE8j3tnaSq9ztuI7CJn/wBY3ktvVR7nyzgcnGO+KTeo1sfNmmafOL+7vGbe0TkIe5OeTg+ grYitpZdPlnug8UZUoGH3sd2Pue1ZHj3RtY0fxTf6DJGWkM5fa nOe/wCHfg85610/wp0G+13WrDw/eRSBBLvdO5iHJH54H1IqHG9h3Oy8E/DHT7vww2oa1JMqGDdZWw48sMMq7+rN1C9gQe4B0/gT4e0XTviDNHbTxXLRQtxuJMcigkg59cY/Our8Z+JdP0vV/Eeg2sM98mktC1sbZDunuwpWfG0/MiHZwcjjFUv2dfh6dRt5vF1teQ2Ny0roFa2YFyOuSW75wce9aW YmzK8Qas+u/G3VLKMlrbSrAW8h7FyQxz+JI/CuS1hbq9sYkkmiZIZn+zhmG2QqzKUY/wAJweCcdBXdw6TaaN4q8WXojmS5urkyTCXqCAxwPbOa838CW97 qumeIYo41kRLg3fzg5UhiDtI7kA8e1RuyktDovDHi260kRSQKl tcwPt+VBFjB5Vh69sGvqD4Z/EPS/EOmR8pHcRri5hBzgf3x6j+VfIr2kWqWUrRlZpUUJKG4DjouSe3 YN2JCtj5TWB4fTXfDGuR6z4V1GaC4t3w1vKSCCOqMD/I1akZuNj7e+I9rqVjZnUdNJmtWXJC87ff3FeHX2vXMd6t7F5lv OjgrJGSNp7fQ16j8Ffi7o/ivTvsd4iWOoxjF3YSn5c/3kJ7Guy1r4ceH9X33lpCgEw+YLTab1QJ2ML4Y/GO01ARaX4ndbe64VLvGEk/3vQ+/Stn4/a6th4I+zQyAvfMFXac5XivJfHHgRPDIfzILqe3c/uzGv+rP1/OuMbUb1rKys9QvZp4LQSTgSMT5aA4AAPQZBOPejmdrDSVzj72D z9Z1C3VyrT3CWu4HpuIBb9GNepeFYCvw+huDGY5NZvZb3Z/djZtkY+nlxp+deR2n2m+vI47XP2y7kZYv+usziFT+G92/4DX0HfW0EN3ZaZaj/R7OJYox6KihV/lWaLluUdctBPpun6OBkXt2ryc4/dRfOfzOBVrWh5lzbW45G7e30FXDFv1uRzylrAIE4GNzYZ//AGWqYPnajPMeQmI1/rQSPYcEkVc0lMSNN0CLwfeq23kfX1rSgQRWQUjJkOTRqgJrSNs lzgljWxb8L05rOsgMcAAirvmKq0AW2l2jOefrVGeUlt3ANI8uO ap3EuR1I9qGBW1KTKHnk9+9ZDIM1eum3MBnNVyKLsCpInHSo2Q enJ/SrbAZ9qiYdqdwKbR9e2ageLNaDr+ZqBkB7UW1Av8Ag20DaoLkr 8kK8fU9KsfEe92WC2wbg/eq/wCHYxb6dvIIZzuORjjtXHeLrg32sLbg5y3P0odwKFjD5dsGYct ya6HwhEguJ75xxAhwfc1ky4VQB2rorOM2ugpEABJcHLE9hSA5f xbcmSLCN/r3yTnqKd4WsYthnntJJIkwqspIw5zznPGMdcH9apaq4utYbccp FwO31r0DRrNbPQLVCjLLNmV8nggnjj196YGv4dgis7KRkCqqpt GfTvUfwwsTrHxEk1OVcx2SM4/3jkD+ZP4Umqzi10LbjBxiuy+DGl/Y/DL38i4lvpC+f9lcgfrn86qCuJ7Hc0UUVsZhRRRQAUUUUAFFFFA BRRRQAUUUUAfOn7RPh/dPfIqYVz58Zx0EuFP/AJFSP8CaxPgdrUl94avdM83bcWkiXsGT03ERyfgJFikPsTXs/wAatIjvdDivXGFiLQzMB92OQY3fgcEe9fMfgjUP+EW+Jax34Ed q8rR3SZ4Ecn7uYf8AATg/8ArLZmi1R0XjgHw/8QI9etEZFEq3kYHXy5MMy/UHev51z/7TmmwL4wsvEVptNvrdkk4ZehkUBWx+Gw/8Cr0X4q6VJLpsNxLzLaStbXB7kMThv++1Yj2kWuW1LTpfGHwZk skXfq3hmYvCo6tA33gPwHH/AFzHrUNDR4HLFubc2c/z/Ctjw54YvLrUYpL/AE9ktfMZYYZcg3Tr1BxyI1/iPf7o65HReDdDtxN9vugs0keWhg6liOrEdwOuByTgV21rfSXqm 7nUqUBQL/c7lfr2PqQfpStbUYNEYLLy5ZfNlf8A1khAG449B0GBgAcAYA6V 55oVvd6h4o1FdNMauIXtRK7FY4o3kZ5HZjwAFK8+4HWul8W6pc Rxx2Nmnm6leHybWBOTk9/w9axvBs1rD4307wJYSx3MNslxe6xODuFzPFC8iRjPVEcLx3I56 U0mx7alH4rXkXhS4t9CtmtLvSJf3t0tjdfNfHHWR16L2CqeB9a wLn4j6Abfba6JHb7VwsBtUKr6fMCD+lcX41nv38V3Nzc3c1zcT Pu82RyzEHsSa0ZFiXw9NF/o6ag4ASWRPlx3x7+9NaEXIl8TalqupxQLFCkbyDEUcYUV6Rdp5 VyjEtmWIMQf4WHBrxnwtaahD4jt7jYZhE+XKuG4r6E8O6Yup6l Z3E0YENtAJJSxyGOSR+fWqsidyO9txovhma8nAW5uU2qCPug9v y5ryxyrTs4xv7mu1+JGuLqF88ELf6PEcJ75PJrh33FlEeASeSR wP8axk22aJWRDdQZlSbIAHUH09aoXNkcG4tWyDyVNdHpmj6jqR aC0srm7J5ZYYWkY+5wKj1DQLy0nigurW5tm3ZMc8bRsR9GHNJM ZgWWny3dk0jkpsbcgI4NMt1VWaPI+o710F+1xp+xVRXjPfpimv bwXsKTPE1uxztYL29/rRfULDfD7oAIGwNjbjx94f/WrqLVVZjJ2A4rlrOwuob6KTCSRg8up4x9K6a0kZo1ReuSP1pNX BFhU8x+fujr7+1TNzwfqaUARrgdB+pppO3A5yeTTb7jJbNDJNv boOT/Sl1SZkiCIQGZgo+p4FWLRCIAT1bk1namDJd2sa9WuBj8Nv+Bot oB9D+EdOt9J0CzsLbBjiiHzf3ieSfxJNbsZyKx/DayDRLIS53+SmfyrYjXA5rpWiMiHXpXt/DWqXER2vHbEg9xkgZ/X9a8Ac2d5pmoafqdpFcRRW095byEsHgmSFmVhggEEqoKsCDgcZ ANe+eJEE3hjVYSdoazkO7/c+f8AXbj8a+e1lhS4niuZmt4Lm2ntWnVN3leZC8YYgckAsM45x ms5blLY5340nULfx9dzSw3E8qWdrEZolzvKxKGYntuPJNdH8Mv 7U8L+F9Y8WXzI2rTsLbTxjG1wCUA9cuFB/CraTR63a/8ACM+MbW1sfEdrZp9g1Hzh5GpwIdgIPQuFHBB+baQRuHOx4jht bG20DT5EaSOytp9VkUj7xWN2iJH1QEj3o2YzJsvC+mXXiXQLHS 7l7u+ucwee7ugHlyOZn6YbeAxzk8tX0YzHSQltGoSNR8u0cYr4/wDCl9qmkfEe0Sd7i3FnMsXm7toXA2k/nmvtaKwgurOOG7Pm45D561UdiG9Ty/4g6fHqNw+o2qE3Lx7LhUGd6gcN9QP0rx7wvBHb6T4j0+OR7dlK vtD/AOtbzMcj06kV9m6d4Xsox+7hVQR1xXi3xq+F0ieb448L22AwMe r2MS/cZThnUemRnH49DUzi90XB9D5+0y01CGzk1PSrgi5sZmDxEBsoR jJU8FSDgg8Eda1olsfE0H2rTRFZatAv76BycFB2J6tH6NyydDl eapzpcWF79ttSwP3vk/mPX6VHqNoLsLrmiObW8g/eSRxHaVI/jT29R2qIysatXM/UIr6G5F9YGbT9Ws3xg/K6nrsb1BGMHoQQa95/Zw+Oxu3/ALC8Rt5V2g/i7464rymwmh8ZW+yPy7PxLbxbdnSK8jHOAO2OTgfd6j5cqOK1H S1nvfOBms7uFsEqdrxsOxq07GEo23P0R13U9G1Hwld6izxzQRw lxz1PYficCvi7xjqJW3uvJJaS7k8mIY5MaYz+Z2j86m8F+JPES eHb7Tr+6ae2hRQs4Zh5jtnCkdDgc59QK5nVrseZcXpOIbNPLiH qwzk/99En8BSmyqcTqfglapqHj/zF+e30iI3Dk9C6qYov/HpJW/4CK9osAsmoTXL8pH1J9AMmvM/2cdNbT/h5da7Ou2bWLppQT1MMeVT/AMeLn8a9S0+Py9PG4HdJyf5mk+wPVjZX+z2skrk7zl3JP8R5/wDrfhVKzQx26hvvn5m+pqXVW8x4rfruO5voKQ+lIRLAnmTKvbv Wix3SlcHC8Diqlmm2JpO54FW4BnrRuBat/lHXPvT2k+lQ7uKjdzTAdNJxVaR+9KzE1XmbjHWgZFIck0wmlPr TDQnYQjEVGOac3NNJwKe4DWHP0ogiMs6xj+I80mcir2kphmlP0 FIC9qFwttZtggALgVwlgftN9cXjcgHav9a2fGN8UtxBGcu52qK zooxa2iQjqBz7mncCS0hN3qEcIGQTlvpWzr90sMEjDjy1wuB3q v4ch2wy3jDlvlTNZXiy4LTJaKeR8zfWpAj8H6eupatFBINwdtz 57qOTXot64lviARtXCrgcYAxWJ4D0/wCwaTNqUoIklQJFkdvX/PpWjC+0NKTnHNUn0Aj1hZdR1C00u35aR1QD3Jr3DTbSKwsILKA YjgjCL9AK8w+FWmm/8Rz6tMuY7UYQn++2R/LP6V6vWsERIKKKKskKKKKACiiigAooooAKKKKACiiigCprFjHq Wl3NjN9yeMoTjpnofwPNfG3xi0mXTtRh1J4yHidobhfdcKw/EFT7lmr7Urwv9obw2sslxIkeY9Qi3rgf8tkHI/4EpIHqzD0qJ7FRfQzfC97H4q8FWzXEod7q3Njcue08YUK/1ZBDJ/2zNcl8PdRl0Hx2sNz+6jvQbSdT0WTOBn6Nx/wI1hfAnWpINTu/DE5UtdgfZwxwDPHkoM9g6l0P1FbXxIssXY1ODeReL5oI+VvNUD d9GZSrfVj6VDLRwfiaG+0Tx5qcDRrtttRaSaPtJBMwKHHTAyv0 NbmrXlnpOjSXPyxwIu7C9/YfX+tavxKSLWvDGj+P4lDtEv8AZ2shOMo3Ab25OR/10X0rj9O069u7hZ7+S3utO0wAwKjb0upwPk3f7I4Yr24Bz1qNy tzlPFWuzeFNNkv5z/xVOrw/uk76dbN0+jsPyH1rzv4W6/JoXxM0bWJvM8qG7UTbQSWjb5XGO+VJ4rpNR8B+NPEOs3OoXxiN 3cyF2aWXLMfYLnt2rd0fwRqfhLTLu4TT7y+1u7tpLeORovs9ra BuC3myAbnx02kY9eorSNkS9Ti/FMMNv4s1Etd29wYZmSI5wuAcZx/SqEem3eqTGQ3ayAdRGMhfx6Ci58L3dlc7dR1DTI3J5VLoTN/5D3D9a7uyudF03TooUvra2UL0SJ3dj65YAD8jS0Ecvb6WkOnuN PV2uXBVp5FIRAepHr+Fem6pqS6N8NtL03TJyt26AahP2x/CqnvleT6Vy1nd6TeyTShWnit1Mk8kzk4UdflHA9K3tSkjOlaDd vNBBa3sEsnzxEqM8BSM/wB3aMjp+FKRUI66nPajp95DqXmW0MlzBME2MnzliR0GOvOa958 GfBzwzoHhhfEvxIvPJcje1uJAqxj+5x95vXnA/WuH/Z88NwPr914nv5z/AGTpZzEAx2tKRnAz/dyPxIPY1P8AFvx1p/i/UreA3UcT2Vw37m4SRoSmBs2hQR/eznnOKSQ5PU9OPxF8OadptzDoGmQ2VjC0cUEcRVWmZhk7mIOMA cnB/wAfOvEPj631hmWfwhaSKcgyPMJJMezbRj8q5aS101/JeF4xcXBxIsEcqgjBOS0jEn6DAqFrZIvliTb9DVWuZ3M7XbDaR sRgpw6o5/hIyAfzqnCrRwhGILd8cVv68MPCjfeEEYP/AHyKy0j8yQDHC9frWL3NExqWyFd0iAsenFTWMSruYDA6CnurNw o49anhUFQo/hHP+NK6GI3MijqOv+f896bEDLMceu0USPsiklxz0Wp9LiKkZ6q Mn6mjrYOhdYhIyegUVX8NWy3/AIttIpTlUeOMg+rnB/m1S3jAIFwSGPIHoOT/AC/WovBl0lhrVve36OifbUkckcbR0/U5prfUR9GwgBQBxip0OSKhh+7kd6kZ0iQySMFVBkkngDvXQZlT xJeRQaa9q1o19NdKUjtVODJjk5ORhQByTxjOa4v4g3kmmeFbqx 137EsJAjlPkrshZjwkQAzu4PPpnpVD4j+MINO8PI8rtHNr8nzs Pv22lxuM49GncbfoD2rnbeLWPF3j9r/xNZxXHh5Sfs8UF06qmQB1VlYkkZOQQe3GKlu7K2On8B+Dpbu1g 1DUbtv7HyfslkjH96A2CXP93cvTv/Pn/EOtx6n4tutRs3jeNzcWMJ6qSsToPw38/jXQfGvxHB4O+GkcWhFrdJZRZwEOWMYYM7cnn1H415Vp2l3+leB tNkUE3jXJu9nQrkFsfkKl6IFqVfiXq9hrutvcWi3sTNtl2+V8q kgHlsgd6+kfhB45tdZ8O2NldSg6lBEElAcENjgEYNfLniu1815 bcgj5RJHx1jb7v5cr/wAB96w/hJ4ovfCnj23RpikEsoVh0wexqoslo/TjTJw1lESOdozUTf6Lqpm4NreYSZT0WTorfRhhT7hfeub8C6ob zSYpWk3+aocH3NdJJ5c8Lwyco6lSM44qxHi/xw+EiMJdd8OW6qGO6a3XgZ9R6H/P1+adXtZ9KleV4pogCQ21SCrDrx6+or9BtMmM8D2l1iSaIbZMj iRT0bHv39wa8n+L3w1tbmCe9tLZGjkHzcfdPYH29D1H84lDqjW FToz43YSRSQ3lpO0ciMJIZozgqQcgg11epqfGgtHubBrHWz+7N zbOEFwfl6rxgHcM9gTkYyRVTWtGnsr6ayMEmUkK7CPmBrrPBVp FAJdRkCmK1j8sMTwcZ3N+e/HukfrWSRc7WMbxOsmi6NbaZEQt1kM+1s4dsYAPfAx/30a43xVFPLb6d4b08bru9lSJVHdmO0ZrsFX+3PFsktyD9mtd0t wR2A5b/wCJ/KrPwe0Nta+JD+JLiM/Z9LhMsYPQSSZWMfggLfitVe7uF+VHsOn6ZBpmmadoNmP9HtIUt 091QYJ/E/zramO3C/wgYqpYgPcyTnovyKf5/wCfamanKUh2ofnkO1aDIrRv508tx2J2p9B/9eplBZwo71EgCIEXooxVq1G0eYe/SlcC0vACDoKnU8VWj45qUHtRcB5Y4xUbGlJpjmi4xrtxVd2yc5 4p0rgVDnn2oAU01utBNNBzzT6gIfemMc05jUbGle4gUFmCjqa1 SVt7brjAqpp0eXMjdB0qj4q1AwWvlx8yOdqj3p3GYzyG/wBYec8xQcL7tUj7p7hYU6ucU2FBaWaxdWxlz6k1peHLfLvduPZ c0hGnM0dnZ46JEvOa463WbUdWVVXLzvtH09fwFa/iy8yFtIyMnlz/ACq54FtEiim1OVQTjy4s+ncj+X501YDp70xwxRWcBykShR71Tu 32QCNeppVJJMjVseA9LOs+Jo2kXNta/vZPQkdB+f8AWqirgekeBtIGj+Hbe3ZcTOPNm/3j2/AYH4VuUUVuZBRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXP/EHRf7c8NT28YP2mLE1uR1DryMe9dBRSaugR8FeOreXQPF0eq6e fIR3EsTLx5bBv/ZWUj6KPWvW7+VfFnhMXmnxqJLyP7bbxjolwhxNF+LFuv/PVfSnftFeDoo7262pthnDXVuQOhwPNX8MK/wBEPrXn3wW12a3mn8Ny5EzSebaKT0uEBBQf9dEyv+8FNY26Ghu +D7+wgmn0XVV/4kWtx/ZbgHjypDwr/wCzydp9yp6LXNfGC+1T4Zavb+H/AAq0UWkx2KTE3MQkeSQswdycZJyMe2OgFavji1E/iGUj5rTUVF1asBgElcSIfryfX5s9ayPHcj+J/CVpdXbNLq+gH7PdlvvTW7H5JT64Iwf9rdnqKRR5ZefFrxkWJi1 q2gPIzDZID+ZFc3cfEHX5Lkyz6zPMzdQ0KAH8hWd4s0/7Fd+UGA25I+X76kkg5/HH4VzwKIpLZJPSqikybnregWUviCzkvbvxJ9nRF3SeTbhfL4zg sMVlyXHhS1kaGzs5tYu88TXDny8+u0YB/GuS8MeJNT0Z3hsJgkUpBdWG4N2wQe3Ne+eGdF8K6voC6jNpcAu jHueIDAc9MD8aT03GcX4ms30/4bxbo0E2qS+ZIscYQLEillUAdiea2PEOn22i+CPD0wieS7urZi YGJPykbVIHbOcj1NanxQWNdIghECufLkhRccR5jbB6dqm0hSUt te1B/wDQdDsYVQyEkNcBPlAz/ChLvgd1HrSvcuOh0el63pvg/wAP2Ph7ULaK4h06xafUIRIVM1w5wVyCCSGYqOf4HNed6n43zfP c2fgzw5CpbIT7MGI+pPU/lXGanrV5qGoPqModY7yTeoJzhUJVFP0GT9WPrXY+C4dOmu1nvo mkjV1BVeu3+LGe9F3pYjfU6FfEdp4itLacaOulXULMJIlQbWOB hlbg4xnII9OapzDzJkiDEbjyfQdzWX4o1Atrq39vsXT0maCJUT ZtUdMjJ5Prk07VNR+w6RPqKrvYMqquOSCwDY/MD8aq7sTa7JdQc3E7zccngelWNF0+81K+g03TbaS7vLhtscUYy WP+e/asm3v4LkGOEmSTjMRX589hj617rplhafDnw9b6bPdRW3irWoGN zcMAxtU2F1hXJAycDPIySO3TJK+ho9DPsfAvhTw1Zvd+MNasJr mJQ00RuNltb56Alfmlbg8KOcHg4zXL+JNW8IpONN0XRpjCpUJe fZ1ijZWxl1zl2/EjNcxqFhLrfiWyt7hb24nUs8dxc7BufOcERlgeOnQdfWrTQXls xjAdiDj5q05URcg1e2a3vTauADG5DDHTHWprNdsRY9WOau+KVM ur3Un8W75vr3pljbS3t7bWFmoeadwkeTgD3J7ADkntWSWpZp+G PDN54ivituyQQQD9/dyg7IQfbuxxwO+Owya1/Fml+HfCNhCNUuRcNMUaNJpGWa6+bjbGh+VfUnt3NT6/4gvtF0m00/wrGsWn2ys6agwQ+bP137G+8SRyCOBtXtmuQ8Nm/hkmutcFtq813J58s08bSMWPOQXHHXtxWijYls95025t77T7e+t W3QzoHT/D8DxXM/EvVfKtLfQ7aQJcag4R2z9yPIBJ+p4+m70rM1XxW+k+DdPOlQ28 dzcvIsSMh2Iqt8xCjGeSPTrXKaHeTXXjXT7rW5zPLLIHmLAD5A MAADgDnp7/AI1Tl0BIb8VfE2k+HtTmgieD+2LcQhY7lAfK/dFfL5GBsQov1Bb+I123wz0TSJfh9Yiw1lLy/ZTI4dQrDPPlnHoc4NfO+vzPruv6rrepRiaa51Cab5if7xUfotd n8LvGElvrEVtLOqgcqg4wBSjroTI67x5p1lr1vY6Ze+Y6w6jFP tUfLuUkEN7EEiuS+Jeuf2dr+h2S5KtdK84HXYRgj/vnNfQl5oOn634dmns1UTToJY2HaQHI/UfrXzT8QtMa58a6dezr+4Dxq+44I+dBge/WlK9yol3xXYx3Hhm2162jeRtPZ4rmMLhtowJOPp5coz3LDsa88 1/R7e9tlvbMp5wAeN16MOxr2LTr8QfEXU9BvoFt7bV9qxbmyq3AG Ysk8Ybc6E/9NM9q8v1m3Xwl4jl0S8V49LumMthK4x5WeqH2B/Lg96ErjkrH0d+yl8QotZ0KLTLuYLdwfIVJ5yOo/rX0YpDAMDX5waRqV14H8Vxa3aM62srAXATtzw39a+4vhV45svF egxTRTKZ1QFwD1z/EPatIu+pnsdzP5ySLc2oBmi5AJwJFPVD9f0IFbUEkN7aB1G6OQ EFWH4EEfpWB9ozUTar/AGVKLp1ZrR2AudvPljp5mPQcZ9ue1UuwHj3x/wDh3Lp1+fEuj3z2VvOnlXBVNxQ9se+MgfQCvNfGpi8L+HLbSlj 8u5EayTJnJQtjZH9cBc+uzNfVPxS1OwsfBNxeXRjkhO1kyRhsH cCD+HX3r471CK68U+L4reR/mkkMszH+DjPP+6vbsSayqabGsHfcfomjXEnh+x0a3JGpeJLkR5 7pApyzfoT/AMBr1fRNEg8M6TJaQKnnTzNJJt6E8Kig+ioFX8M1mfDWzju9dv 8AxTsK21pH/Z+mKegA+8w/DH45rppG869yeVj5/Gp8gbuPiQQwrEDnA5Pv3rNlkE920nVI/kX696s6pcGKAIh/eynan9T+AqlEAiKi8gcCkySxEPMcL271bXngDAHSooU2pjuetW UWjcByg0+gDFITSACaikbilc1WnfAODTQyOR8t1ppbApnI/GkyeaAHZ7UE0wnFNYmmA5m5pqguwUdSaaxwKuWEYRDM/wCFAE0jJa22CRwMk1yJlN/qT3j5MURKxjtn1q54nv3ldbCA/PJ94jsKz5Gjt4FhTgKMUhE2Gu7hYUPU8+wrpiY7CwLHAVF4Hqa zvDlmY4jPIPnft6Vn+J75pJhaq3yJ97B70wM5mkv7/nJaQksR2Hc/hXcWKqlpHFFkQgDYDxx2rD8M6WWiNxMGXeB7ECui4RcAYA6UeQ Dbl9q7F6ntXr/w+0b+yNAj81NtzcfvJc9R6D8B+pNef/DvRTrGvi5mXNpa4dwejN/CPz/lXsdawXUmTCiiitCAooooAKKKKACiiigAooooAKKKKACiiigAo oooA5b4m6Ade8NSLCim8tT51uSM5YdV9wRxjvXxP42sZfD/AInS9tGkhQlZInB+ZcHjn1UjH1X3r9Aa+bf2kvBCxtJd28P7iY tNFtH3W43p+OAR9MdzWc11Li+hjabLYeMdFiZ2SB7ndPC46W10 P9av+6SRJjurMO1cHeXEtheQ6vawLM8YeK4gLZWZOkkJPuBkH1 UEc1l+ANYl0fU5NKuJvKjlZXikbojj/VyfTkqfYkVraiscOtTRujR2l827Zn/j3mBxgHtzwPwrPSxSOB+Jnhy2li87Td09tLH9o0+UjBZCeUPuC CpHqK8ie2Qo4bKuBxX0RPalfO0WfASV/OsnPAjmxyvsrjj2IHoa838UeHFu2e7s18q5XPmxY+8f6GmtAaP NTG0TgnIYEHHevoD4LSX114bN5eZWIuRECoHTqR7dvwryrww+g iCe1vdHuLrU5FKWbrJ8nmNwN69wDyP1r6B0yyj0fQLXTkwBBEq sQOpAy365om9ASOW+JJkvPsWnQAtPdXAjVV6ncCv8iPzrY+MOn Xth4StdHtbO7Wwiy9zcx27PGZCQz5YcDHA+hp3w9s/7Z8c3Wv3mBYaGh2FvumYjk/h/QVna58VNR0zwauoW4urpdXnuJbYvcMI4cTPGqKg4Awm4+pfnip SG3Y5DTbHwteaPaW83iCOOSBi8sYQeYcnorMyrjr69qyr7XYNP ne30hI3GcK0soY/98rkfqaXwz4XvPEt99q1e4EX2hwdi4UAHufSvT9W8D+G/ClhA+mgXGoSH5Cy5OfUZzxTvYSVzivAEVt4jM9hq7eQ7EsJxwV b+Hj0zXU+H9AjvdQj0+5dWjtbdzMy4J9yF75OR36e1aWjJeLGf 7U0/TZI0/eeaIBFMmOeGUDd06HNcl8MNclkh8Rz3tmbxZgZNwwfKH3s5P3f vdvWqbuOKaZ13wE0Kzk+IsurS28f9maVbm7mJOfmBIRfbLD/x2svW/sXxS+L9/b674gNlb2mJEj6B2Oe/H8+9dL4EuBovwk1PUTNvl1C5kIfuY4sqo+m4GvmvwvqEt342ku p3bbOXaQZ6jBOP0ogriqM+mrfw7pnhzxBbalp2sNevGDbgIYQg UjH8I3H8zRqAE0sbyjaXI38e/X8q8V+E/k6x8V7UR7lt4S8rDceSFOP1xXtWsOHklAGBuCDHoSF/rTvoQcvrUlv9tl1C5LK67mZtxCjPJzzitrwjBBaeFNc8UTIrR7 fsFpuzhnkGZW/BDj3DEVwGqS3eu65P5O46ZbOUZgPlaQAnH4dcd8V6p42sY9B+C 3g/R4BzPayXsx7sZAGU/wDfLY/CsrdTV7Hj2veMbWGSWE6nehWclVitDsBwB/FtJ6DvXsXhbXtD8ReENPgjspIL22sxl2TYHC8ep+teG33loSzE Ljnce1dv8I0kmnYpdrOJ45QhDZ/hNaRlcyNy5vft/ifT7WJVa3tdMdyPR3uXA/RP0pkazN4unmRSVtrLJ46sJIzx+BqSxgh0iyu9VuAVlSIRSbum FeRhj/v4apfDDWYtdvtQukxmeG/iQY5Zkti6fmUFQ172hotjg9u2+1S0Yc21/PH17byw/RhXF6VNd6X8QrZ5N7AzbRnurV6H4ztDpfxR8SadtwryJcJ7jG1 j+YFYk0cI1a1uHRSVkHzY6c0+azIZ9e+BL1T4Q0+SNsgqVP1Br yf4+aMLG/s/EcEAe2W5VpDziIsyknj1I7+tdb8L78SeGZbXdzBNuH0NdLfxW+ o6fLa3cSSxSKVdHGQQeoqpR0CLsfPHie4+3XUtw+12Ybdw4OOM EY7ggGtnxRpsHxC8EM0xT+04iBJIR924Aysn0kAJP+15n90U3x/4Xbw9MjW25rJuEJOSo/uk+w796wfCGtLouu7LpyLKZdk2Bk+USMsB3KNhsdxlf4jWUXY6 GlJaHB+HZ5porvwxrMRjvLbKqrjkgdV/Dt7V1HwZ8eaj4K8VxadJKfKDkJuPBBP3fxqx8dvDktpJH4p05F jvbJwtyYzuDrwFbPcD17qQelcsn2HXNPTUERFkkUBmHWNx1rXb U52uh9+eHtfttZ0mDULV8xyjoeqnuDW3ZB523E4HrXyZ8L/ipp/hCa30i/vjeJIi+ZlcHPqO2a9x8ffEfTLbwPHJoc3nS38YAKj5hu4CY9Se 34cbgaptLUEjg/jR4ntJdRfRtJZv7KtH814/MYo0p6BQThQSCSBgYDcA1yWh2NzBpiJEpbVdbfyoieqRE/O/4/yrLsUj1HVwLybNtE5lupgc73/iwe/QKPpnua9K+Hto93dXHiq8jCBh5NhH2jjHHH5f5zWXU1fuqx00c Ftomiwadbj91bJt46s3c/UmmWylIcyEbj8zn3qG5cz3ix9RGd7j1Y9B+HX8qp63c78afEx+ YZmI7L6fj/LNBJB55u7pro52fdiHovr+P+FXrOMk7z07VWsoTIwA4UVsRRhV AAxSYCxpipgMUKKccUMQ3NRsac5qvJJigBJZABVUsSck8U2WTc eDxUe+gY8sKTNMLUE8e1MAJxTC1Iz89aagMkgRepo2AntozK/sO9Lrd/HY2bMTwBgD1NWJZI7O2OSBgZJNcbdXTajeG5k/494z+7H94+tJgLb7kD3VwczS8nP8I9Ks6RaNf3fmMP3aH8zVKI SXtysEWTk/MfQV1CCDTLIDO1VHJ9aTEGs6iun2myNh5rcKKwvD9hJql/l+Y0O6Q+vtVW4ln1XVAI1LM5wo9BXcaXaxabYrAmN3V2A6mmBb OyKMRp91R+dRBZbieO3gQvLKwVFHUk0ySQEnngd67/4UeH2Zjr94nXK2qkfgW/oPxq4q4N2Ox8KaNHomjQ2a4Mn3pXH8Tnr/AIfhWtRRW5kFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAVj+MNDh8QaDcadKAGYbon/ALjjoa2KKGrgfB3xJ8OXWlarND5JSa1ZmVcfw5y6/h1H1NQ2N6uq2CRzMpnVQAzH72OFJP0+U+2D6mvpT9ofwU2oaf8 A8JDp8f8ApEGDNtHPHRq+U9QQadfbov3UExJQdo37r9D/ACP1rCzRqnfU0NRuLe8DbvMaWEeXdAL8xQdJAP7ynOfXkdwawL t5l1l4bsr5kgB83d8smRw2fcYOe+aTXLxnUakBJDLCypcvGcsh 6K/uCMA/T6U7aNR02OOXYJE/1bL91SxyBn+4xyVPZsjvwrFGx4P8IaZpGum8ieOZpgJkeQjMaE AiNRnk8/M34dzXR+JLwwWb+WpkkbEcSjq7scAfiSB+NcNpP75o4Z9ttd2p PkytnAbAHzY52nH4Zz256XwFeya34w07TNVg2XFpI7uCQMyKpI yB6fe9OAe9LcVrFr4nXMPw9+D6aHBMPt+pkpJKOrluZX/XH4ivDL+WRfDHhWF1ke3aO5nQZ43NOyZ9v9WK6n476tc+LviRc aTFKtva6extod4bHH3mwoJOT0wOgFWZvBMlv4Ft7LT31HVbpLn zkmuIDa21ohU703S4ALNg4J/hBxzWkdhMh8Kao0Tx4OHByQexr1X4bX1nq3jyCfXJlWytRkl+n AyBXi8dnFopaW/1O3eXjCW2ZAD6buAf+Akj3ratdXfUols7RZwGGW8xgqkDqdo4x 7nNRYfQ9p8b+JNM1yTU7fSpI5UWNi7xJtjGQQFXPJ784rx/wpt0zwp4qt4/LeYyQwtOr/KqGMMwA752YzXV+H7GbT/D93M8UokuEyu7q4AIBA6jqev8iKxPhz4eufEWpNo0lhcWVnNNb tOWVslFVgSSehPTFK9ho7PUNE1eb4Z6V4c0WzknvY9MW5kVULM DKRI3yjk4YgV8/aL4S1G216SC4vLe2mAZeAXkGeDhBzn64r6A8ZeLINE+Mmi3k9u klnHcuJEKBljXYI92P9n5m/Cn/Hr4p6Xp8DtpiQS3M37vawzKMdcsfmx+NXHYiWu5wfw00u00DxJ aC1typd8SSTkGVjg9hwo9q7fVb4Wmn6leONwhgaTPpivIvC2rO 2r6ddzXbXF/PIJWHZAewH416Jr0jXfhLWwn3mtWUjvnNDvYS3OY8F6xBf6Hcp Aqw/ZoN7ggF5Z2O0/N6bS54xyfpj279oiNbY6Np0QwltpQiUDsFJUfoorwfwxaw2Pgu +vsRpPLfx28arwSqoNzEe/H45r3P9oKTzdb09yeHtSPoPNkH9Kl7Gkj5s8SMFtJBnBNd9+zL AxuJ5ZPuRK4T6la4TxTaSi4Me04DYzXpHwKcWvmWwwGbJP5U4v oZM3vihC48L6ukX8UIYD3B5rjvgq9n4ej0jVbry9ia3HBJg8tE VAckemGxXpviy0e80W+SNd7+S3HqMf/AKq8s0cxXvhbUlmkSWSTUWl81FICts5wMDA+bp7Um7Ns1hqjT/aTsJPDPjvSNZlUyRNbJb3bAfe+UBj/AN9bz+FcTq6KYRJC6yIfmR16MD3r2z422B8bfCXRdXhQNcPabG P/AE2U5b8385fwr5y8E35lt59JmLHystDu6gfxL+HX86VtCGe9/A/WvtUrWxPE8JHP95f/ANVeqRTDZ1r5z+G8lzolwNR86NolnDKFbLAdwa9hudZVZd0LZi cBkPqDWl7olG5rWn22uabNYXIzkcEdV9CK8C+IHhXV9AJeaBnj hffDOgyrDuvtkZ4Ney22siKWO6LZVeJP93v/AI10uoW9tqFk0ckaTRSJ0IyGU9qhrU1jJo8X8FahF4h8LSabdh Z5rGERuG5860b5Ub32EhD/ALLR9lNeJTyXHgjxPf6VcQtLal+BnG5OqsPwr27xDpVp4B8R6T qGjktvklBtZSSskJXEkbH+6VYrk9M+wqPxU3h661FWTRv7WDkR xSzWgcorrlVJI4fHBx0IOOmaEwmr6o4/wXp9n4gu45oEGz+9IpUgYyefQAEkjsDXZ6tdiR4LWwBWGJfJtF AwcdGkI9TyB6c9gtQRQSaNZywXT/8AEwnA+1BDxBGPuwrjoeOfTH+zg6Xh63W2tJdYuUDTyHy7OIDq 3TIHoOgqfQIqyuXPD+jPfXltoVvkb/nuXX+FR1/w/GvXruSDT7BIIFVYoFCRovHPYVh+DNHOh6SZ5wG1G8OXJ7dcL9B z+tW5HWWZrqd9trb52k8B27t9Ow/GnfQTdwkm/s+xM0g3zyH5F7sx/wA/gKo2Nu7uWc7pHO6V/U01DLqV59pcFVHEan+Ff8TW1bRrEgAAzSYE9tEsaBQMVOpxUKv Tg1JMRMGwKRnAqJnwKrzTgDrRYCWaUAHms25uQSVB4qrqGoKCY 1b6nPSs5rsetAzU84DqSaZ5y4xnArHe/A/ix6mq8uoAdG4FPUdjeM6njORSNcr0B6Vyk2rhGPOaSPUnuHWNA WZjgDvTuB1Ky+Y4RBknpWvbxrawl3I3kZJPaqOj2os7fzrgjzM ZOf4a5/xHrxu5Ws7OTEef3kg/kKXQQ/XNSOoXDW8TEW6H94394+gqgS0rrbwr7ACqiuWKW8Kk9gBXVaFp yWqCWXBlYck9qBE+lW0WnQjd/rCMs1Ymuak93N5MZJQHoO5qXxFqnmP9ltznsx9at+GNIKMLu5A 3fwKR096ANLwvpf2KATTKPtDjn/ZHpWxKwAI7U0uAMU7S7C71fUIrGzUtJIcD0UdyfYU0gNLwVoUv iLWFhwy2UJDXDj07KPc17hBFHBCkMSKkaKFVQOAB0FZ/hnRbXQdJjsLUZ28yPjl2PUmtOt4xsZt3CiiiqEFFFFABRRRQAU UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAMuIo54HhlQPG6l WU9wa+Rv2gvh5JoGqTTWyE6ddndG2OEavrysbxl4esvEuhT6Ze xqyyL8rH+E9jUyV0VF2Pz4hE0JUlA8igxujDiVO6H39Ko2znRd UgwDcaXcKyxBuhQ/ejPuD/nmvRviB4Ru/DOuz6dexsF3fK4H3gOjD3H+e2eOu7eIxT2t4ubeQ5lK9UbtKv8 AUVlY0RZ1zS5FS3u7WfzUlXfbXH/PVR1Rv9te/qOfWtbwZqgt5L3WEs7eS50qwluJcnZM6KAgi3c8bpARx/DWJ4J1JrK+k8KeIAXs7ogpKh+438E0Z7c9fz9as+KdDutPvmik x9pC7kdVwl0g53AD0/iXt24xhbaFXMTUPipqcFzLcab4d0XSZJTlp5yZpSfU5wD+IrPg +IHxB8QagDY31zfXTHYrW1oilD1wG2/L+GKyfGfh6HULKbVtLR/PjGbiEclffH9R9exrof2YdClm1yfVJrR2ih+WO4SbhZMY2ugPT DEgkdR1p2XKQzO8Y+GPGVvpDeIPFt79mLsEiWa48+eVjzgcnA9 ea6P4U2n9jaE97JGftmoggTvyVjGMhfc55P4d69C/aE8Ial4k8H2dzpGJrjSTLNJbdDMjBdxX1ZdvTuCcc8Hwjwr4nu IVa0nZ57fzPMhKkb7ckAMpH90gDn2HuKdmwPo3wraN9g+3T/OCMJnnJ9a6/wAPwbVedxhtpIHpgHFZ+nWjRaHp8OMBLdNw/wBogE/qTWndymz0G8nUEtHCzKB1JGOP51PoF7nzP8YpmvdSNwgV2k81s Z52tuY8fQ1yfi/w/wCIfEutTawbWO009Y4wbu6kWGL7ozgscsfZcmvSfiLomraDYQ6 nrHhQwR26hUnvmC57DChufpg1wUvjPxJ4luFgWYGKFADIIl/0eMejYyB7AjPpVRfKJmdaW9hpzwSW1897cQjHnIpjiTHoW5b8q 9e8O+ZrXhbUtTgVppJYNjhDkMcNhgAPavnrVrxNR1plS4m+zF9 qs55I9TXvH7K90bga5o8h3RQpHIg+pYH+lJolbmJM8kPhjW47s M8/24z7jGVGWjB4BA4zx0xxXrfxvdrn+y50xu+yZH/f6Wt/XvDdhrWkT6fdxAxyx8EdVPqPcVznxMDf2VpW87tkEsRbHXbczD P5CpNG7o4aLW/BeoWD6VryNY6pZoCJ1HyzIemR6jpUHgHVNNPjT7NpjIbZV2hh1 Y+prntR8Darq3iOPVk0rUrqyUeVMIYiAwHo547isvWb+Pwzqtt Z6VpwslEuTuk3v1/iP+FUjNn0laMiajGJACrNsI9jxT7jwlos/nRyWEC+axZmRdrFumcjvWTDO0+k2WpxujxToCJEORuA5H1rsra YTwxTr0kUN+YpyRUWYHgHS5R4L8WeD7lzLNpjLfWrN1eEkkY+n 77Pu1fMfxJ09PCvxAt9UhjItbwl5FA4DdH/AJ5/Gvr/AEIx2PxD0m9k4tr9JNMu/QpMMIf+/gUf8CNeBftGeH3XSL2N0xc6ZcbiCOwO1v8AH8KUdBy1MS90W68 Pab/a8V8n2WTbIg+8smeQK9S8Fi28TeFFuLdd0sHVc7cA/wD168B0/wAVJe+D9O0a8aRWsd5BYEh8nj8hgVvfDLx7q+gauJ7EILUkgRy JkPnqCPQ09nZknq729xZ6j5E8bBWOAu7PFeg6BY3+n6AJLkBrN H2wP3C4ztP05A9vpR4Uh0Hxky6+LiGzs7WIPdqz/wCpPcZ9PSsLxt8VLHVNTHhzRreRtPjDRpGrbAxwQXf1OM4Xt1J zwG1dAjgfGOtm+192sZo/PVSIZCAyWkP8Urf7R/hH0rctVHhPQ0iSFpdd1AgwpIN8tuvOGJ5IkbJJ/u5x2Gee8KS6RZxDWoLNjFJIJNOtpRmS4fJC3Eg67QeI07kFu2R 0zRTaXBJqmoN5ut3gOzcc+SD1P+fYDgcRa25puzkpNOn/ALUeG4kDmM5lI/vY5H16D2xivRfA2ifaJE1fUDi3t0xAG+6oH8X09PxNYXhPRX1W +EYDfZ4zmZ+7E9s+p/QfhXo15NFb2ywxKBBEQuxOPNfsg9h3/wAM1K7lSfQZPPJdzb8tFvTCA8GKLu3szY49APrVCVzqDqkS7bG IjYB/y0I7/Qdvz9Kj3tdhgz7o3O6Vx/y1PoP9kdPf+dyMgDAAx7UjMtW6rEu1eKmD1UD09W4oYFpX5p28 AdapmUCq9zepEhZnAA6k09xl24uAoPNc5rGtKhMcTjPc+lZGue IVfdHBJhO7dzXK3WpqWIB68daQG/calkE7vwNU5dWVQPnBPoOtcnf6k3TcOvBqk13I2cPwOB9KEOx1 s+qZ5MigGqcmqHGM9RjNc6bpuWyefU0/T4LrUrpba1RnZj0HQD1NPQZrxT3F3KsUCO8jnAA716H4f0220G xN/qUsYnxkk9E9hXO2txo/hG1/eSC71Er823nHt7CuY1rxFeavOXuHxGDlIweB/jSbuJnV+IfFM2pymC1LR2wOPd/r/hVGzd5CI4xuZq52wd7iURwDJzye1eg+HNPjtohJKRn1o3Fuaeg 6cttH5smGlPc9qTWdWOPslscseGK/0qG+v5Jj9lsweeCw71e0TRhEfOuMM/vT1AZ4e0bLi4uVyeoBrpxtUYUcCoox8mFGB2xUsEE93cx2lpG0 sshCqijJY0kr6iFhjnu7lLW2jaaZ2CqqjkmvaPAnhiLw/YbpQr30w/euP4f9ke386h8B+Ebfw/bCecLLqDj537J/sr/U11VdEY23IlK4UUUVZIUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAUUUUAFFFFAHFfFXwRaeLdGcGIfa4xlGHU//Xr4/wDFvh++0bU3tZkIkjJ2Ejhh/n/Pp9615t8Yfh9beJNOkvLaLbdINx2jnP8AeH9R3qJR6lxfQ+Kri 2huIkORH5TfuJT1t3P8J77D+h/I9f4S1S31yyPhfxMjpMhH2a4zh43HTDDoR2Pcfrl+LdEv9D1Wa V4Cy4/0iHqGXpvX1HqO1Z9pLAktrdtNL9kR1KTIMtHg52NnqPQ9s/nkWjR8ReENZ0ac3LqWIPyXEK4WYHvj+FvVTwe3pXP+Gbu48LeJ R4g0WEkP8l/p6cLcJ3aP0YdcfX3r2/VlfWdJ0u8inREvdiCLcjNDvRWGRjkH5sjvjBrznxb4XvrVZLz7 MYwmGl2klQMkBweuMg9eRjPI5VLRhuezeG7m38R2cF7o0wmhkU MsiHj/AOsa8t+M3wh8LQL/AG9ayjS9Rkuoomt1GYrh3cDAX+Fup444PHesLwL4y1PwVqVzJb OqfaF/fwyqdkp9TjO1v9sAg9/WtjxL41/4SC1s7rVLA2mm2l4t4lzLy7soxjjIILEBVGTwxJGcU79UKx6/KFwFA4zx9K5/4n6lNpXgHULm2mENwdkcTk42liRn8M5q54c1m01eyju7eVHVh2 YHkdqzPHunf25NoWiyputJr/zrznA8mNckH6nA/GhgeBfGfULzWPEdxpV/dTEaZ+6LSSF2uHGAZDnuevc81hfD65WzvDEVHkTq9vMo6EHv+H Br1D4x+EbnW/ihqN3pkaw2ckUKm5mysQkMSg7RjLnAHCgnJrze50Kz0rVHtZ1v 7qTdgQ+UYvNb3GdwH5UXA4y/8OXq6pdeWqR28chPmOwAC56n0/Gvb/2W7E2mralIkcrRS2n+vYYWQhx90Hkjnr0rz7UtYsI3ijvLW0ZY TlbW35VT/tPyB/wH869D+BHif7b8QJdNlEe86e7MqDCRYZMIPfHJ96ptsVrHvMeD t91NcJ49BNmsOf8AUXVwn/fWyX/2tXcRgEjY/wCBrh/HxWOW4MpCIbh5NxOBj7PbL/7KallGx4N8TeI9f8BrPqd9bSRWavby2sYVGAU7Y+g7jH518y+O rm0u/FMpSWK8nVioit+Yoz3G7ocdzXSat8RrbR9Pu9H01BcQXDf6Rvc hX9vlIOPXkZ6HivNr/VJtSZ/KSG1gkPzCGMICP7qqvCr7Vad9ybHpXwz8WGxvBp13M9xYlw0oV f3QYdBk/qRX0bpxhW1jEA2xY3Iu7dgHnAPtXx/oUcjmIMpVFOFUDr7AV9K+AvEct/bw6ZdxW8E0UOY40BL4HUsfU8cfWpTuhLc7O/hM9pmNijr8yMP4WBBU/gQDWJ8dtPstVv47+WMrZ61YpNME6gsNsgHvkGt62cOhHqKh8X2 o1L4fRvGCZ9JuzE2P+eUvzA/g2R+NIo+Z/jJ420nTbC38FeFdAjsbS3VRNdTRgyTY/u98e55PtXKaHe22rlIY1fzehVFP5+wr0Xxb4a0DUdXjnu7NLu/jAxF5pRWHbzCOijrUF5pTGOPTtHsoLOzVDJO6IIVbB5ZicbVH+ 0c4PviiVmhWNrQo4tM0GbT7OfEky5uJg2QB2UeuPX16VV0iJfD jS3kbj+0zmOJ2Td9lLDHC/wAcpB4TtnLY4BdBM1qsFnZ+bc3Ug/deUpWWX/rmDzEn/TRsMf4QvU9z4R8KppRTVda8qW9Vf3MKj91bD0Uevqepp3tsNR6 kHg7w6ukWg1nV1ZZ8FoY5H3tHkcsx/ic8c9ug4qq/2vXdbMEHzSOcs3aJPerOvatda3qY0rTFLvnDP/Cn1/z/AEz1Gh6bFoVmtnZKJr6Ub5JW/h9Xb2HYdz+JqS9jW021tdG0s2sTiFIk3TSn+D3P+0aw5Llr6Xe UMVso2xRHrt9T7nqfy9c19Z1aOZhZwyFreJslieZX/vH/AD/Sqq30ajJYVNyTciaphIq9651tYgQcyAfjVS48RWw488fnQmB1n 2hc9abLfRxjlhXBX/jHT7RDuuVLegOTXDeIvH15JK6QARpjAyck/l0o8kNI9X1rxVZWWVaUNJ2ReSa4rV/Fcl6w/eYjP3VB/wA5NeU3WuyPKW3HL8nNUX1eds5Yn3os2PQ77UtcAOFbIYYHNZc 2qySAqH69MGuQN+X5ZyTxVq3vFxye+etFg0OljmZiAWyas+aqr 8zZx61z8N4QvBVV9WqZ9Vitf3pdCR0aTp+C/wCNFhnUWNmJY/tN7Olraj+N/vN/ujvU174pg0+A2mkJ9mjbrIf9a/19K891DxJPcOSjyO5/jc5P4elVLYXd2/yh8n8zTcXuK508+rh2Lu5Yk9M5NXtIgvtUuFSNGCMaTwr4TnuZ FlmX5c85r1LQ9LhsFWOCINMeAMUnqDE8N6JbabaiW4PzdcVsxx 3GoNshj8uEdyMCrlppuWD3ZJb+56VfS4iiYRR7cL29B7UInck0 7ToLRBxlu5PU1oqC3GMD0FYN/r+maeoe6u1Ln7qIdzH8BWv4GsPEnjq6C6TaGw09GAmvJRkY9hx k+38qaVwNGztLy/vI7HTrdrm4k4VF6AepPYe9ezeB/CVt4etvNkKz38i4klxwv+yvoP51d8J+G9P8OacLWzVnkPMs8nL yH1J/pWzW8YW1Zm5XCiiirJCiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigDzD4tfDi21y1e +sYik6EviMfMrd2X+q96+VPEnhnUNC1ZjDAu2Q/voAP3cq92TP6r2+lffVcD8Svh7ZeIbWSe1hVbg/MyDjcf7yn+Fv51nKFtUWn3PjdrS88Pyi7t451gzunt45f3kBI6 gj064/pXY6P4nOpajpbTzGV4w5mBIHnKBIFO0DAAEhyT1OfUVe1nSLjw 7dXkV/ZxyLKnlCd48FGH3d3QqQfcA+3SuE1Jraw1to9IudsqNkRspjWV u5jJx+XAPp2qOhR2PifwZbXlv9p0dVZRyLfdtK/9c27f7p4+lcGLW9srqQwRRzNCpE8MsIJC9w8Z5H+8OPeu38L+K Ul+WVxDKDhww2jP+0P4T+n06Vv6xpWm68iSTo8N1H/qp4m2TRH1Vh29ulTYq/c810eDTo9Ttb3QNSuNDlkkX7RZGQCGXnnaWBU/oa6u++Jw0OygbU9Ei1KW4t5JrR45NgTbPNFiT0/1anj19q57xN4U1a1kM08P9pQL/wAvNrH+8x/00h/i+qc+1cnqFlaXtq8A8qSEn5lUkYI/JkPsRRd2Huix4y+OHijVYms7O6i0m0K7TBpo8skejS/eP0BA9q87urLWJdJOq3EclpZSyiOJ3UqJ2OSdpP3sY5PuPWvVv g3ongHRPEJuvFdpNfpvBt5pF3pH/vIMg4/vfoK7j9qC1ttbstH1zwoyaxpVtAySRWi+Y1u27JZ0HIBGOSMfJ g9apkHzr4W0+0S/ivrsrJFFucmUfL8oJ6d+RWp+zVcsnxcgBfcZ4LhS3r8pbP6VmW sMzaCWVmafzgU77ST0Pt61v/CXS49F+LkeoxuRpdms2+V+BkwtuA9QCTz7U4tWZL3R9RwsxbPG M1zfjn7K1tNHc2ySM9qzpK/SI5wzAdC2F/D261o2ms6bMivDe27qeciQVfuF8Iavo1yviHX7LSY7SYeXPK43 Mdjb0VeS+VkTIA79jg0rXLZ8c+JvC9//AGkg0+Ge4E5+Vepz744rVt/BdzY2KQS6hBFfSnLhV3si/wB1ewPqxIxXpHxB13w3C7W/hpbxLHZsN5dELLcc9Y4lwVX6t9fSuAttQViWmhYxfwQq+XmYdC 59B6cCjmYrGnaabbaPCnkTtdXAXDXT9F9kHQD3q54M8ZrYeLtN ittrwPcqlxKeeG+U89+tcJ478RalNdLpzyJGDGgkSJdoVSAQgP 061oeFdJe8mWWMslrb4eWVVJCjPAHqxPAHUk07MVz6qvtf0nRo JJtQv4IFXqGbn6AdTXnuseP59Zs9at9An1KztbtIY5Z1JiRgjH q2ehDsCvHY9sVyXi6x0q31SbVJbW712+nkPlWgb5U78gc4596q aXpPifxXcLHPGohiI2WdngRQ/wC8/wBwH/vo+1ZrUo3bGzgsoFe8uo1Zh5n2eOVJp2x0ZiDtXHq5Cj0Y1raX pOt+LJA1qi21gH3ieQFow395QcGZ/wDbYBR/CBXReFPh7punxI+qCO5cEMLdc+UG9TnmQ+7fgBXX3uo2un2jST SpDCgxk8AegH+FVqBlaL4d0jwzbO1sjT3kp/e3Ep3SOfUn+lYGtatdateNp2kuSM7ZLgdB6hf6noPc0t7d6p4o uGtbNHtLAf6x24Zx7/3R7dT3710/hnQgrxWWlwb5GwA4XJY+w/kKnULkfhfRIdLhFtaIr3LDLue3uf8ADqax/G+oapGJNN0XT7uRCc3Fx5ZzK3p06V9I+APBNvocCXN2okvD82C c7D6k929+3auzwK1VO5Lkfn7cx+KVYrHo98xx2hb/AAqrLbeNZvlXSbqMf7aEfzr751zQtN1mEx3sAJIwJFO1h+NePe Ovhbr1lBNc+GL15s8+URn81zz+HNTKm0NSR8rXumeMFTzJ4ZI1 HqOK5/UYNajRvMnxjr84Br2bVvEOs6K8ltrunQb4zhwjEE/8BIzWTNrXgjVQGvbCxLnqHhGf5VFizwq9lnT5WkJ/4FWbPdSHuT9K94uvDPgG+yY7e3jZuhSVl/TNY9/8MtCmB+x3TJnp+8yKpWE0eMedMxyqfnTf3zH53C16ddfCuQE+T foV96oP8K79idtxGR7mq5kBwSPbxf6yXcfQd6eNTRB+5jYkV3S fC286NcQbR3NX7b4XqpBlu1A9l/8Ar0m0B5m1/eykiJNh/vDrUlvp91cOC+9mNev2Pgbw/atm6vFbA/iYCtOGfwbpC4WSJyv90bqOYZ514e8G6jdsp+zlFPO5xjivS/D3giGyAaYBnwKpXPxCsLcFLCz388F8Y/KsLUvHWr3YKpJ5SnsvHFTJX1YWZ6si6bYR7ZLiMHtGp5NQXXjX R7BCiMBgnhOW/GvHItQ1K43ATPlupzyfxrQ0fRL67lVUheWRzgKq5JNTuPlXU7H WPH9/dOItIj8mP+J5FyT/AIVX06bXdWu0gtjNLcSfIFiUksSe36dK9K+HH7P/AIi1jy7nWh/ZFmcH96uZWHsnb8cV9IeBPh/4Z8G24XSbFTcYw91L80rfj2HsMVpGm3uRKaWx498KvgK7NHqvj Msg4ZbJW+Zv98jp9Bz9K+hNPs7XT7OOzsreO3t4htSONcKo+lT 0VsopGTbYUUUUxBRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAHOeMPC WneIrdvNRY7krgSbchvZh3FfMfxW+E1zbSsiQNG65aJQePqjen sf0r6/qtqdhZ6latbXsCTRN2bt7g9jUSjfYpSsfnJfzajpNz5OorJ5sX ypcAbXHs3/1/wA66nwl42a1CRXLqYh0JB2D+qfqPYda+jviV8HLfUIXltIPtce DgDiZPp/eH+cV80eMfhlq2kTvNpvmMik5UKQw9iv+H5Vm7plp9j07TNasr 4DyJl3kfcJGfw7H8Kj1nw/oGuDOoWEUkwHyyrlJB9GGD+teCwapqGky7Z1eIg84GVJ/x/I12WjfEK4jCxzKJsDoxPT69R+OaQ0amt/DW/UmXQtZLEciK7Xn6b16/wDAga5OSLxboFwG1jQbtkU8XNiPMx7/ACkH9BXpGl+N9IuFXzrj7Kx6eYfl/wC+hx+eK6S3voZog8bpIjDhlIIP40Id2eOR+ILLVmMV5LDqQK4 aK5C+co9AWAcH6VHd2tglo4tbd41mAidbmV1/dgglVbaMdB05r1vUbLRdRXZfafaXHtLErfzrGl8DeECd0WlpAf SCR4x+QIFJ7CPJZPBOlXUyy2tqLZCOf9LeUk+vQV0N3pt7c6Zb 6dPfl4oMmN2QuwbGATk88ADr2HoK62b4d+HW5ikv4T/sXBH86q/8K50Ethr3Vm9jdn/CnqVc4R/BFzOzeZrDBT1K2uSfqS4rRtPDfhvSkjkupV89QQ8s12ED/wDARjH512cHgDwtDw1rPcf9drl2/TOK1dP8OeG7JwYNGsUI6N5IJ/M0rk6HnsVt4auLnzLDSbfULjpm3083BP8AwKTK/rXS2Gh+JL1I449OtNMgTlDdODt9xFHhQfxruoXijQLGqKB0CjF RXmp2dom65uYoR23tgn6UbgZNh4JsR+81m8m1NzyUbEcP/fC9fxzXTwfZ7WFYbeKOGFBhURQoA+lc3L4gknB/s2ykmX/ntN+6jH4nk/lTF0rU9VG++maWI/wYMcI/D7z/AI09QLmpeJowWh0xBdyjgyZxEn1bufYfpVW20ae8lF9rNw7kcj cNoUeir/CPc8/St7R9DSOVEt4TPMOFIXhf90Dp/OvR/C/w8ubwpcakAig5CHr/APW/n9KEgvY5Twj4YvNZkSCwtSlsnJ4wMHuT/kmvbfCHhax0C3BjQPcsMNKR0HoB2FaWi6XbaVaC3thhR19M/Sr1axjbczcrhRRRVkhRRRQBjeJvCvh/xJbmDWtLt7wY4Zlw6/RhyK8I+IH7LOk6k0l14W1ubT5zkiK5G9Cf94cj8jX0hRScUxqT R+dvjr4K/FfwgXlm0G61C0XpPp/79cDuQvzD8QK8wn1/U7Kd7e4kuIJEPzI+VIPuK/WGsTxL4R8LeJojF4h8O6Xqq4x/pdqkhH0JGRU8hftD8vI/GWpRkFL6b2+arEfj3Vyeb1/xr7w179l/4LasWf8A4RM2EjfxWV5NHj6LuK/pXH6h+xj8M5mJs9Z8S2gP8IuI3A/OPNL2aH7Q+Qn8dawxw19KPYVUm8S306Ye7lbPq1fXUn7Ffgkt+ 78XeIlHowhb/wBlFWLL9jPwNC2Z/E2vz+37pf8A2WlyD50fGL6lcu3Lu341JDJczHAjZiTxivu7Sf2 VPhhYlTINVuiO8lyOfyWuz0X4JfDPSsGDw1DIw/imkdv0zj9KORi9oj8+dM8Na1fsvlWcp3dPlr1DwZ8BvG2s7GXS LhI258yYeWuPq2M1906ToGiaSoGmaTY2eO8MCqfzAzWlT5O4va dj5z8F/szWdsEl8QaqDjGYLVf0LH/CvavCXgjwx4WiVdG0mCCQDBmYbpD/AMCPP5V0VFWopEOTYUUUUxBRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUUAFFFFABWN4h8M6RrkZF7bDzcYEqfK4/Hv+NbNFAHgXxB+CYukklt7aPUEx1QbJgP6/r9K8F8RfCySyuGFsXikQ8xuuxlP0PH/oNfe9UNZ0bS9Yt/I1KxhuUxgFh8y/Q9R+FQ4di1Pufnz/ZGqafKRe2guE7lxtb/AL6z/wCzGrFrb6dEd8D3ulyE53RsVU/ltB/Emvr3xB8HNLugX0nUZ7J8/dlUSofbsR+ZrzTxF8IfFdkzPBolrqa9d9rOqn8jhvyBqbNdB3R 5RaX2qxr+51uC6H8InAH/ALKM/nVwaxr6oo/s+2uj38qcLj8i1XtX8L3Wn7Tq/hnVNN3dZJYCVH1YisuHR9Mn+e3uopB6q/T8iKTsPUuDWdYUAt4euye+yQEf0pTrmrn7vhrUR7lkA/nUCaPGD+7u8Y/2m/8AiqsxaMhxuvS3/bQ/40rIYz+0tfkPy6IEHrLdhf8A2U0jXmrE4lutLtD/AHdzSn9CK1rHwvFcMPLimuT6Kpf+VdTpHw/1icqLTw9dn0LxeWPzfFPQDg40urrAk1DUboH+CBBCv/fXX9a1NO8PqriT7NBbserN+9kP4mvWtH+FOvygG7ktLBfQt5jD 8Bx+tdno3wv0S1w99NPfOOxOxPyHP60JPsS2jxbStG8y4Vba2l u7jtkFiPw7V6N4b+G2pXjLPq04tYjzsX5nP9BXqmmaXYabCIrK 0igUf3FAzVyqUO5LkY+g+G9K0WPbZ2yh+8jcsfxrXAAGAMCloq 0ktiQooopgFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRRRQAUUUUAFFFFABVa4sLG4Obizt5T6vErfzFWaK AM5tB0RhhtH08j3tk/wqWHStMhCiLTrSML02wqMfpVyigBqoirtVVA9AKdRRQAUUUUAF FFFABRRRQAV5h4mmnh1+8jjnlVRJwA54yAa9Pry3xZ/wAjFef74/kKANfQ9AuNS0yK8OrTxbyflwTjBI67qw797yw1Ca3F7MzQuVDB yM479a0rK48QWPh9Lu2mRbJSQAFUkZYjuPWsZBPqOoAM4M87/eY4BY0AelaFemfQbe8upFB2fO54HBxmkOvaOD/yEIfzrA8TW02neD7Oyd/mEgD7eh6nH51leCLK2vtWeO6iWVFiLBT0zkD+tAHaf29o/wD0EIfzq9bzw3EQlglSWM9GQ5FcP4806zsXtGtLdYfMD7gvQ4x j+dL4Nmkj0rWAjEbIgy+xw3P6CgDrJ9Z0qCQxy38CuvBG7OPyp n9vaN/0EYfzrzbTYkm1G2hkGUeVVYeoJr0n+wNG/wCgfD+VAGV45uFk0O3ubWY7WmG10YjIway/h/NNJrEqySyOPIJwzE9xWj46t4bXw9BBAmyNZxtUduGrmPD2ptpd zNPHEZZGiKIOwOQcn24oA9GvdSsLKRY7q5jhdhkBj2qzE6yIJE JKkZBxivNtG1NX8RRXup4m3nBZ/wCA9iB7V6YOlAGL4xvxY6NIAf3s37tPx6n8BXn08t9BM0M006O vBUueK6DWtSs7vxXGLuXbZWhxwCdxHXp78fhVHxhdadfX6XdhK XLriQbCvI6Hn2/lQB2vhe++36NBKxzIo2SfUf5zVm91GxsnVLu5SJmGQG7iuP8Ah 7feTqEli5+Wcbl/3h/9b+VS/Er/AI+bL/cb+YoA62xvrS+DG0nSYJgNtPTNQ3OsaZbTtDPeRxyL95WPIrn/AIa/6i+/3k/kaxfHH/Iy3P0T/wBBFAHb3ur2cOmNeR3MRDK3lE9HYdq5S38X6lJdRLKLZImcByE PAzz3rR0e1t7nwMGniWQxpKyZ/hOW5rj9NRZNRtkdQytMgYHuMigD0yDWNLuJlhhvYnkc4VQeTU1 7f2VkQLq5jhLdAzcmorfRtLgmSaGyiSRTlWA5FcB4vdn8RXe4k 4YAewwKAO7/ALe0f/oIQ/nT4NY0ueVY4r6FnJwBuxk1leGNF0u40K3mns45JHUlmbqeTXDX yLFfTxxjCpIyr9AaAPXcUYqDTHaTTbZ3JLNEpJ98VZoAp3uoWN mQt1dRRE9Azc/lVf8At7Rv+ghD+dcB4ndn8QXrOSSJSoz6DgV2Ph/RNKm0W1lls45JHjDMzckk0Aa9jfWd6GNpcJNsxu2npUMut6TE5 je/gDDgjdnFVtVsrXTdE1CSxhWBmhIOzv8A5ya4DRIY7jVrWCZd0b yqrDPUZoA9G/t/Rv8AoIQ/nVqzvrS9Um1uI5tvXa2cVznjDSNNtdEkuLe0jikV1wy8dTisPw I7L4iiVWIDowb3GM/0oA7eXW9KhlaKS+iV0OGU9QaJdb0mNgr30KkgHGexGRXnvif/AJGC9/66mut0TRdMm8OwTS2iPI8JZnPXPNAGrFrekyyLHHfwM7HAGepp H13SFYq2oQ5Bwea8uj/1i8kcjpXeeJ9G0y30CeaCzjjkQKQw69RQBu2WoWV6SLW5imK9Q rciivPPBrsniS12kjcWB9xtNFAHp1FFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFeYeJ4Z5devHjglZTJgEIecDFF FAHWeF7ZbnwmtnOjLuDowIwRkmuGmsby3uXj8iXfGxGVQ9Qeoo ooA67Whc614TgmjhczxuDLHtwcgEHA/HNYXhm6n0jUGuJbC4kVoyhCoQRyD/SiigCfxXqMusNb+TYXMYiDZ3KcnOP8ACtDwdpd2NK1HzYmiNzG Ej3jBPB5/WiigDnIbW+sNQiklspt0MgYrsPODnrXY/wDCWJ/0Cr7/AL5oooAreL55L/w5azLbSI0k27y8EsBg9azvAVu66xJ58DhWgYDenHUetFFAGd4g 0iex1SWGKGR4id0ZVSflPb8OldDp+t3MfhiRZIZjeRDyo/kPzZ6H8B/L3oooAn8I6JaNpCz3trHNNKxY+YmSozjHP+eaua3oWnPpVyILO GKUIWVkQAgjmiigDgbNL21u4riO3mDxsGHyHtXUeObefULaxvr WGSSPYdwC8rnGMiiigCh4U1OTR1uFl0+5lEpUgqvTGfX61T8R/a7/AFNr77DPEkwBRSpJwBjn8qKKAOs8LQPL4QNqVKOyyJhhjGSf8a 4lLS+sb6N5bKbdDIGxsODg560UUAdrb+J/PnjhXS7tWdgoLDAGT1Nc54x028TXJ5xbyPFKQysqkjoKKKANLQ/EBsNLhtJdMu3eMEZVeDzXNPa3t5fO0dnNulkLBdh4yfWiigDs/Esuoadodklk7rKpVHMa54C1T8IahrFzq/l30kzReWxw6YGePaiigDH8V6Zexa1cSi3keOVy6uqkjBrZ0jxG bPTYLWTS7tmiQKSq8HFFFAGiL6TXtKv7eK0ltz5W1fN43E54/T9a4mwivNP1OGeSynJhkDFdhGcGiigDf8R662p6Y1pFpt2hZgd zLwADmq3gbT7sa0l08EiRRq2WdSASRjAoooAz/EkE8mu3jpBKymU4IQ4Ndz4fyvhi3DAqVhIII5HWiigDzdLW5Dq TbTYB/uGvRvFoLeG7kIpYlVAAGSeRRRQBxnhSCePxDaO8EqqGOSUIH3T RRRQB/9k=[/img] Apparently they have 4 of these reconditioned 20-spokes at $250 each if you were so inclined! Aftermarket transmission spring mount and rubber rings for top and bottom are available, I've seen them on Ebay. I must say that I'm fairly impressed at the variety of rubbers and gaskets available for the XJ12 nowadays, thanks mainly to Eurospare and Uro Parts. They will do. Good luck and congratulations. This one is special. Let's keep her out of the boneyard, shall we? |
Well isn't this nice. The enormous blocks of jibberish text are supposed to be little pictures that I copied and pasted into the reply like I always do. Now they won't display as pictures. Nor can I edit my post and delete that garbage. What the heck is going on with this new forum setup? Mods can you help?
https://cimg9.ibsrv.net/gimg/www.jag...09dd7a51de.jpg
Thank you Richard and Lady P. I wish I knew how to post colour schematics. Richard, I didn't know the V12's didn't have LSD. All the 5.3's did, so I assumed. I guess the traction control is used for slip control. Thanks for telling me the front roll bars are the same; you saved me measuring. I'll get the stats and hoses. I'll try the spring swap and see. For the earlier XK engine vs V12, the 12 was 80 pounds heavier I think. I'm not sure about the difference in this case. The 12 is bound to be heavier, but the R springs are much stiffer...here's hoping. The tires were new, so I stayed with 16 inch rims. I got this set from an XJ8. To me they are nicer, and I didn't have to restore them. Thanks, Rob |
A large thermostat gasket.
https://cimg3.ibsrv.net/gimg/www.jag...9108132820.jpg
EBC8331 Thermostat Gasket, Jaguar XJ12 (X305) As I was saying... this is available at AutohausAZ for $2.91 each. I'm re-learning how to post pictures. Car looks sweet with those wheels Rob, good job. |
