XJ XJ12 ( X305 ) 1995 - 1997
Injectors not firing
Old Dec 1, 2025 | 06:49 PM
Parker 7's Avatar
Cleaned the faces of the 2 crankshaft position sensors ? different then connector clean
There should be 2 crankshaft position sensors fwd and aft face of the block
Does the V - 12 have a camshaft position sensor only used in the starting sequence ?
swapped the fuel pump relay , # 2 may still be OK not being used in the starting sequence
Cylinders put into a bore wash condition ?
Using old fuel ?
Main fuel line filter change , flow arrow points car's outboard ?
Cleaned plugs ?
Swapped the right heelboard fuse box small king relay in the corner ? power to control the 2 fuel relays ? may explain your intermitent fuel pressure
You can jumper this relay between socket 3 to 5
inspected the # 1 fuel pump on the pump motor connector for burnt / arcing sockets ? happens as the old pump dies
pic coming , same as above pic standard relay and numbering socket
Old Dec 1, 2025 | 09:21 PM
944play's Avatar
The 'A' bank contains a cam sensor. The Electrical Diagnostic Manual is pretty vague about its function, but seeing as how the X305 is batch-injected and wasted-spark, I'm not really sure how necessary it is.
The camshaft position sensor (CMP) (14) provides one signal every 720$ of crankshaft rota-
tion indicating No. 1A cylinder at TDC prior to the firing stroke. These signals are used by the ECM to control fuel injec-
tion and ignition duration and synchronization.
Old Dec 1, 2025 | 10:19 PM
watto700's Avatar
The CMP is there during cranking to determine whether the 1A piston is coming up to TDC on the compression stroke or the exhaust stroke. If the CMP is faulty the ECU makes a guess and if the engine doesn't start then the ECU tries again one rev later.
I unplugged mine to see what happened and the engine started OK but cranked a little longer before it fired up.
The CMP also is there for semi sequential fuel injection control..
I have attached some relevant info.
Cheers,
Jeff.
File Type: pdf
Old Dec 10, 2025 | 12:59 PM
Ivan Hall's Avatar
Using old fuel ?
Cleaned plugs ?
It'll run with propane going into the intake. Also as reminder I have fuel pressure now. Fresh fuel.
Greg in France
Jun 28, 2024 05:19 AM
santacruz11
Aug 17, 2022 07:25 PM
layada
Jan 10, 2017 02:18 PM
M90power
Mar 24, 2012 08:35 PM
