V12 Bolt Pattern
Hi,
Does anybody have the bolt pattern, dowel to crankshaft centerline specs to make an adaptor for 1996 X305 6.0L engine. Any help would be greatly appreciated . Steve |
Is this for a gearbox/ clutch housing? I don't have dimensions but interested in topic...I believe ICSAmerica on this forum may know more...
Hi,
Thank you for the reply, I will contact ICS. The project is for a mid engine layout to ZF trans. These bolt patterns seem to be top secret ! ! Thanks Steve |
Originally Posted by stevenx605
(Post 1863854)
Hi,
There is some twinking involved with the ECU to swap over to manual . XJRengineer has the experince on that . There is a different manufacturer on the AJ16 and V12 engines for the X300 series ECU's.
