2004 XJ8 boot doesn't close properly-help
Old Nov 7, 2013 | 08:14 AM
Billsblue73's Avatar
Default 2004 XJ8 boot doesn't close properly-help
After searching the threads, I think I have a slightly different problem. This morning I probably damaged something in the BOOT by over loading it. When I went to close the BOOT it wouldn't latch properly, I tried moving things around and was able to get it to close, but not completely. When I try to open it with the FOB or button inside nothing happens. There is no sound from the motor that I used to hear when opening. It is not completely closed, shows a BOOT open message and I cannot activate the central locking. Pressing the remote fob to lock the doors, etc. results in two small beeps. I am unable to open the BOOT by pushing the Leaper on the BOOT. I can open the BOOT with the key.
Any help will be greatly appreciated.
Old Nov 7, 2013 | 09:59 AM
Peter Connell's Avatar
A simply fix might be the fuse, not sure which one through!
Old Jan 3, 2014 | 11:33 AM
Seth's Avatar
Hi Billsblue73
Did you find the problem and if so, how was it solved?
I have the same problem after "overloading" the boot this morning.
Would be most grateful if I could find a solution before trying out the expensive dealer repair route.
Old Jan 3, 2014 | 04:11 PM
meirion1's Avatar
Sounds like the boot latch motor needs repair or replacement-they are available used.
Old Jan 3, 2014 | 05:47 PM
GMad's Avatar
I too have had this problem by overloading the boot (I carry a lot of crap around), I got around it by leaning on the lid quite heavily to get it to close properly, then opened it with the fob and never overloaded it again!
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
tomsjag
Jun 10, 2023 10:02 AM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
jimbo1948
Sep 7, 2015 03:14 AM
