2004 XJ8 at local Junkyard
This is the first time a junk 2004 Jaguar XJ8 shown up in my local junk yard. Its a self pull a part. I am planning to pull the air shocks ($15.00 each) , pump, couple O2 sensor ($10.00 each), couple coils ($10.00 each). What other rare parts should I pull?
Alternator, air compressor.
Starter, sensors, wiring harnesses with the components that are pulled.
If you have the money, and space, the whole vehicle as a parts car. |
Seats headliner, hood trunk, doors, grill headlights differential, trans engine, coolant bottle, side markers, center console electronic stack, doors, did i miss something :)
Originally Posted by annamiata
(Post 2015286)
(Post 2015286)
Shifter assembly
And on, and on and on. Strip everything electric/electronic. Skip the bushings.
Originally Posted by Mark in Maine
(Post 2015841)
How much for the car????
I was there last Sunday to remove parts. I could not go Saturday and someone beat to it and took bunch of parts including side mirrors, abs brake pump, driver head light, driver fender. The car was involved in a passenger side accident. I was able to purchase the air compressor, complete throttle body, three coils, three injectors, thermostat housing, coolant heat pump, air flow sensor, wheel lugs, and three or four dozen of nuts and bolts for less than $100.00. I could not remove bottom bolts from the shocks. I will come back with impact gun, blow torch to unfreeze the bolt.
They do not sell whole car. |
