2004 XJ8 Sitting too low
Old Sep 11, 2016 | 08:51 PM
Jag Brent's Avatar
Question 2004 XJ8 Sitting too low
My 04 xj8 is sitting too low.. with no dashboard message ( Car too Low) (air Suspension) none of that..i think front and rear are both sitting too low..rear definitely is. Not down where it scrapes wheel wells. Driveable but scrapes on speedbumps or driveway.I recently had it hauled on a flatbed due to needing a new fuel pump and it was put on a lift at repair shop when changing oil.I didn't seem to have any height issues until after that trip. Coincidence ? Same height parked or running.Thanks in advance for any help.
Old Sep 12, 2016 | 05:19 AM
Fraser Mitchell's Avatar
The ASM thinks all is well, so with no fault message, I reckon a re-calibration of ride height is needed.
Old Sep 12, 2016 | 02:02 PM
Originally Posted by Jag Brent
My 04 xj8 is sitting too low.. .....
Welcome to the forum Jag Brent,
I've deleted your identical post from General Tech Help. This is the place to post technical questions about your model.
Old Sep 12, 2016 | 08:16 PM
motorcarman's Avatar
You might check the lower control arms for damage to the ride height sensors if the flatbed tow truck used chains/straps to pull/secure the car.
A bent or disconnected sensor will cause problems. The suspension control module cannot control the height if it does not get INPUT.
2004 to VIN (G26871) should have BOTH front control arms with sensors and only one (left) subsequent. (see TSB XJ204-05)
bob
File Type: pdf
Old Sep 14, 2016 | 09:31 AM
Jag Brent's Avatar
Thank you guys,,so great to be part of this wonderful group. Frasier Mitchell was right ! Ride height needed re calibrated. Thank you Frasier !
Old Sep 14, 2016 | 10:15 AM
Jag Brent's Avatar
Thank You ! So sorry for a newbie mistake. Unbelievably grateful to be part of such a group. Mr. Bevington has already benefitted, Hope I can contribute a little something to the group. Brent
rf69
Sep 5, 2016 10:37 AM
powerhouse
Aug 30, 2016 01:23 PM
Harry Peter Rose
Aug 29, 2016 06:28 PM
Steve10
UK & Eire
Aug 29, 2016 03:06 AM
Steve10
Aug 27, 2016 06:16 AM
