2004 XJR - Throttle Body / TPS issue
Old Feb 11, 2015 | 08:05 PM
Lagonia's Avatar
The throttle body has been replaced and with 400 miles on the new throttle, I feel pretty good.
Getting ready for heart transplant
The tricky part are the two coolant hoses. Remove the 4 holding bolts and twist the throttle body around so that you have more space to remove the coolant hose clamps
Coolant hose clamps are more accessible
New on the left, old on the right
No surprises, pretty straightforward overall.
Old Feb 14, 2015 | 11:40 AM
jackra_1's Avatar
Besides being dirty were there other issues with the old unit?
also did you lose much coolant when doing the swap?
Last edited by jackra_1; Feb 14, 2015 at 11:41 AM. Reason: added another question.
Old Feb 15, 2015 | 10:09 AM
Lagonia's Avatar
Other than putting me in limp mode, I did not have any other issues that I could attribute to the throttle body.
I lost very minimal coolant. Pretty much a non-issue there.
Old Feb 25, 2015 | 01:50 PM
MCSMCS1's Avatar
Originally Posted by DonsXJ8
Just had my two tire TB plug fall apart last night. I was driving home and got the STD. engine systems fault and when I was poking around it decided to unplug the connectors to the TB and the two wire connector crumbled. So in my search for a replacement connector I stumbled upon this thread and found it useful. I also found another possible option other than the plug Lagonia ended up using. I'm going to order some and thought other may have some interest.
SouthBay Fuel Injectors
Did this 2-wire connector replacement work? It looks like a better potential fit with the design shown in your link above.
Old Mar 2, 2015 | 09:04 AM
anindyam's Avatar
Well that sucks. But at least you're prepared with a replacement TB. And that connector won't be a problem anymore. Good luck.
Old Mar 11, 2015 | 04:32 PM
Muddybear's Avatar
Does anybody know what size head the screws holding the TPS on are? Are they Torx head? I'll be replacing mine shortly and like to plan ahead.
Old Mar 11, 2015 | 06:40 PM
Cambo's Avatar
5-point Torx, special security bit, you'll find them on eBay.
Old Oct 22, 2015 | 11:10 PM
  #28
emorillo2's Avatar
Exclamation
It does not fit. The side grooves are not centered and the top groove is not wide enough on Denso connector. Pictures are from X-Type TB, but I assume is the same as X350.
Side grooves not centered on denso connector.
Top groove not wide enough on Denso connector.
Side grooves not centered and top groove not wide enough on Denso connector.
I continue to search for a replacement connector, there just has to be one out there.
Old Oct 28, 2015 | 08:52 AM
NCamie's Avatar
Hi Lagonia,
I really appreciate your posts on this TPS problem. Seems I'm having the same issues. When I get home I plan on looking at the wire connections to it, but I am curious to know where you sourced your new throttle body unit? I think I may have seen some on eBay, but I'm hesitant to purchase from there. What are your thoughts?
Thanks, Norm
Old Oct 29, 2015 | 07:05 PM
  #30
Lagonia's Avatar
Originally Posted by NCamie
Hi Lagonia,
Thanks, Norm
I got it at SNG Barratt (SNG Barratt - The Ultimate Jaguar Parts Specialist) and the part number is C2C20541. I have installed it last February and have since put 8,000 with absolutely no issues. The car is still my daily driver.
Old Nov 2, 2015 | 06:37 PM
  #31
emorillo2's Avatar
Talking I found the connector!
The connector is available for sale here: Jaguar x Type Throttle Motor 2 Way Electrical Connector | eBay . It fits and works perfectly .
Get them while they last!
Old Nov 2, 2015 | 10:18 PM
  #32
dwclapp's Avatar
emorillo2: Have you tried Ford electrical connector WPT-1269?
[WPT-1269]Motorcraft/Ford Wire Assembly(WPT-1269)
Connector WPT-1269 is in Ford's electrical connector catalog, page 12:
http://www.fordservicecontent.com/pu...torcatalog.pdf
Attached Thumbnails 2004 XJR - Throttle Body / TPS issue-ford-electrical-connector-wpt-1269.png
toronadomike
Jan 22, 2026 10:13 PM
way2far
Aug 31, 2022 09:26 AM
kelliott
May 31, 2022 05:26 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
